Martin Gregorie wrote:
Don Johnstone wrote: The version used in the UK almost universal, it is one of the few things that most people seem to agree on is C - Controls B - Ballast (includes tail dolly) S - Straps I - Instruments F - Flaps T - Trim C - Canopy B - Brakes E - Eventualities Personally, I find the final E to be in the right place, especially for winch launch. It means the last thing I push onto my brain stack is the direction to turn after a high winch launch failure. This means that if I have a launch failure its "nose down -- got approach speed -- look ahead -- (too high for land ahead)-TURN" and, because the turn direction was the last thing into my memory, its the first thing that pops out again and turning the correct way is a no-brainer. We also teach the "E" with the accent on the pilot having done the self briefing, and/or had one from an instructor. The eventualities item is just a reminder that life is what happens while we are planning other things. On a winch launch it pays , as Martin points out to know what your plan is. It appears that the mind works this way. Referring to the eventualities plan as the last thing before initiating the launch, means it is top of mind when/if something goes wrong. So - the eventualities item is not a substitute for thought, but it does help to trigger the correct information from current short term memory in the event of things falling apart. I personally have to have a couple of very different "Eventualities" plans in my head. Consider the differences. We have a field with a short section of reasonable grass, cut short and level at each end. In the middle is over 1000m of much longer grass that the wildlife continuously works on returning to it's natural lumpy state. To the west there is a near parallel 1470m long tar runway varying from 150m to 300m, closer on the downhill side than on the uphill side. Oh, I almost forgot, the 60" tree between the runways at the uphill end. Depending on whether I am flying a 27:1 high wing, skid equipped two seater built like a brick outhouse, or my Std Cirrus with its low wings and 36:1 performance, a cable break at say 200 feet will have very different actions. Which will also vary depending on which direction the wind is from, etc. You don't want to be mentally flipping through permutations when the cable breaks at an awkward height. I use the "E" to remind me, of the decisions I have made about launching this specific airplane, on this runway with the current weather. -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. |
In message , Bruce
writes Martin Gregorie wrote: Don Johnstone wrote: The version used in the UK almost universal, it is one of the few things that most people seem to agree on is C - Controls B - Ballast (includes tail dolly) S - Straps I - Instruments F - Flaps T - Trim C - Canopy B - Brakes E - Eventualities Personally, I find the final E to be in the right place, especially for winch launch. It means the last thing I push onto my brain stack is the direction to turn after a high winch launch failure. This means that if I have a launch failure its "nose down -- got approach speed -- look ahead -- (too high for land ahead)-TURN" and, because the turn direction was the last thing into my memory, its the first thing that pops out again and turning the correct way is a no-brainer. We also teach the "E" with the accent on the pilot having done the self briefing, and/or had one from an instructor. The eventualities item is just a reminder that life is what happens while we are planning other things. On a winch launch it pays , as Martin points out to know what your plan is. It appears that the mind works this way. Referring to the eventualities plan as the last thing before initiating the launch, means it is top of mind when/if something goes wrong. So - the eventualities item is not a substitute for thought, but it does help to trigger the correct information from current short term memory in the event of things falling apart. I personally have to have a couple of very different "Eventualities" plans in my head. Consider the differences. We have a field with a short section of reasonable grass, cut short and level at each end. In the middle is over 1000m of much longer grass that the wildlife continuously works on returning to it's natural lumpy state. To the west there is a near parallel 1470m long tar runway varying from 150m to 300m, closer on the downhill side than on the uphill side. Oh, I almost forgot, the 60" tree between the runways at the uphill end. Depending on whether I am flying a 27:1 high wing, skid equipped two seater built like a brick outhouse, or my Std Cirrus with its low wings and 36:1 performance, a cable break at say 200 feet will have very different actions. Which will also vary depending on which direction the wind is from, etc. You don't want to be mentally flipping through permutations when the cable breaks at an awkward height. I use the "E" to remind me, of the decisions I have made about launching this specific airplane, on this runway with the current weather. Going through E on a deliberate site, conditions and aircraft basis is vital every time. For instance, I fly from a nice large site with flat land all around (mostly). If I get a winch failure and I am in a position where I have to turn then down wind is usually the best option (gives space and time as you turn back into wind to get into the site). 5 miles away is a ridge site which many of us fly from occasionally. Here turning down wind would be very dodgy as you would go straight into the curl over at a low height - guaranteed to be experience enhancing. So do it last and work through everything that is different since the last time you did this - wind (strength direction), type of launch (winch aero), aircraft (ballast, has it got flaps, max launch speed all that stuff) and so on and ask yourself "so what" at each stage. That builds your get out of jail plan and as has been pointed out, the last thing in the brain usually turns up as the first thing out. Cheers Robin -- Robin Birch |
