Newps wrote in message news:0jTdc.112869$K91.324392@attbi_s02...
You don't take a visual approach until you're sure you can find the airport visually. You don't accept a visual until you can actually see the aiport. That constitutes being sure you can find it, UNLESS you can also see that you won't be able to see the airport between "now" and the time you land (e.g. you can see it through a hole in the overcast). Being able to see the aiport isn't enough. You need to be sure you can find it and land at it. It's very unusual, and not a good idea, to accept or request a visual approach if you're not already sure you can make it. No it's not. There's no reason to be sure you'll get the visual to request to go have a look see at the MVA. Going lower is not the same as accepting a visual approach. |
You don't accept a visual until you can actually see the aiport. You can be vectored for a visual because you don't yet see the airport but reasonably expect you might if you can get closer. Scott, I'm finding this very confusing. Can you direct me to where it says I must actually see the airport to accept a visual approach? We've been cleared for a visual approach many times when more than 10 miles from a non-towered airport w/out an IAP. The airport was definately not in sight. No vectoring was involved. Cheers, Sydney |
![]() "Snowbird" wrote in message om... I'm finding this very confusing. Can you direct me to where it says I must actually see the airport to accept a visual approach? We've been cleared for a visual approach many times when more than 10 miles from a non-towered airport w/out an IAP. The airport was definately not in sight. No vectoring was involved. Had you reported a preceding aircraft in sight that had been cleared for a visual approach? FAA Order 7110.65P Air Traffic Control Chapter 7. Visual Section 4. Approaches 7-4-3. CLEARANCE FOR VISUAL APPROACH ARTCCs and approach controls may clear aircraft for visual approaches using the following procedures: NOTE- Towers may exercise this authority when authorized by a LOA with the facility that provides the IFR service, or by a facility directive at collocated facilities. a. Controllers may initiate, or pilots may request, a visual approach even when an aircraft is being vectored for an instrument approach and the pilot subsequently reports: 1. The airport or the runway in sight at airports with operating control towers. 2. The airport in sight at airports without a control tower. b. Resolve potential conflicts with all other aircraft, advise an overtaking aircraft of the distance to the preceding aircraft and speed difference, and ensure that weather conditions at the airport are VFR or that the pilot has been informed that weather is not available for the destination airport. Upon pilot request, advise the pilot of the frequency to receive weather information where AWOS/ASOS is available. PHRASEOLOGY- (Ident) (instructions) CLEARED VISUAL APPROACH RUNWAY (number); or (ident) (instructions) CLEARED VISUAL APPROACH TO (airport name) (and if appropriate) WEATHER NOT AVAILABLE OR VERIFY THAT YOU HAVE THE (airport) WEATHER. REFERENCE- FAAO 7110.65, Visual Separation, Para 7-2-1. c. Clear an aircraft for a visual approach when: 1. The aircraft is number one in the approach sequence, or 2. The aircraft is to follow a preceding aircraft and the pilot reports the preceding aircraft in sight and is instructed to follow it, or NOTE- The pilot need not report the airport/runway in sight. 3. The pilot reports the airport or runway in sight but not the preceding aircraft. Radar separation must be maintained until visual separation is provided. d. All aircraft following a heavy jet/B757 must be informed of the airplane manufacturer and model. EXAMPLE- "Cessna Three Four Juliet, following a Boeing 757, 12 o'clock, six miles." e. Inform the tower of the aircraft's position prior to communications transfer at controlled airports. ARTS/STARS functions may be used provided a facility directive or LOA specifies control and communication transfer points. f. In addition to the requirements of para 7-4-2, Vectors for Visual Approach, and subparas a, b, c, d, and e, ensure that the location of the destination airport is provided when the pilot is asked to report the destination airport in sight. g. In those instances where airports are located in close proximity, also provide the location of the airport that may cause the confusion. EXAMPLE- "Cessna Five Six November, Cleveland Burke Lakefront Airport is at 12 o'clock, 5 miles. Cleveland Hopkins Airport is at 1 o'clock 12 miles. Report Cleveland Hopkins in sight." REFERENCE- FAAO 7110.65, Approaches to Multiple Runways, Para 7-4-4. |
"Steven P. McNicoll" wrote in message link.net...
