Be warned that spray painting is more than just a skill, it is an art.
You will need to practice before you attempt to paint that cowl. There are numerous paint guns available. Try Northern Tool. They have numerous outlets and a web site. You will need a device to separate atmospheric water from the compressed air, also. Also, the regs require weighing and rebalancing control surfaces. ( a bunch of ) So be cautious what you tell your mechanic at the next annual.. Again, Imron is dangerous stuff. Had a pilot at the field sent to the hospital for two weeks for not using an aspirator while spraying in a hanger. It can be absorbed through the skin and disrupt the nervous system. Almost as bad a nerve gas. Dupont has a second tier product paint, Chromacolor, a binary paint which is typically used on autos. I do not have any experience with this product. |
the hospital for two weeks for not using an aspirator while spraying in a hanger. It can be absorbed through the skin and disrupt the nervous system. Almost as bad a nerve gas. I do believe you mean respirator, not aspirator. Specifically, a pressure hood. No part of your body should be exposed when using IMRON. That means wearing a pressure hood, set of coveralls, gloves and boots. THEN tape the wrist and ankles to seal. |
I use Imron outside and stay up breeze from the spray with no problems.
Update on new paint job and leather seats - Trip back home | Longworth | Piloting | 6 | November 21st 05 06:52 PM |
Thinning paint | Michelle P | Owning | 12 | June 4th 05 12:37 PM |
Instrument Panel Paint | [email protected] | Owning | 0 | May 1st 05 02:54 PM |
Trailer paint removal | Chris Davison | Soaring | 13 | September 3rd 04 10:42 PM |
Choice of Paint for use over Copper foil Antennas | Charlie Precourt | Home Built | 1 | December 2nd 03 02:51 AM |
