Nasa Icing courses
Old January 8th 06, 06:59 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Default Engine Making Metal (Was: Nasa Icing courses)
Jim Macklin wrote:
There is also the fact that the oil pump is at one end of
the engine and the cam shaft lobe that fails is probably at
the other [a guess] and the oil takes some time to reach the
journal and establish a full oil bearing.
Add a little sludge, maybe some cold oil and an over-revved
engine, and you get cam lobe /journal failure or the lifter.
Pilot error due to poor operation.
This is on an O-540. The cam lobe that wore is in the center of the shaft.
So how long is too long to sit? The longest my airplane sat between
flights since the O/H was one stretch of 7 weeks while it was in the
shop for corrosion repair on the belly. Second longest was also in the
shop for 4 weeks for a new interior. Other than that it has been flown
a minimum of every 20 days.
So if it is pilot error, I am all ears as to what I can do to improve my
technique. So far, no one has been able to tell me anything I did
wrong, including Penn Yan.
Old January 8th 06, 05:14 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
"George Patterson" wrote
In the absence of some catastrophe, such as a bent pushrod, this is
generally caused by not flying enough.
Whenever I see less than 200 hours on an engine in a year, it seems like
there are tales of destruction of an engine to follow.
All of this would not be nearly as likely (it seems to me) if aircraft
engines were equipped with rollers on the cams.
Jim in NC
Old January 8th 06, 05:19 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
That describes almost every privately owned aircraft at our airport. Only
trainers routinely put on more than 200 hours per year.
Mary and I fly more than anyone at the airport, and we just barely put 200
hours on last year.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 8th 06, 05:37 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
"Morgans" wrote in message ...
snip
All of this would not be nearly as likely (it seems to me) if aircraft engines were equipped with rollers on the cams.
Jim in NC
Yes, the 'new' roller cams finally address this issue...
Old January 8th 06, 07:41 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
George Patterson writes:
"So why not build the shaft entirely of hardened steel?", I hear you cry. That's
because the harder steel is, the more brittle it becomes. The best strength
comes from this sort of lamination of hard and soft steels.
Saw a show w/ a Japanese craftsman making a sword. Two layers of
different steels. Pounded it thin; folded it over; pounded...
Many layers later, that was the sword...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old January 9th 06, 01:36 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Yep, that's a very old technique. Westerners call it "Damascus steel."
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old January 18th 06, 06:00 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
On Sun, 8 Jan 2006 19:41:33 +0000 (UTC), David Lesher
Right, but the entire blade is heat treated so that it is tempered,
rather than hard. If it were made from the kind of steel that
camshafts were cast from, it would be very brittle.
Not many camshafts, in low rpm engines, require forged camshafts,
there just isn't much pressure on them because they spin so slowly and
the valve springs aren't very stiff. But all camshafts require heat
treating the outer layer, or they'd wear out very quickly.
Corky Scott
Old January 9th 06, 05:50 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
On Sun, 08 Jan 2006 05:02:33 GMT, George Patterson
In the absence of some catastrophe, such as a bent pushrod, this is generally
caused by not flying enough. The layer of hardened steel on a camshaft is fairly
thin. Let the plane sit long enough, and rust will form. When the engine starts
again, the rust is worn away, making the thin layer of hardened steel thinner.
The worst wear points, of course, are the tips of the lobes. Once the hardened
steel wears through, the softer steel underneath goes pretty rapidly.
The automotive world tried out roller lifters a long time ago. They
would work fine in aircraft engines too. I've heard that some of the
engines built for the homebuilt market can and do incorporate roller
lifters. I even thought I read that at least one company was
intending to certify such an engine.
Corky Scott
Old January 9th 06, 05:58 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
news
generally
fairly
starts
thinner.
hardened
Corky Scott
It is not uncommon to see roller rockers on round engines.
Nasa Icing courses Jim Burns Piloting 96 February 1st 06 04:16 AM
ASRS/ASAP reporting systems - how confidential? Tim Epstein Piloting 7 August 4th 05 05:20 PM
NASA Icing Course [email protected] Piloting 3 December 28th 04 05:18 PM
About Acellerated Courses for Private Dudley Henriques Piloting 137 July 22nd 04 04:21 AM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
