What is keeping the airplane's speed up with the conveyor belt? The
propeller. Said propeller moves air. Air causes lift By that logic, a pilot doing a full static runup at the runup area will levitate. -Robert, CFI |
LOL :-)) Or do an Indian rope trick! ;-)
"Doug" posted the exciting message
oups.com: What is keeping the airplane's speed up with the conveyor belt? The propeller. Said propeller moves air. Air causes lift. The problem is more complicated than it seems to be at first read. Well, if it only took the propeller then you could set the brakes, apply full power, and lift off at zero ground speed. |
"jesse" wrote:
when you walk on a treadmill, do you have any significant airspeed(minus wind and fans)? you are moving forward relative to the treadmill belt only, your airspeed is zero, sure your legs are moving at say three miles per hour, and the treadmill belt is moving three miles per hour the opposite way, but without airspeed you have no lift(assuming your arms were airfoils). its not that complicated people. the thrust of the airplane is only used in most cases, to provide a movement of air over the wings to cause lift. if the supposed airplane is stationary to the air, regardless how much thrust is being used to "keep up" with the treadmill, no lift will be created, try it with an rc plane on a real treadmill if you dont believe me. Im not calling anyone stupid, but didnt everybody learn in PP ground school that ground speed has nothing to do with airspeed and the associated lift? thats one of the first things, the most basic of things that i was taught. im done with this topic. enjoy, let the roasting begin! Jester PP-ASEL A&P some people apparently have a hard time reading. "a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward." When the conveyor belt is moving backwards at 80mph, how fast is the plane moving? Hint: there is no mention of how fast the plane is moving relative to the conveyor belt. If the plane is moving forward at 80mph, is it likely to have enough airspeed to fly? If you are still confused, when the plane is moving forward at 80mph, the conveyor will be moving backwards at 80mph, and a speedometer that measures off of tire rotation would indicate the plane's speed (before getting airborne) as 160mph, the speed relative to the conveyor. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
measures off of tire rotation would indicate the plane's speed (before getting airborne) as 160mph, the speed relative to the conveyor. While an airspeed indicator would indicate zero. -Robert, CFI |
"Robert M. Gary" wrote:
and a speedometer that measures off of tire rotation would indicate the plane's speed (before getting airborne) as 160mph, the speed relative to the conveyor. While an airspeed indicator would indicate zero. -Robert, CFI Only if there is an 80 mph tailwind. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
No. The plane is moving forward at 80mph. The wheels are the only thing
feeling the 160mph effect of the treadmill. This isn't a ground propelled vehicle. -- ------------------------------- Travis "Robert M. Gary" wrote in message ups.com... and a speedometer that measures off of tire rotation would indicate the plane's speed (before getting airborne) as 160mph, the speed relative to the conveyor. While an airspeed indicator would indicate zero. -Robert, CFI |
"cjcampbell" wrote:
Saw this question on "The Straight Dope" and I thought it was amusing. http://www.straightdope.com/columns/060203.html Seems Cecil Adams is compounding the confusion by having the page's title begin: "An airplane taxies in one direction...." So is the plane attempting to taxi or take off? The page's title says one thing, the person posing the question is stating another. The hypothetical pilot of the taxing plane would presumably not let the the airspeed go to takeoff speed, while the pilot of the plane taking off would want to accelerate to rotation speed. So on that basis alone, we can say a taxing plane isn't going to take off! ;-) |
Taxi is just nomenclature for the airplane moving along the ground.
"Takeoff run" would be more correct I guess, but in this case things are so weird, as it is ambiguous whether the plane is going to takeoff or not. |
If the treadmill is stationary and the belt speed is equal
to the required take-off speed, the airplane will have zero airspeed if it is "moving" in relation to the belt, the airplane is moving, the prop has thrust and is balancing the rearward movement of the belt. The tires are rolling, but the airplane is stationary and there is no airspeed or lift. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Doug" wrote in message oups.com... | Taxi is just nomenclature for the airplane moving along the ground. | "Takeoff run" would be more correct I guess, but in this case things | are so weird, as it is ambiguous whether the plane is going to takeoff | or not. | |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
