Speaking of being toasty warm, the last trip I made in my Aztec was at the
first of January at night with the OAT around 20 degs F. The heater was not working. After a 6 hour round trip in that, even with heavy clothes, jackets, gloves and blankets, we were miserable. It is hard to tune the radios with ski gloves, so my right hand was in and out of the glove a lot, and the result was numb fingers. That finally provided the motivation needed to get the heater working. It is a Southwind Model 940DB12, which is rated at 15,500 BTU/hr on low and 27,500 BTU/hr on high. I used to wonder if it were even capable of keeping the cabin warm, but after looking at my old thermo book and doing a little calculation, I determined that if a heater that size can't keep the Aztec cabin warm, something is really, bad wrong. Anyway, after studying the service manual on the heater for a while to understand how it was supposed to worked and doing a little trouble shooting, it was revealed that the heater overhaul shop had incorrectly wired the heater. I don't know how it ever passed a burn test. I'll bet it didn't. It would light from the prime fuel charge, open both fuel values, burn very rich and smoke migthly until the high temperature thermostat opened which closed both fuel values. Only the high heat fuel value was suppoed to be controlled by the thermostat. Controlling both fuel values with the thermostat caused combustion to stop once the heater exceeded the 240 deg F outlet temperature. Once the flame was out, the heater had to be turned off, allowed to cool, and reprimed before it would ignite again. It was supposed to ignite, burn on low, and only open the second fuel value if the operator selected high heat. In high heat, the increased fuel flow requires additional combustion air for the proper mixture. Proper combustion airflow depends on an increased pressure head from the slipstream. The airplane needs to be flying to provide this 1" to 2" of water pressure head in the intake. There is a very small ram air scoop on the air intake for this purpose, which has been "calibrated" with a couple of small holes drilled into the flage, at least I'm guessing that what the small holes are for. This is why the airplane's Approved Flight Manual advices against using high heat during ground operatiions and cautions that doing so will result in excessive smoking from the heater exhaust. Once it was wired to match the wiring diagram in the service manual, it works like a champ. We have heat!!!!!!! I'm still thankful for you guys educating me about C&D and I will use them for parts and/or a rebuilt should the old Southwind hang it up, but for now, it is going strong. Now I need to add a CO detector in the cabin to warn is the heat exchanger springs a leak. I also need to get motivated to relace the side windows like. I need Jim Burns for my partner :-) Ronnie "Denny" wrote in message oups.com... That's true Jim... I am toasty warm and heven't even run the heater on the highest setting yet. Subzero wx is comin so I will have the chance I'm sure... The carb seems to be running just fine, now that we put all the parts inside that the designer intended... denny |
We have heat!!!!!!!
Congrats!! ![]() it just takes some patience to figure out what's going on. Am I remembering correctly that you are in TX? There's also a well known heater shop in Dothan AL, http://www.haroldhaskinsinc.com/pages/1/index.htm I also need to get motivated to relace the side windows like. I need Jim Burns for my partner :-) The side windows are easy and you can trim them to fit with a belt sander. Just clean everything up real good before installing so you get a good bond if you use silicone. Clean up the excess while it's wet, you'll never get it off without damage if you let it dry. You can also use the original black window seal goo. We bought LP Aero windows, 1/4 which required a 337, or you can go with 3/16 or 1/8" and thermopanes from Great Lakes without a 337. Jim |
Yes, I'm Austin, TX.
Matter of fact, I didn't want to mention any names, but since you brought it up, that heater shop in Dothan, AL is the one who's sticker is on the heater and who's signature is in the log books as having done the last overhaul. Hopefully their work on testing the heat exchanger for leaks was better than their work on the wiring. Maybe the tech who did the wiring was having a bad hair day. Everybody makes mistakes, but I would have expected those errors to be caught during the burn and post installation test. But who knows, maybe the heater left their shop propely wired and adjusted and the mechanic in the field who reinstalled the heater decided he needed to move a few wires around to make it work better. I saved your original post about installing the side windows. I need to tack that project. One of our windows has a crack in the inside pane. Maybe when the weather gets too bad to fly here in Texas, I'll tackle that project :-) Ronnie "Jim Burns" wrote in message ... We have heat!!!!!!! Congrats!! ![]() simple, it just takes some patience to figure out what's going on. Am I remembering correctly that you are in TX? There's also a well known heater shop in Dothan AL, http://www.haroldhaskinsinc.com/pages/1/index.htm I also need to get motivated to relace the side windows like. I need Jim Burns for my partner :-) The side windows are easy and you can trim them to fit with a belt sander. Just clean everything up real good before installing so you get a good bond if you use silicone. Clean up the excess while it's wet, you'll never get it off without damage if you let it dry. You can also use the original black window seal goo. We bought LP Aero windows, 1/4 which required a 337, or you can go with 3/16 or 1/8" and thermopanes from Great Lakes without a 337. Jim |
