Airplane Batteries
Old January 23rd 06, 07:00 PM posted to rec.aviation.piloting
Default Airplane Batteries
George Patterson wrote:
RG batteries are very sensitive to being left in a partially
discharged state.
I plug in the trickle-charger every time I come back from a flight and
leave it on until I go again (lead-acid battery). Mechanic concurs that
this is a good idea. I usually fly once or twice/week. Sounds like this
would be a good thing for an RG battery as well?
Old January 23rd 06, 09:22 PM posted to rec.aviation.piloting
If you are servicing the battery more than once per year there may be
something wrong. I replace my battery every 2-3 years. The only
othertime the battery box is opened is during annual.
-Robert
Old January 23rd 06, 09:43 PM posted to rec.aviation.piloting
I've used a RG battery for 6 years and consider them a good solution to
a potentially nasty problem (leakage). I think the life is comparable
to a wet battery, and would certainly use one in your situation. The
RGs are a little more sensitive to overcharging, so have your mechanic
check the charging voltage when installing the new battery.
Crash In The Nolichucky W P Dixon Piloting 2 June 22nd 05 04:16 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 05:14 AM
Newbie Qs on stalls and spins Ramapriya Piloting 72 November 23rd 04 04:05 AM
The Best Airplane Veeduber Home Built 1 February 13th 04 05:43 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
