Doodles...
Old January 15th 06, 08:39 PM posted to rec.aviation.homebuilt
Default Doodles...Calibrate
Jim Williams wrote:
Richard,
What software did you use to design the aircraft? The aircraft
looks pretty damn good.
Jim Williams
Mr. Williams is obviously a man of good taste and culture.
Probably an Ace pilot and a handsome devil too...
Thanks, Jim.
CAD:
The drawings are done with Design CAD 2000. My choice.
I started with the DOS version of DC - golly - 25 or 30
years ago, now. That's a really nice package too. IMHO,
way better than Autocad V10, (which I also bought way back
when?).
Both put lines on paper, but so does a pencil.
Drawing a smooth spline, on the other hand...
There was a real cool release of this program a while back
under the name ModelCAD. It was optimized to design model
airplanes(!). Tapered wing rib patterns et al.
I haven't played with it, but I'd love to if anybody out
there has a copy.
I don't think it matters much what CAD package you pick,
drawing in 3D is a little higher hurtle to get a leg over.
Or maybe it's just a question of what you learn first?
I know kids who can do beautiful 3D, but can't project
a 3 view on paper. Dunno...
Animations:
The animations are made from CAD screen shots.
(rec.aviation.homebuilt - NOT - Industrial Light and Magic)
Draw, render, save pic,
move parts, render, save pic,
repeat until done,
or until you goof,
or just can't stand it any more.
The DC programing language is BASIC-like (rather than
Autocad's Lisp interpreter?). I haven't tried to write
anything to do this kind of animation, but it's certainly
possible.
For any kind of ILM style animation, I think you'd have to.
The elevator and aileron animations are only eight frames
each (IIRC?). Four for each side. They are simply
repeated in the reverse order to show the return paths.
They were stitched together with GifAnimator.
That part is pretty simple, really.
Analysis: (and back on topic?)
The stress calculations are provided by a custom program
(originally published in Sport Aviation a LONG time ago).
I got it working (I think), and added a menu system to
allow easy editing of wing parameters, weights, G limit,
material strength, spar width, etc.
Plug in your numbers and it grinds out the details.
One of the things it creates is a spar size table that
_is alleged_ to be minimum material dimensions to carry
the given load.
But like Stealth, I wonder if it can be trusted!
And, like Stealth, I'd like to have it evaluated by
someone who knows what they are doing before diving off
the deep end.
So...
I thought of one point that might could be calibrated -
Vans RV-9.
IIRC, RV-9 spar caps are milled from a single bar of aluminum
and stepped thicker at the root. We also know how thick the
spar shear webs are - from the plans.
All we'd need the spar dimensions from the plans,
and the following data:
Span [ft] [ ] Span Load [lb/ft] [calc]
Area [sqft] [ ] Area Load [lb/sqft] [calc]
Chord root [ft] [ ] RN root [mil] [calc]
Chord tip [ft] [ ] RN tip [mil] [calc]
Chord MAC [ft] [calc] RN mean [mil] [calc]
Aspect [#] [calc] Max CL [#.##] [ ]
Gross Wgt [lb] [ ] Stall Speed [mph] [calc]
Design G's [#] [ ]
Wing Thick[%chord] [ ] Spar Compr [psi] [ ]
Cap Width [in] [ ] Spar Shear [psi] [ ]
Any takers?
Richard
Old January 15th 06, 08:50 PM posted to rec.aviation.homebuilt
Default Doodles...
Jim Williams wrote:
Richard,
Jim Williams
I was sitting here the other night, before the phone line was
installed, taking an imaginary walk around an imaginary airport
looking at the imaginary airplanes, and I had a thought -
"I gotta get a life!"
http://home.earthlink.net/~cavelamb/!tour(1).jpg
Old January 15th 06, 08:55 PM posted to rec.aviation.homebuilt
Default Doodles...
Richard Lamb wrote:
http://home.earthlink.net/~cavelamb/tour1.jpg
unix hates me...
Old January 15th 06, 09:31 PM posted to rec.aviation.homebuilt
Default Doodles...
Richard Lamb wrote:
unix hates me...
My unix (linux) had no problem. Nice Drawing when so you start building? ;-)
John
Old January 16th 06, 12:05 AM
Jim Williams Jim Williams is offline
Junior Member
First recorded activity by AviationBanter: Sep 2005
Mr Lamb knows me very well. Your too kind, but right. Get the numbers right on the design and I'll start cuting metal .
Quote:
Originally Posted by Richard Lamb
Jim Williams wrote:
Richard,
Jim Williams
Thanks, Jim.
CAD:
when?).
there has a copy.
Animations:
repeat until done,
or until you goof,
possible.
the given load.
the deep end.
So...
Vans RV-9.
Design G's [#] [ ]
Any takers?
Richard
Old January 16th 06, 02:29 AM posted to rec.aviation.homebuilt
Default Doodles...
On Sun, 15 Jan 2006 20:55:21 GMT, Richard Lamb wrote:
Well, geeze, Richard, if you're gonna build virtual airplanes, take 'em up for a
spin instead of letting them sit in hangars....
http://www.bowersflybaby.com/MSFS/formation.jpg
Old January 16th 06, 03:00 AM posted to rec.aviation.homebuilt
Default Doodles...
Why thanks, Ron!
I'll just slip in here behind the Junkers...
http://home.earthlink.net/~cavelamb/form-up.jpg
  #28
Old January 16th 06, 03:07 AM posted to rec.aviation.homebuilt
Default Doodles...
Thanks Ron,
Right neighborly of you guys.
I'll just slip in here behind the Fokker-like thing.
http://home.earthlink.net/~cavelamb/formup.jpg
oh ****!
Throttle back!
WAY back!
prop to fine pitch!
Flaps! FLAPS!
  #29
Old January 16th 06, 03:25 AM posted to rec.aviation.homebuilt
Filled in WingSpan and GrossWeight from Vans web site.
IIRC, Van uses a 23012 airfoil?
If so, the 12% stays, and I'd guess CLmax of about 1.3.
Wing Chord?
Spar cap materials?
Span [ft] [ 28] Span Load [lb/ft] [calc]
Area [sqft] [ -- ] Area Load [lb/sqft] [calc]
Chord root [ft] [ ? ] RN root [mil] [calc]
Chord tip [ft] [ ? ] RN tip [mil] [calc]
Aspect [#] [calc] Max CL [#.##] [ ?.??]
Gross Wgt [lb] [1600] Stall Speed [mph] [calc]
Design G's [#] [ ? ]
Wing Thick[%chord] [12%?] Spar Compr [psi] [ ?? ]
Cap Width [in] [ ? ] Spar Shear [psi] [ ?? ]
Any takers?
Richard
  #30
Old January 16th 06, 05:56 AM posted to rec.aviation.homebuilt
Default Doodles...
("Richard Lamb" wrote)
Is that the Seahawk's new aerial attack I've heard about? They're going to
need it next week!
Montblack
http://www.jt-sw.com/football/pro/results.nsf
GREAT NFL (Game-by-Game) HISTORY SITE!