![]() The thing that annoys me about all this, $2,000 later, is that the clapped out mags have been starting immediately and running like gang busters... I can hardly wait to see how the new mags run... denny That was a good write up, Denny. My problem with AS is that they don't list shipping charges or calculate them for you on their website. I ordered a wingtip light bulb for the Cherokee a few days before Christmas. It cost around $14.00. I knew shipping UPS or FEDEX would be very expensive so I chose USPS knowing that the Holidays would slow down delivery. It arrived yesterday, so it took nearly two weeks. The shipping charge for the $14 light bulb was $8.80. Their website offers a free catalog with free shipping and I ordered that as well. I wonder if they didn't charge me shipping on both items? Joe Schneider 8437R ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
ALL shipping has become expensive... I try to batch my orders so I hit
their minimum dollar amount for "free" shipping without going over the weight limit... Not possible with the mags, so I got hit with the freight charges for the weight... That's life I guess... denny |
![]() Denny, looks like you and I has similar annuals! This year both my mags where replaced with new from aircraft spruce I went with slick conversion kit after all core credits & rebates my total cost for Plugs, Mags & Harness was about $1,025 + Labor "Denny" wrote in message oups.com... The dreaded annual condition inspection time has arrived... Fat Albert is currently perched upon the wing jacks pending gear swing testing... I have put 500 hours on the fat boy over the past three years and one of the topics this year was the mags.... I had gone to the yellow newspaper and priced the various Bendix magneto parts... Steve, the mechanic, had the mags on the bench when I arrived... After looking at the disassembled parts I got that familiar (to airplane owners) sinking sensation (much like a big down draft on short final)... It was clearly visible that the mags were in need of significantly more than points and condensor... Bearing balls were significantly out of round, the distributors were burned and pitted, one rotor had been rubbing on the stator and was scarred, one coil had been arcing, etc...After spending an hour (another $55 in labor) jawing about the mags, looking in Steve's parts catalogs (going back to the Wright Bros.), and making phone calls we came to several conclusions... First, is that the mags needed total overhauls - actually more like a sledgehammer massage... Second, that two of the mags were a collection of random parts from various fly-market magnetos, not all of which parts were from dash numbers called for by Lycoming... One case was -30, one was missing the tag, one was a -29, and one was a -11... The plug wires are 4 years old and in fine shape... The cost of Steve's time and parts to rebuild these mags was not economical... We tossed around the idea of going to Slicks, but that mean't buying new wires, which were not needed... In the end we opted for a set of rebuilt mags from AVIAL by way of Aircraft Spruce... First phone call to AS: I got a young male voice... Told him what I needed, rattling off the 10 number... Got a long silence in return followed by a plaintive request , 'did I know what page number in the catalog that was on'... I advised him I wasn't looking at a catalog and I suggested that he type 'magneto' into his computer screen followed by the 10 number I gave him and see what turned up... Long story short, after 5 agonizing minutes he finally located the magnetos and announced that the -30 mags were special order only... At this point it was clear he was in over his head and I did not believe anything he said, told him I would think about it and hung up... Second phone call: I counted to 20, slowly to allow Forrest Gump there to be on the phone with someone else, and redialed AS... The bubbly, blond, southern bimbo answers... I can smell the fresh nail polish clear through the phone, as she is waving her hands to dry the gleaming red lacquer.. The smooth southern drawl would make Dolly Parton jealous.. I need some magnetos, I announce, with dread in my heart... Bendix or Slick, y'all, she fires back... This catches me off guard for a second... Bendix, I admit, stumbling over my tongue.. Do you have the 10 number she asks... I rattle off the -29 one... How many, she asks... Two, I admit... Very good sir, those are the non impulse mags, they are in stock and we can ship this afternoon... Do you need any impulse mags... Jeez, this girl is giving me whiplash she's so quick... I rattle off the -30 number and ask for two - holding my breath about the special order schmozzle... They are in stock and we can ship this afternoon... What else kin I hep you with, sir... At this point we had been engaged for roughly 90 seconds and I was already thinking of asking her to marry me, but I suspected that my wife would object... Instead we settled for my credit card number and a promise that they would ship with the 6 o'clock untied parcel that very day... "Byeee, y'all have a good un.", she chirps and is gone... The thing that annoys me about all this, $2,000 later, is that the clapped out mags have been starting immediately and running like gang busters... I can hardly wait to see how the new mags run... denny |
Uhh, seems like the number she quoted to me, was roughly $355 per mag
