Sloshing compound is failing
Old January 17th 06, 11:06 PM posted to rec.aviation.homebuilt
Default Sloshing compound is failing
Larry wrote:
Jim: I don't believe it is the MEK that is so toxic. I was an organic
chemist for many years. MEK evaporates very quickly and doesn't get
past your skin surface.
Uh, it gets past you rskin if it gets inhaled, right?
There are lots of places where the MSDS is posted, usually in .pdf
format:
http://www.palomar.edu/ehs/Chemistry...L%20KETONE.pdf
FF
Old January 13th 06, 03:10 AM posted to rec.aviation.homebuilt
Tim Hickey wrote:
I guess that it has been at least 18 years since I build the fuel
tanks for my CH-300. They are of welded aluminum construction, and
were sloshed with Randolph's sloshing sealer. The Alcohol resistant
type, if I remember correctly.
Today I drained the tanks so I can replace the fuel selector valve,
which is enjoying a small leak around the selector shaft, when I
noticed that there is a small flake of sealer that has cracked loose
from the rest. Further examination shows that there are areas that
look like small blisters are forming under the sealer. I suspect that
this is not an unusual problem, as I seem to recall that others have
had this problem also. The question I have, is what to do. It seems to
me that the tanks need to be removed, (big job), and the sealer
flushed out of there. I seem to recall that some were using MEK to cut
and remove the sealer. Does this seem like the thing to do?
Advice welcomed.
Zenith CH-300 Driver.
That has been a problem in the RV's, When I built my tanks in 1988 it
was common practice in manufacturing to use Pro Seal on the seams and
rivets and then Slosh the complete tank. Many builders had the slosh
come loose and had to remove the tanks and and clean out all of the old
slosh. Some builders just junked the tanks and built new tanks as that
was the easier way to go in some cases. It seems that any chemicals that
you use to remove the old slosh just gums it up and makes a complete
mess. I have slosh in my tanks and and am reaching the 17 year mark with
no signs of it coming loose but am keeping my fingers crossed. Van's
have found that the tanks seal just was well just using Pro Seal with
out the slosh.
Jerry
Old January 13th 06, 04:25 AM posted to rec.aviation.homebuilt
On Thu, 12 Jan 2006 19:10:04 -0800, Jerry Springer
Advice welcomed.
out the slosh.
Jerry
The tanks need to be clean and etched before sloshing so the slosh
can bite.No oxide layer. Won't guarantee it will never peel, but if
you get a good bite you won't get corrosion between the metal and the
slosh, which lifts the slosh.Most slosh kits come with an etchant for
steel. Use aluma-prep (Phosphoric acir IIRC) on aluminum tanks.
Old January 13th 06, 08:01 AM posted to rec.aviation.homebuilt
Don't use Randolph again. Ever. Use PRC 1005L Buna-N, available from Spruce.
The sealant is diluted in MEK, you pour, slosh, drain excess, let dry and
you're done, and its impervious to any fuel additives.
http://www.aircraftspruce.com/catalo.../sloshcoat.php
"Tim Hickey" wrote in message
Advice welcomed.
Old January 16th 06, 09:54 PM posted to rec.aviation.homebuilt
and
I seem to remember the Randolph site says that 912 is no longer
available. I also can't find on the 'Spruce site where PRC 1005L Buna-N
is at all alcohol resistant.
That said, has anyone tried that POR-15 stuff? Or the 'alcohol
resistant' sealer on Hirsch Auto's site? I'm looking since my RV tanks
are over 16 years old and starting to seep.
Peel plying and compound curvature [email protected] Home Built 3 August 10th 05 01:32 AM
compound curves in plywood BA-100 Home Built 58 April 13th 05 05:29 AM
Nut/thread securing compound nauga Home Built 7 April 22nd 04 07:56 AM
Cirrus' "Failing Instruments In Rapid Succession" Marco Leon Piloting 21 April 17th 04 07:47 PM
Randolph Wing Walk Compound Larryskydives Owning 7 March 7th 04 09:44 PM
