Why is wind directon expressed as "FROM"?
Old January 6th 06, 05:39 AM posted to rec.aviation.piloting
Default Why is wind directon expressed as "FROM"?
On Fri, 06 Jan 2006 02:15:53 GMT, "Steven P. McNicoll"
wrote in
. net::
"Larry Dighera" wrote in message
So the placement of the pivot point is immaterial?
Well, where the pivot point is placed would determine
which side of the pivot point had the greater surface area.
I would think placement of the pivot point would determine the
arm/moment of the moveable vane. Either end could have greater surface
area than the other, but the end of the vane with greatest moment
(surface area * arm) will trail in the breeze.
Old January 5th 06, 10:43 PM posted to rec.aviation.piloting
"Jose" wrote in message
I'd say the opposite - the vane is designed that way because we're
interested in where the hot air came from.
One could easily design a vane that worked the other way.
Most weather vanes I've seen are of the simple arrow type. A weather vane
of that type that pointed the other way would be counterintuitive, the arrow
would be "flying" backward.
Old January 5th 06, 10:49 PM posted to rec.aviation.piloting
vane of that type that pointed the other way would be
counterintuitive, the arrow would be "flying" backward.
In which case is a windsock confusing?
If we used standard vectors, the tail could be arrow shaped, lose the tail
and save 50% in parts costs
Old January 5th 06, 11:26 PM posted to rec.aviation.piloting
"JohnH" wrote in message
None that I can think of.
If you lose the tail you lose the ability to estimate wind speed from the
windsock.
Old January 6th 06, 10:45 AM posted to rec.aviation.piloting
On Thu, 05 Jan 2006 17:49:51 GMT, Jose
But they didn't. All weather vanes point into the wind. So those New
Hampshire farmers must have been onto something, since their cast-iron
horses, carriages, sailboats, kiddies etc all point in the direction I
should land the Cub.
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
In Search of Lost Time: www.readingproust.com
Old January 6th 06, 02:25 PM posted to rec.aviation.piloting
Then why don't airports use weathervanes instead of windsocks?
Old January 6th 06, 02:46 PM posted to rec.aviation.piloting
Wouldn't a wind tee be considered a weathervane?
Peter
Old January 6th 06, 02:53 PM posted to rec.aviation.piloting
Windsocks are a bit more useful to a pilot, they provide an indication of
wind direction and speed. Weathervanes provide only an indication of wind
direction.
Old January 6th 06, 03:05 PM posted to rec.aviation.piloting
In article . net,
direction.
I used to have a weathervane in the shape of a duck with wings that spun
around. You could get a good feel for how fast the wind was blowing by how
fast the wings were spinning around.
One day, after a storm, I discovered that the spinning wings could also be
used to estimate peak gust strength by their absence the next day.
Old January 7th 06, 01:11 AM posted to rec.aviation.piloting
Some do.
Geoff
the sea hawk at wow way d0t com
Spell checking is left as an excercise for the reader.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
Headwinds, always Paul kgyy Piloting 36 June 9th 05 01:05 AM
LX4000 wind calculation AttentionLEcureuil Soaring 2 June 23rd 04 04:33 AM