and $200 core deposit... I assume my cores will be accepted as they were running on an engine when removed but you know what 'assume' can do Even with the $800 back from cores, it's going to be $1600 or so in the end with labor and shipping... Still, that's a 1200-1400 savings over all new... Actually, I like Bendix mags.. Parts can be had everywhere... And, I've been flying behind them for 60+ years... Looks like there will be a delay in getting the ship back... I ordered the mags at 4PM on Wednesday and they were in my hands at noon on Friday... Not bad for UPS Brown from Ga to Mi...So, late Friday afternoon I delivered them to Steve... While there Steve and I swung the gear, and then I sat around and watched while he greased the wheel bearings, reassembled the wheels and brakes, etc... Actually, he dropped several hints that I could help if I wanted... Sittng there in a white shirt and tie, I simply grinned and watched while he rolled his 260 pounds around on the floor like a beached whale... I did help get it off the jacks... Then he dropped the bomb... The FAA is going to be in the shop on Monday, Tuesday, and Wednesday for his new Part 135 certification of the books, the shop, the Chief pilot, and the Aztec... I informed Steve that my airplane was NOT going to be in the shop for three days, with the logs laying on the wing, while the FAA was prowling around desperately looking for someone or something to violate... So, he WOULD work Saturday and Sunday installing the mags, buttoning up the inspection plates, dye checking the rudder hinges, test run, etc., etc., etc. and give my plane back to me so I could get it locked away in a private hangar... He about cried... Said it was going to take him all weekend to finish all the squawks on the Aztec that miraculously showed up on the final test flight by his Chief Pilot... After a bit of shouting and swearing, he allowed that he could get Fat Albert out of the shop and into the box hangar next door, which is not subject to the 135 inspection... I was still growling like a Grizzly with a bad tooth, but it is the best I can negotiate... denny and Fat Albert |
"Denny" writes:
The plug wires are 4 years old and in fine shape... The cost of Steve's time and parts to rebuild these mags was not economical... We tossed around the idea of going to Slicks, but that mean't buying new wires, which were not needed... In the end we opted for a set of rebuilt mags from AVIAL by way of Aircraft Spruce... These are the kind of GA stories that make me cry. Thirty five years ago, I remember changing the points and rotor in a Beetle. That was the last mechanical ignition I've seen. I junked my 2nd Datsun 210 this year. From 1979 on, those two were all I'd driven. And while I'd acquired and kept a spare ignition module; I'd never used one. (Nor the spare starter....) And while the Beetle was a PITA to start in cold damp weather with a weak battery... my neighbor just donated away his +10yo Caddy Coupe de Bismarck. After spending ~$10K on an engine rebuild a few years ago {gag!} he finally gave up after the ?air? boost part of the suspension failed & the dealer wanted $3K more to fix it. It sat there for 2+ years because he really didn't want to let it go; all the new ones (inc. his) were smaller and he kept hoping it could be fixed... Finally his spouse ordered it gone. The flatbed from the 501c3 couldn't hook it at the angle it was parked, so he and I used my "battery boiler" charger and my welding cable jumpers. It fired up on a squirt of ether; and as soon as the gas made it up front, kept going. We managed to back it into the alley despite the fact he'd left the parking brake on and the rear wheels were seized. (A little dish soap & H2O helped...) I keep hoping that someone somehow will figure out a way to move some of the massive tecnology improvements we use (and ignore) daily in our cars into the fleet; but I sure don't know what that route is... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
David Lesher wrote:
I keep hoping that someone somehow will figure out a way to move some of the massive tecnology improvements we use (and ignore) daily in our cars into the fleet; but I sure don't know what that route is... Yeah. I heard an ad on the radio about a shop that had the gear to read the computer chips for diagnosis in cars. That set me thinking about the diagnosis technique frequently used with aircraft; replace parts until something works. It seems to me that it wouldn't be hard to get the FAA to sign off on at least a diagnostic chip. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
George Patterson" wrote in message
news:ZK0wf.23428$uy3.5082@trnddc08... David Lesher wrote: I keep hoping that someone somehow will figure out a way to move some of the massive tecnology improvements we use (and ignore) daily in our cars into the fleet; but I sure don't know what that route is... The technology got into cars because the government mandated fuel economy and emission improvements. It shouldn't be hard to figure out what it will take to get it into aircraft. In any case, there are exactly two things "wrong" with aircraft engines. The spark timing is fixed and the mixture control is in the hands of the pilot. And you can't do anything about the first problem until you fix the second. Yeah. I heard an ad on the radio about a shop that had the gear to read the computer chips for diagnosis in cars. That set me thinking about the diagnosis technique frequently used with aircraft; replace parts until something works. It seems to me that it wouldn't be hard to get the FAA to sign off on at least a diagnostic chip. Right. Now a mechanic just replaces parts until the fault codes go away... It's nearly impossible to narrow things down to just one part, so even with diagnostic codes to point the way, mechanics still tend to replace the easy stuff first. For example if you get a "oxygen sensor not switching" code, 9 times out of 10, the mechanic will replace the sensor. Then, only when that doesn't solve the problem, will they will actually start to look for the cause of the mixture problem (vacuum leak, etc.). Of course, there are those who will just replace the sensor again. And again. And again... After a few tries, they then complain that there is something wrong with the diagnostic software. FWIW, I write algorithms that do air fuel control and diagnostics at one of the larger automobile manufacturers. -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
20 Nov 2005 - Today's Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | November 20th 05 09:43 PM |
2005 ANNUAL PASCO SEMINARS, BANQUET AND AWARDS PRESENTATIONS | Marc Ramsey | Soaring | 0 | November 8th 05 02:36 AM |
Oshkosh 2005 Redux | Jay Honeck | Piloting | 17 | August 6th 05 07:14 AM |
Oshkosh 2005 Redux | Jay Honeck | Home Built | 13 | August 5th 05 04:35 AM |
Oshkosh 2005 Redux | Jay Honeck | Owning | 13 | August 5th 05 04:35 AM |