"Snowbird" wrote in message om... Had you reported a preceding aircraft in sight that had been cleared for a visual approach? Nope. No one else going in to that non-towered airport IFR. Typical exchange would go something like "XX Center, Grumman 123 requests slow descent into Podunk" "Grumman 123, descend and maintain three thousand." (3000 will lose radar coverage and radio contact will be iffy) (around 3500 ft) "Grumman 123, radar contact lost, you are cleared for the visual approach into Podunk, no observed traffic between you and the airport, change to advisory approved, report cancellation with Flight Service" FAA Order 7110.65P Air Traffic Control Chapter 7. Visual 2. The airport in sight at airports without a control tower. That looks pretty unambiguous. My guess is what I've run into is someone who knows if he waits to clear me until I report the airport in sight, the chances that he'll have lost both radar contact and comms with me are pretty high, and has decided to simplify his life. Cheers, Sydney b. Resolve potential conflicts with all other aircraft, advise an overtaking aircraft of the distance to the preceding aircraft and speed difference, and ensure that weather conditions at the airport are VFR or that the pilot has been informed that weather is not available for the destination airport. Upon pilot request, advise the pilot of the frequency to receive weather information where AWOS/ASOS is available. PHRASEOLOGY- (Ident) (instructions) CLEARED VISUAL APPROACH RUNWAY (number); or (ident) (instructions) CLEARED VISUAL APPROACH TO (airport name) (and if appropriate) WEATHER NOT AVAILABLE OR VERIFY THAT YOU HAVE THE (airport) WEATHER. REFERENCE- FAAO 7110.65, Visual Separation, Para 7-2-1. c. Clear an aircraft for a visual approach when: 1. The aircraft is number one in the approach sequence, or 2. The aircraft is to follow a preceding aircraft and the pilot reports the preceding aircraft in sight and is instructed to follow it, or NOTE- The pilot need not report the airport/runway in sight. 3. The pilot reports the airport or runway in sight but not the preceding aircraft. Radar separation must be maintained until visual separation is provided. d. All aircraft following a heavy jet/B757 must be informed of the airplane manufacturer and model. EXAMPLE- "Cessna Three Four Juliet, following a Boeing 757, 12 o'clock, six miles." e. Inform the tower of the aircraft's position prior to communications transfer at controlled airports. ARTS/STARS functions may be used provided a facility directive or LOA specifies control and communication transfer points. f. In addition to the requirements of para 7-4-2, Vectors for Visual Approach, and subparas a, b, c, d, and e, ensure that the location of the destination airport is provided when the pilot is asked to report the destination airport in sight. g. In those instances where airports are located in close proximity, also provide the location of the airport that may cause the confusion. EXAMPLE- "Cessna Five Six November, Cleveland Burke Lakefront Airport is at 12 o'clock, 5 miles. Cleveland Hopkins Airport is at 1 o'clock 12 miles. Report Cleveland Hopkins in sight." REFERENCE- FAAO 7110.65, Approaches to Multiple Runways, Para 7-4-4. |
"Steven P. McNicoll" wrote:
FAA Order 7110.65P Air Traffic Control [...] the pilot subsequently reports: 1. The airport or the runway in sight at airports with operating control towers. 2. The airport in sight at airports without a control tower. Why the distinction? Given that the runway is part of the airport, under what circumstances could you possibly have the runway, but not the airport, in sight? |
![]() "Roy Smith" wrote in message ... Why the distinction? Given that the runway is part of the airport, under what circumstances could you possibly have the runway, but not the airport, in sight? Beats the hell outta me. |
![]() Snowbird wrote: Newps wrote in message news:0jTdc.112869$K91.324392@attbi_s02... You don't accept a visual until you can actually see the aiport. You can be vectored for a visual because you don't yet see the airport but reasonably expect you might if you can get closer. I'm finding this very confusing. Can you direct me to where it says I must actually see the airport to accept a visual approach? We've been cleared for a visual approach many times when more than 10 miles from a non-towered airport w/out an IAP. The airport was definately not in sight. No vectoring was involved. You must either see the airport or the preceding aircraft. In the real world it is only a tiny percentage of aircraft that get a visual approach and don't have the airport in sight but are following another aircraft. Here in Billings we give a lot of visual approach clearances on initial contact because the pilot calls the airport in sight 40 miles out. Are you saying that the center, for no apparent reason, is just giving you a visual approach clearance without you first calling the airport in sight? If that's the case just say "unable". Whether or not an airport has an IAP is not relavant. |
Report Leaving Assigned Altitude? | John Clonts | Instrument Flight Rules | 81 | March 20th 04 02:34 PM |
Night over water | Stuart King | Instrument Flight Rules | 43 | March 4th 04 01:13 AM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
Visual Appr. | Stuart King | Instrument Flight Rules | 15 | September 17th 03 08:36 PM |
