![]() "Morgans" writes: The GAU-8's biggest limitation besides ammo supply is that the recoil slows the A-10 quickly, [...] A myth, according to a A-10 driver here, a while back. [...] A quick visit to Newton's second law indicates a roughly 2 m/s^2 ~ 6.5 ft/s^2 deceleration due to the recoil force (10000 lbf acting on 50000 lb airplane). From a hypothetical slowish flying speed of 200 mph (300 ft/s), it would require about **20 seconds** of fire to get down to the A-10's ~115 mph stall speed. Whether that's "quick" or "a myth" depends on your point of view (and on whether I did my estimations correctly). - FChE |
![]() "Frank Ch. Eigler" wrote in message ... "Morgans" writes: The GAU-8's biggest limitation besides ammo supply is that the recoil slows the A-10 quickly, [...] A myth, according to a A-10 driver here, a while back. [...] A quick visit to Newton's second law indicates a roughly 2 m/s^2 ~ 6.5 ft/s^2 deceleration due to the recoil force (10000 lbf acting on 50000 lb airplane). From a hypothetical slowish flying speed of 200 mph (300 ft/s), it would require about **20 seconds** of fire to get down to the A-10's ~115 mph stall speed. Whether that's "quick" or "a myth" depends on your point of view (and on whether I did my estimations correctly). - FChE Did your estimation take into account that the Warthogs engines are still producing power while they shoot? |
![]() "Frank Ch. Eigler" wrote Whether that's "quick" or "a myth" depends on your point of view (and on whether I did my estimations correctly). What you failed to take into account, is that the engines keep applying thrust, and will partially negate that issue, and that the gun is nearly always fired while the airplane is in a rather steep descent (to get guns on target), so there is more force to keep the airplane from slowing down. So it appears as though it would take considerably more to slow the airplane to stall speed, and it the guns fired much longer, they would be a molten pile of metal, or out of ammo. Anyone remember how many seconds of ammo are carried? As to the engines ingesting the gun smoke, consider how much air they take in. Massive amounts. Most of that is bypassed around the engine, so only a little is burned. Even if some of the smoke is taken in, I doubt that it is enough to make the engine even stutter. -- Jim in NC |
![]() "Stubby" wrote in message . .. The chain gun on an A-10 Thunderbolt (aka Warthog) files about 3900 rounds per minute. Another way to say it: $24,375 per second of depleted uranium rounds. But don't hold the trigger for more than 18 seconds because the barrel will melt. They don't use depleted uranium, anymore. Tungsten is now the ammo of choice. -- Jim in NC |
OOPS
Had to build a new computer and when operational didn't see the original post on this group so resent. Please erase the duplicate posting ![]() Big John `````````````````````````````````````````````````` ```` On Mon, 23 Jan 2006 00:12:51 -0600, Big John wrote: New super-gun to be tested in Feb ````````````````````````````````````````````````` `````````````` By PAMELA HESS UPI Pentagon Correspondent WASHINGTON, Jan. 20 (UPI) -- Next month a new high-explosive munition will be fired in Singapore and then tested again by the U.S. Army, heralding what may be a sea change in weaponry: a gun that can fire 240,000 rounds per minute. That's compared to 60 rounds per minute in a standard military machine gun. Metal Storm Inc., a munitions company headquartered in Virginia but with its roots in Australia, has been developing a gun that can shoot at blistering speeds, albeit in short bursts as each barrel is reloaded. A Metal Storm gun of any size -- from a 9 mm hand-gun up to a machine gun size or a grenade launcher -- has no moving parts other than the bullets or munition inside the barrel. Rather than chambering a single slug for each shot - very quickly in the case of machine guns -- the bullets come pre-stacked inside the barrel and can be shot all at once, or one at a time, as the shooter decides through the electronic controls. Because there are no moving parts, the weapon is less likely to jam, and will presumably need less maintenance. Lashing many barrels together increases the number of rounds per second. Once fired, however, each spent barrel has to be reloaded. Starting in 2006 the company will demonstrate its prototypes with applicability that is especially likely to interest the U.S. military. The weapon system can be mounted on an unmanned ground combat vehicle, an unmanned aerial vehicle, and might be used as a defense against rocket-propelled grenades and mortars. Metal Storm's speed allows it to lay down a blinding wall of slugs that can intercept and pulverize incoming enemy fire, according to company CEO David Smith. As long as the grenade or mortar is fired from outside a range of about 50 meters or 162.5 feet and a Doppler radar is in use, a Metal Storm system could be an effective defense, he told UPI. Closer than that and there is just not time to react. "But if you are from 50 meters and beyond, if everything can work fast enough -- the radar -- there is enough time mathematically" to shoot down incoming fire, Smith said. At least 153 U.S. troops have been killed in Iraq by enemy rockets and mortars since the start of the war. Nearly 2,000 have been wounded. The grenade launcher barrel can also carry less-than-lethal munitions, like small bean bags, sponge grenades or smoke. On Jan. 16, the