Air Force (USAF, at least) checklists are arranged to go around the
cockpit from left aft, around the front, to the right aft. Makes the flow of checking items smooth. But the checklist "lists" all the items (and the position to be confirmed or set). What happens in practice is you would hold the checklist at the correct page and go through the items by memory (or listen to them being read by the copilot/WSO). If done correctly, it will catch all the switches/controls/settings. If done in a hurry, or totally by memory, or without thinking (easy to do when you do it every day, sometimes several times a day), it is surprisingly easy to miss items. Sometimes, you just have to sit back and look at everything and think about it for a moment.... Kirk 66 |
I spent many hours observing flight test pilots and the systems they
were testing. The procedure that seemed to be universal for before engine start was to set up all the systems by memory using the same flow, and then to check the systems configuration by use a checklist. Andy |
Nyal Williams wrote:
I'd like to see posted various generalized, and glider-non-specific pre-lauch checklists with the letters followed by explanation of what it means. I'm not a friend of large mnemonics, I've rather structured my checklist by logic content. This gives me a reliable generic check list which is valid for all gliders. 1) Glider preparation. (Rigging checks done, tail dolly, ballast etc.) 2) Strap myself. (This item also serves as a structure elment: group 1 cmopleted. In two seaters, passenger strapped and rear canopy locked goes here.) 3) Instrument panel. (Just go around the panel and point to each instrument. Radio check comes here, too.) 4) Mechanics. (Controls free, spoilers locked, flaps set, trim set.) 5) Canopy shut (Again, this serves a structure element: all checks done.) 6) Pre launch concentration phase. (Where is the go-no-go-decision point; what to do if the cable breaks low, middle, high; what is the safety altitude, what are the speeds to fly... Depends on glider, place, wind etc.) 7) Get the cale hooked up. (Another structure element. No way I let somebody hook up the cable before this point, regardless on how much pressure they apply.) 8) Windsock, no people in the way, give ok sign. This works for all situations and all gliders, I don't have to memorize a long list and the risk of forgetting something is minimal. Stefan |
At 18:24 25 January 2006, Stefan wrote:
This works for all situations and all gliders, I don't have to memorize a long list and the risk of forgetting something is minimal. Stefan There are 8 items in your list, as many as CBSIFTCB, but no structure or mnemonic. Easy to forget something. |
Mark Dickson wrote:
At 18:24 25 January 2006, Stefan wrote: This works for all situations and all gliders, I don't have to memorize a long list and the risk of forgetting something is minimal. Stefan There are 8 items in your list, as many as CBSIFTCB, but no structure or mnemonic. Easy to forget something. |
The last item on all my checklists is, "Don't do nothin' dumb". That's to
avoid being the lead story on the evening news. Bill Daniels "Stefan" wrote in message ... Mark Dickson wrote: At 18:24 25 January 2006, Stefan wrote: This works for all situations and all gliders, I don't have to memorize a long list and the risk of forgetting something is minimal. Stefan There are 8 items in your list, as many as CBSIFTCB, but no structure or mnemonic. Easy to forget something. |
Funny thing about checklists...you gotta use 'em.
I'm very conscientious in my use of checklists. I use the ABCCCDWD (altimeter, belts, controls, cable, canopy, divebrakes, wind, Dead (as in "will kill you dead if you do something stupid"). I use USTALL in the landing pattern. Undercarriage, spoilers (yeah, I know its not consistent with D for divebrakes), trim, airspeed, lookout, land. Works for me...usually. Did I mention that I'm very conscientious about using my checklists? Well, here's how I got caught out: I went through my pre-launch checklist and got myself mentally prepared for tflight. Takeoff was as normal. During the tow, I noticed a cockpit problem (not a flight safety issue) that I wanted to fix before engaging in a long day of cross country. I notified the tug that I was getting off early and landing, and did so. Now, here's where I screwed up. I didn't go through my checklist for the second launch. I had already done the checklist hadn't I? As you may have already guessed, the divebrakes weren't locked and eased themselves open during the takeoff. Having noticed that the oncoming trees weren't dropping away as usual, I checked airspeed, found it right on, and immediately reached for the divebrake handle which I found full back. Closing it got us back on our normal climb. So, use those checklists EVERY time you launch. As an aside, my ship is a 301 Libelle, which type is known for ineffective divebrakes. In a ship with effective brakes it would have been more immediately obvious that the brakes were open. With the Libelle, or other ship with weak brakes, divebrakes open on tow is a more subtle and insidious problem, but one that could just as easily cause the flight to end badly. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I need winch launch videos | Bill Daniels | Soaring | 21 | December 1st 04 06:41 PM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Vandenberg Launch, April 17 | Piloting | 5 | April 9th 04 02:21 AM | |
Ground launch and the incremental vanishing of soaring | Mark James Boyd | Soaring | 24 | March 8th 04 10:50 PM |
