Bob Moore wrote:
"M. J. Powell" wrote Except ICs instead of valves? It wasn't the size of the electronics, but rather the large antenna array required of the VOR system. A VOR antenna must be permanently aligned to the earth, something not possible with such a large array onboard a ship. The TACAN system operating on a different principle than VOR solved the size and alignment problems. Bob Moore Can you either explain how a TACAN works or provide a reference? Thanks. |
In message , Bob Moore
writes "M. J. Powell" wrote Except ICs instead of valves? It wasn't the size of the electronics, but rather the large antenna array required of the VOR system. A VOR antenna must be permanently aligned to the earth, something not possible with such a large array onboard a ship. The TACAN system operating on a different principle than VOR solved the size and alignment problems. Right. Thank you, again. Mike -- M.J.Powell |
Bob Moore wrote:
"M. J. Powell" wrote Except ICs instead of valves? It wasn't the size of the electronics, but rather the large antenna array required of the VOR system. A VOR antenna must be permanently aligned to the earth, something not possible with such a large array onboard a ship. The TACAN system operating on a different principle than VOR solved the size and alignment problems. The writeup at http://www.radarpages.co.uk/mob/nava...can/tacan1.htm has already been mentioned. Aside from size and earth orientation, TACAN has two advantages over VOR for shipboard use. 1. TACAN uses a bearing reference direction of due east. For a shipboard installation, that means a properly corrected compass reference and a means of correcting the antenna orientation. 2. TACAN incorporates a ranging transponder (DME) in the transmitter site. The aircraft interrogates the system, and the site's transponder responds after a fixed 50 microsecond delay. The site's azimuth and range are typically displayed on a combined bearing/distance/heading indicator. The combination of bearing and range display clears up any of the to/from confusion possible with VOR sites. | George Ruch | "Is there life in Clovis after Clovis Man?" |
Bob Moore wrote:
A VOR antenna must be permanently aligned to the earth, Why? Why not have a heading indicator (or DG) to drive the 'angles' (i.e. phase) it sends out? Hilton |
M. J. Powell wrote:
Is TACAN still in use? I worked on it briefly in 1956 when I was in the RAF. I remember from a recent history or discovery channel program that air-to-air tacan is still used for aerial refueling operations. Here's a page about it from Rockwell: http://www.rockwellcollins.com/ecat/gs/TCN-550_Tacan.html - Ray |
Ray wrote:
M. J. Powell wrote: Is TACAN still in use? I worked on it briefly in 1956 when I was in the RAF. I remember from a recent history or discovery channel program that air-to-air tacan is still used for aerial refueling operations. Here's a page about it from Rockwell: http://www.rockwellcollins.com/ecat/gs/TCN-550_Tacan.html When I was stationed in Thailand, I also heard about A-A mode being used in a two-ship formation when a major system (attack radar or INS) failed. The aircraft with working systems would lead, and the aircraft with the failed system would follow the leader. As I understand it, buddy bombing was possible, but may not have been all that accurate. | George Ruch | "Is there life in Clovis after Clovis Man?" |
Wherewhendid dual speed on ias come from | Gene Whitt | Instrument Flight Rules | 7 | October 27th 05 12:31 AM |
Idents on VOR+DME if one of them is inop | Robert M. Gary | Instrument Flight Rules | 14 | January 24th 05 10:10 AM |
KRMN ILS 33- Interesting Approach | Brad Z | Instrument Flight Rules | 11 | May 21st 04 10:53 PM |
