On Thu, 29 Dec 2005 08:43:31 -0700, "Matt Barrow"
wrote in :: "Hilton" wrote in message nk.net... CHANGE THE F&$*#ING CHANNEL IF YOU DON'T LIKE WHAT'S ON I didn't think an airman was capable of such inane rudeness. Your boorish behavior reflects badly on us all. Please consider an objective self-assessment and tendering an apology. |
Peter Duniho wrote:
Open source does make access even easier, but it's by no means required for the purpose of providing sufficient inspection. I definitely disagree with the claim of "significantly easier to detect flaws". Open source isn't more readable, it's not less obfuscated, it's not easier to validate. It's just publicly available. That's all. you haven't been looking at much code, proprietary or open source if you believe so; when you write code that you know is potentially going to be scrutinized by the best mind out there -- whether it is going to be the case or not, but you can be it will, by your next potential employer -- if said potential employer is not a moron -- next time you apply for a job and by people who matter in the field, the average programmer tends to do things differently it seems than what is done for code which is known to remain proprietary (who's going to look at it? Pointy Haired Bosses?) and where being readable and unobfuscated is a known bad carreer move (do you really want your code to be easily taken over by the nice folks of the newly opened field office in Bangalore?); I have seen good and bad code in either proprietary or open sources, you bet, but by far, the worst piece of junk I ever had to look at were proprietary, no contest. --Sylvain now this is of course completely off the topic, isn't it? :-) |
"Sylvain" wrote in message
... you haven't been looking at much code lol...the fact that you would even say that simply shows how little you know about me (and about the prevalence of maintainable code generally). Suffice to say, the rest of your reply is way off base. |
Recently, Peter Duniho posted:
"Jose" wrote in message [...] An electronic voting machine whose software OTOH is open, public, and whose compiling and loading into standard interchangable chips and media is properly supervised is much more difficult to rig. I would have more confidence in such a machine. I would not. [...] I do agree that an open source software voting machine is preferable. But IMHO, the more important aspects are for the voting machine to provide a paper record of the vote, and for the voting results to be audited. Specifically, electronic voting machines ought to spit out a paper ballot very similar to what is used today. The voter should inspect the ballot to verify it has recorded their vote accurately. Then, some small percentage of voting machines should be selected (randomly, of course) for their output votes to be compared to manually counted paper ballots from those machines. I agree with you. Further, the percentage of sampled machines should not be "small", as in 1 or 2%, but significant, as in at least one machine from each precinct. The paper proofs should be printed at the same time, with the voter inspecting both for accuracy, and then give one copy to the registrar (or designated official). That copy would be used to verify the electronic tally. The question becomes, what to do if there is a discrepancy? It really angers me that such basic and simple methodology is not even being discussed, much less that Diebold is pawning off an approach that is completely unverifiable, and that politicians are buying into it. Neil |
It isn't a simple as just print a receipt. If you print before the
voter presses the final button and the voter changes their mind, the receipt and the machine do not agree. If you print a second receipt then you have two receipts for one voter. If the receipt and the machine disagree and the voter presses the final button anyway, which one is the true vote? There is no way to count the receipts by hand so now you need a entire new set of machines to count receipts which brings you back to many of the problems with punch cards. "Neil Gould" wrote in message news ![]() I agree with you. Further, the percentage of sampled machines should not be "small", as in 1 or 2%, but significant, as in at least one machine from each precinct. The paper proofs should be printed at the same time, with the voter inspecting both for accuracy, and then give one copy to the registrar (or designated official). That copy would be used to verify the electronic tally. The question becomes, what to do if there is a discrepancy? It really angers me that such basic and simple methodology is not even being discussed, much less that Diebold is pawning off an approach that is completely unverifiable, and that politicians are buying into it. Neil |
Recently, sfb posted:
It isn't a simple as just print a receipt. If you print before the voter presses the final button and the voter changes their mind, the receipt and the machine do not agree. If you print a second receipt then you have two receipts for one voter. If the receipt and the machine disagree and the voter presses the final button anyway, which one is the true vote? Why would a receipt *ever* be printed before the "final" button is pressed? At that point, printing them in duplicate is not a problem. There is no way to count the receipts by hand so now you need a entire new set of machines to count receipts which brings you back to many of the problems with punch cards. Why couldn't receipts be counted by hand? As a method of verification, the task isn't all that large. Still, if the receipts followed a standard layout, they could be counted by machine quite easily. Regards, Neil |
![]() "Neil Gould" wrote in message ... Recently, sfb posted: It isn't a simple as just print a receipt. If you print before the voter presses the final button and the voter changes their mind, the receipt and the machine do not agree. If you print a second receipt then you have two receipts for one voter. If the receipt and the machine disagree and the voter presses the final button anyway, which one is the true vote? Why would a receipt *ever* be printed before the "final" button is pressed? At that point, printing them in duplicate is not a problem. There is no way to count the receipts by hand so now you need a entire new set of machines to count receipts which brings you back to many of the problems with punch cards. Why couldn't receipts be counted by hand? As a method of verification, the task isn't all that large. Still, if the receipts followed a standard layout, they could be counted by machine quite easily. Additionally, just because a receipt is printed it does not mean that the vote recorded is the same as printed on the receipt (screen says vote for "X", receipt says vote for "X", record vote as a vote for "Y"). It appears there is no way to insure fraud is not a part of the voting process. The only thing that can be done is try and minimize the fraud. |
Receipts can be easily faked also. Even with the bat codes on them, if
let's say 6 million were faked, are we going to try to recertify 6 million receipts by hand? |
"Tom Conner" wrote in message
nk.net... Additionally, just because a receipt is printed it does not mean that the vote recorded is the same as printed on the receipt True. That's why a hand-recount is needed of some percentage of the paper ballots, as an audit of the machine-counted votes. [...] It appears there is no way to insure fraud is not a part of the voting process. As long as human beings are involved at any part of the process, there will be the potential for fraud. The problem is that currently, the potential for fraud is VASTLY higher than it should be. The only thing that can be done is try and minimize the fraud. Indeed. So, let's do that thing. ![]() Pete |
On Thu, 29 Dec 2005 18:10:26 GMT, "Neil Gould"
wrote in : : Why couldn't receipts be counted by hand? As a method of verification, the task isn't all that large. Still, if the receipts followed a standard layout, they could be counted by machine quite easily. What method would you employ to assure that the receipts are not forgeries? |
Aircraft Spruce: Abused Customers and Fourteen More Angry Comments -- More to Come | jls | Home Built | 2 | February 6th 05 08:32 AM |
If true, this makes me really angry (Buzzing Pilot kills 9 year-old son) | Hilton | Piloting | 2 | November 29th 04 05:02 AM |
millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 5th 04 11:14 PM |
JEWS AND THE WHITE SLAVE TRADE | B2431 | Military Aviation | 16 | March 1st 04 11:04 PM |
Enemies Of Everyone | Grantland | Military Aviation | 5 | September 16th 03 12:55 PM |