Army awarded Metal Storm a $975,000 contract to further develop its non-lethal rounds. "Our so-called competition is (the) Mk19 - grenade machine gun," Smith said. "It's enormously heavy. It takes six people to carry it into a battlefield scene. It's not mobile. "But the military has had this transition out of big system warfighting into much lighter, higher firepower that can be carried into battle by individuals or light vehicles. Our guns have no moving parts -- so they have the same amount of fire power at significantly reduced weight ratio." Metal Storm technology has been under development for about a decade, but a series of small-business innovative research contracts awarded recently by the Department of Energy and the Army mean prototypes are now being produced and demonstrated. "We are to the point we can start providing prototypes. The Army is very, very parochial in how they buy weapon systems," Smith said. "But now we can put it into an actual environment." The company is also studying whether it can mount a Metal Storm weapon on a small helicopter, particularly looking at the recoil effect from the gun. Smith said such a system - deployable down to the squad level -- could be useful in a place like Iraq, where it's a common tactic for insurgents to launch a mortar and then run. By the time soldiers on foot or in a vehicle get to the launch site, the shooters are long gone. But a UAV quickly launched can see where the shooters run to, and if a gun is on board, can shoot at them. The Australian military is testing a Metal Storm gun of its own, the Advanced Individual Combat Weapon (AICW). The AICW combines both an assault rifle and a 40 mm grenade launcher in a single unit with a common trigger, allowing the shooter to choose which munition he wants to fire without having to refit his weapon. It also allows three grenades to be fired at once, whereas one is the only option in the current generation of weapons. Metal Storm Inc. will demonstrate a high-explosive munition with a 10-meter (32.5 feet) or burst radius in Singapore on Feb. 6, Smith said, and for the Army's Picatinny Arsenal and Armament Research, Development and Engineering Center later that month. © Copyright 2006 United Press International, Inc. All Rights Reserved Want to email or reprint this story? Click here for options. advertisement Analysis: U.N. says Ivory Coast calm By WILLIAM M. REILLY UPI U.N. Correspondent 1/21/2006 7:17:00 PM -0500 The United Nations says four days of violent, orchestrated, demonstrations in Ivory Coast against the world organization and its peacekeepers appear to ... advertisement Advertising Links texas holdem poker apparel · west coast choppers · orange county choppers · Kids Murals · USB adapter · Website templates · Compare Camcorders © Copyright 2006 United Press International, Inc. All Rights Reserved |
Big John wrote:
New super-gun to be tested in Feb Wonder what the barrel life is. Seems to me that you wouldn't reload this thing, you'd replace it. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
("Big John" wrote)
New super-gun to be tested in Feb Can you crosspost to multiple newsgroups, instead of starting separate threads in separate newsgroups? Many (most?) newsreaders will cancel 'read posts' from one newsgroup to another. Thanks Gun: Didn't a couple of Mormons, out in Utah back in the late 80's, have a gun that fired .22 rounds? It was suppose to be able to shoot down a telephone pole and slice through a moving car - like a knife through warm butter. It was lightweight and inexpensive because it used .22 shells. Something like 6,000 round per minute. 100/sec. The story was featured in our daily paper - there might have been a Twin Cities connection. Montblack |
On Mon, 23 Jan 2006 13:58:57 -0600, "Montblack"
wrote: Didn't a couple of Mormons, out in Utah back in the late 80's, have a gun that fired .22 rounds? It was suppose to be able to shoot down a telephone pole and slice through a moving car - like a knife through warm butter. It was lightweight and inexpensive because it used .22 shells. Something like 6,000 round per minute. 100/sec http://www.american180.com/history/index.html check out "history" and "quad mount" TC |
wrote)
http://www.american180.com/history/index.html check out "history" and "quad mount" Yup. That's it. Thanks. At 6,000 rounds/min and 275 rounds/drums x 4 drums = 1,100 rounds 1,200 rounds would be 12 seconds of firepower. (Necessary Aviation Content) OMG!!! Someone mounted TWO of these on an ultralight! http://www.american180.com/history/index.html (From the link - Quad Mount) "ILARCO built a few quad-mounted American 180s. These "Quad 22s" fired from a tripod at a truely devastating rate of over 6000+ rounds per minute. An American 180 salesman from the New England area mounted a pair of quad American 180s on a Falcon ultralight airplane. The "Quad 22s" were placed in removable brackets of the left and right sides of the fuselage. The salesman was hoping for sales to third world governments. The individual guns could be fired in any combination. They could be fired one at a time, or one on the left and one of the right, or all eight at once. Using 275 round drums and firing the guns singly produced eighty-eight seconds of fire. In most cases, all eight American 180s would be fired at once to minimize return fire from the ground. This translates into over 12,000+ rounds per minute!" Montblack (.....running AND ducking!) |
