![]() "Stephen H" wrote in message ... older Dodge Caravan (grand?) , but the round body style Late 90's I think 2.4 4cly, it held the upper motor mount together (pointing the same direction the cam did) Didn't actually have to remove it; and according to another tech it's a Chrysler special tool. I wouldn't buy a set yet! Oh, the BF Vise grip tool, or the BFH and cold chisel? Sounds like what I would end up using! g Of course, then there is the fire ax or the sawz-all! -- Jim in NC |
Morgans wrote:
"Stephen H" wrote in message ... older Dodge Caravan (grand?) , but the round body style Late 90's I think 2.4 4cly, it held the upper motor mount together (pointing the same direction the cam did) Didn't actually have to remove it; and according to another tech it's a Chrysler special tool. I wouldn't buy a set yet! Oh, the BF Vise grip tool, or the BFH and cold chisel? Sounds like what I would end up using! g Of course, then there is the fire ax or the sawz-all! BF oxy acetylene, LF dremel ![]() |
On Wed, 04 Jan 2006 05:53:00 GMT, "Stephen H"
wrote: Working on Dodge caravan the other day, couldn't get my 19mm to fit and the 20 was too large. Went to the sae set, nothing would fit.. Looked real hard at the nut... I'll be dammed a 5-point nut. Where the hell did that come from. Probably needed a Torx socket. These are becoming more common slowly. I know that Briggs and Techumseh are using them on carb bolts now. Wayne Cook Shamrock, TX http://members.dslextreme.com/users/waynecook/index.htm |
wrote: Looked real hard at the nut... I'll be dammed a 5-point nut. Where the hell did that come from. Fire hydrant ? |
Leatherman Multitools
My wave has a 5 point security bit Andy Dingley wrote: On Wed, 04 Jan 2006 05:53:00 GMT, "Stephen H" wrote: Looked real hard at the nut... I'll be dammed a 5-point nut. Where the hell did that come from. Fire hydrant ? |
On Wed, 04 Jan 2006 11:46:06 -0500, Brent Philion
wrote: Andy Dingley wrote: On Wed, 04 Jan 2006 05:53:00 GMT, "Stephen H" wrote: Looked real hard at the nut... I'll be dammed a 5-point nut. Where the hell did that come from. Fire hydrant ? Leatherman Multitools My wave has a 5 point security bit 5-point bolt heads (and other strange and wonderful fastener designs) are often found holding things closed that they don't want the average induhvidual off the street to get into, the Leatherman Tools are one good example They'll fix it for you for free if you send it back for service, so you don't need the special 5-point Tamper Torx driver. Controls unauthorized mods that could cause injuries. Or things that aren't supposed to come apart at that point, like those motor mounts. Sounds like that's for the 'backup bolt' on the mount, meant to keep the engine from falling totally out of the car if the rubber mount fails - and there's always some fool who will remove the bolt "To save weight" and then act surprised when the engine falls on the freeway at speed... (And then they'll sue the manufacturer of the 'defective' motor mount - and win. Look up "Chutzpah" in the dictionary.) Things like the lids of Power Utility manholes and handholes, where there are seriously hazardous voltages lurking inside... Which is the reason I need to get a few of those 5-point sockets, so when I get called out on an outage I can confirm whether or not it's dead in there. And secure the lid properly if someone else didn't. It's one of those "Kids, Don't Try This At Home!" things. Occasionally (two small associations we service) they tap HOA owned streetlight poles straight from the Edison handhole with a simple inline fuseholder and pay a flat-rate for the power - which is cheaper than installing a meter pedestal and paying the monthly minimum for a meter. And I very occasionally need to get in there and pull the fuse so I can work on the pole without the ahem excitement factor. I do my darnedest to make sparks only when I'm welding. On purpose type welding. With a MIG torch in my hand. Oh heck, you get it... ;-P -- Bruce -- -- Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop Electrician for Westend Electric - CA726700 5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545 Spamtrapped address: Remove the python and the invalid, and use a net. |
That Makes sense.
Steve "Bruce L. Bergman" wrote in message ... On Wed, 04 Jan 2006 11:46:06 -0500, Brent Philion wrote: Andy Dingley wrote: On Wed, 04 Jan 2006 05:53:00 GMT, "Stephen H" wrote: Looked real hard at the nut... I'll be dammed a 5-point nut. Where the hell did that come from. Fire hydrant ? Leatherman Multitools My wave has a 5 point security bit 5-point bolt heads (and other strange and wonderful fastener designs) are often found holding things closed that they don't want the average induhvidual off the street to get into, the Leatherman Tools are one good example They'll fix it for you for free if you send it back for service, so you don't need the special 5-point Tamper Torx driver. Controls unauthorized mods that could cause injuries. Or things that aren't supposed to come apart at that point, like those motor mounts. Sounds like that's for the 'backup bolt' on the mount, meant to keep the engine from falling totally out of the car if the rubber mount fails - and there's always some fool who will remove the bolt "To save weight" and then act surprised when the engine falls on the freeway at speed... (And then they'll sue the manufacturer of the 'defective' motor mount - and win. Look up "Chutzpah" in the dictionary.) Things like the lids of Power Utility manholes and handholes, where there are seriously hazardous voltages lurking inside... Which is the reason I need to get a few of those 5-point sockets, so when I get called out on an outage I can confirm whether or not it's dead in there. And secure the lid properly if someone else didn't. It's one of those "Kids, Don't Try This At Home!" things. Occasionally (two small associations we service) they tap HOA owned streetlight poles straight from the Edison handhole with a simple inline fuseholder and pay a flat-rate for the power - which is cheaper than installing a meter pedestal and paying the monthly minimum for a meter. And I very occasionally need to get in there and pull the fuse so I can work on the pole without the ahem excitement factor. I do my darnedest to make sparks only when I'm welding. On purpose type welding. With a MIG torch in my hand. Oh heck, you get it... ;-P -- Bruce -- -- Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop Electrician for Westend Electric - CA726700 5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545 Spamtrapped address: Remove the python and the invalid, and use a net. |
wrote: Working on Dodge caravan the other day, couldn't get my 19mm to fit and the 20 was too large. Went to the sae set, nothing would fit.. Looked real hard at the nut... I'll be dammed a 5-point nut. Where the hell did that come from. The electric company uses them here to secure the lids on in-ground boxes. Regular 1/2" bolt with pentagon head. |
You weren't trying to loosen the hood ornament were you? ;-)
Working on Dodge caravan the other day, couldn't get my 19mm to fit and the 20 was too large. Went to the sae set, nothing would fit.. Looked real hard at the nut... I'll be dammed a 5-point nut. Where the hell did that come from. -- Stephen W. Hansen ASE Certified Master Automobile Technician ASE Automobile Advanced Engine Performance ASE Undercar Specialist http://autorepair.about.com/cs/troub...l_obd_main.htm http://www.troublecodes.net/technical/ wrote in message roups.com... four point (square) sockets (and/or wrenches) who makes them, who retails 'em? |
Adding a lifting point. | [email protected] | Home Built | 1 | March 8th 05 03:05 PM |
A Question For Real Airline Pilots | Blue | Simulators | 34 | September 6th 04 01:55 AM |
flight training - 100nm night flight requirement | Jonathan | Piloting | 36 | May 11th 04 07:34 PM |
How fast should an ADF point? | Ben Jackson | Instrument Flight Rules | 6 | November 21st 03 03:50 AM |
Reaming needed on aft wing attach point. | Boelkowj | Home Built | 0 | November 7th 03 01:30 AM |
