The V-g diagram is usually a good representation of this information.
The best SINGLE diagram I've found, IMO, is in the Jeppesen Instrument Pilot Manual. For Va (maneuvering speed), the angle of attack changes with speed and load. If you are flying slower, your are at a higher angle of attack. A gust from the front or below will increase the effective angle of attack, and, before the lift increases enough to do damage, a stall will occur (at least momentarily). However, if the gust is strong enough from below, you can damage the wings even if you are just dangling from a wire. The force on the wings isn't from too much lift--it's from just blowing the wings off. AvWeb had a discussion about this a few years ago; the information might still be in their archives. Flying Magazine, June 1996, page 106 had another fascinating article on this as well. Frequently, we seem to be taught that below Va, we can move the controls to full extreme without damage. Well, flight 587 in New York straightened us out on that. You can't go from one extreme to the other repeatedly. Another source of info is NTSB Safety Recommendation dated February 8, 2002. A few years ago, I did a minor Civil Air Patrol seminar on this topic--not in depth, just about 15 minutes or so. I have a very thorough Vg diagram I put together from several different sources. If anyone is really interested, I can try to dig it out of the archives; it is a powerpoint slide, though quite detailed. I have no idea how to put it up on the newsgroup, so if anyone IS interested and knows how, I can email it to them. |
topic--not in depth, just about 15 minutes or so. I have a very thorough Vg diagram I put together from several different sources. If anyone is really interested, I can try to dig it out of the archives; it is a powerpoint slide, though quite detailed. I have no idea how to put it up on the newsgroup, so if anyone IS interested and knows how, I can email it to them. Email it to me at I'll upload it to the binary channel (alt.binaries.pictures.aviation) you ya! (Pictures are verboten here...) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On 2006-02-09, Jay Honeck wrote:
That makes a LOT more sense to me than the commonly labeled "UPdraft", which implies a wind from below. True UPdrafts only make sense to me near the ground, where wind over ground obstacles can create eddies and currents, much like water in a stream burbles around rocks and other obstructions. Not anywhere near correct, I'm afraid, as any glider pilot can tell you. Thermals also qualify as 'updrafts', and I've spent many hours being kept aloft by these updrafts. Even with our weak lift here, I've got my glider to 5,300 feet on these, and in Texas I've been at over 8,000 feet AGL. Some soaring sites get thermal lift up to 12000' AGL. Wave lift (which can be considered an updraft, as there is a vertical component to the air) can reach well into airliner altitudes. Gliders at Minden regularly reach FL300 and higher. The only part of turbulence I truly DON'T understand is the kind that tips one wing up violently. How the heck a "parcel" of air can be so different in the span of just 30 feet (our approximate wingspan) escapes me, but I've had turbulence push one wing up so hard that it took nearly full opposite aileron to remain level. Again, try some gliding in the summer to understand this better. Quite often in a glider, you feel one wing rising faster than the other - you bank into this rising wing because this is where the strongest lift is. Small, strong thermals can have a very marked boundary and it's quite easy to have half the plane inside the thermal and half of it outside. -- Dylan Smith, Port St Mary, Isle of Man Flying: http://www.dylansmith.net Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de Frontier Elite Universe: http://www.alioth.net |
which implies a wind from below. True UPdrafts only make sense to me near the ground, where wind over ground obstacles can create eddies and currents, much like water in a stream burbles around rocks and other obstructions. Not anywhere near correct, I'm afraid, as any glider pilot can tell you. Thermals also qualify as 'updrafts', and I've spent many hours being kept aloft by these updrafts. Understood, but I'm making a distinction between "lift" (which is a consistent area of "updraft") and "turbulence" (which is an inconsistent area of "updraft" or varying relative wind, i.e.: wind shear). The line is fine, admittedly, but the sky is complex enough to require it. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
I'll give you one piece of advice that I have learned by experience. I
fly out of Boulder, CO. West of Boulder is the Continental Divide rising to 14000+. The prevailing west winds come over the ridge and on the east side of the ride there is unseen pockets of 'rotor' type turbulence. Going west you are climbing and are slow, so if you hit them it's not too bad. But coming east, you are descending. Pilots need to keep their speed down here. It is easy to point the nose down and gain speed. Sometimes, except for these turbulence pockets, the route is smooth, so that doubles the temptation to come down fast. When you hit the pocket of turbulence it is usually just one or two "thwaps", like giant hit the top of the wings with a big flyswatter. Then smooth again. This is one place where keeping an eye on Va is essential. |
Hey Jay:
As an aside: Is your Va close to, or at Vno? (In the old days we called Va "Rough Air Penetration Speed" now it is called, rather inappropriately I think; "maneuvering speed". I may be misnterperting your message and if I am, my apologies. From your message it appeared that you are concerned about staying out of the yellow arc vs staying in the green arc in rough air. Can I then I assume your Vno and Va are close to each other? Regards, Watson "Jay Honeck" wrote in message news:ScyGf.763242$_o.277999@attbi_s71... Mary and I flew to West Bend, Wisconsin (KETB) today. It was supposed to be CAVU all day, except along the Lake Michigan shoreline (where they were getting stomped with lake-effect snows all day), but, of course, the forecast was just a bit off, as it often is in winter. From Dubuque (DBQ) to Madison (MSN) we ended up flying at 3500 feet under a broken-to-solid overcast. With an artic cold front settling into the upper Midwest, the winds were howling pretty good, flipping around from 020 to 310 at 19 knots when we landed in West Bend. It was a good, but busy, landing... En route we encountered mostly light to moderate turbulence, with long periods of little "bumps" intermixed with some pretty good jolts. I hit my head on the ceiling once, and my seat belt was plenty tight. Having 1:45 to study this uncomfortable mode of flight, we discerned something about turbulence that we'd not noticed befo Upon entering an area of more severe turbulence, air speed invariably climbs. Since our Pathfinder (with all its speed mods) usually cruises well into the yellow arc, this can be a real problem. We would set the throttle and prop RPM so that we would be clearly out of the yellow arc, and then -- just when you DIDN'T want it to climb higher (i.e.: when hitting moderate turbulence) -- the airspeed indicator would almost instantly jump into the yellow arc. Sometimes it would stay there for a minute, and we'd have to reduce power to get things back in line. We debated this phenomenon for some time, as it didn't seem to make sense. Why would the airspeed jump when encountering turbulence? It *feels* like an updraft, when it slams your head into the ceiling, which seems like it should result in either a drop -- or no change -- in airspeed. And wouldn't you think turbulence would be equal parts up- and down-drafts? One possibility we considered: Perhaps, upon encountering an updraft, we were instinctively pushing the nose over, to hold altitude. This would, of course, result in an airspeed increase. However, as soon as we postulated that theory (man, we have some *interesting* husband/wife conversations, no?) we were able to test it, and, no, that wasn't the case. With the yoke held rock-solid in place during turbulence, indicated airspeed still increased. Another likely possibility: The airflow over the pitot tube is being disrupted, and making it LOOK like the airspeed is jumping into the yellow arc. A good test of this would be to see if GROUND speed increased, too, but the GPS doesn't update quickly enough to tell for sure. And the fact that it would sometimes stay in the yellow arc for more than just a few seconds seems to negate this possibility. So what's happening here? Is the airspeed REALLY increasing in the bumps, or not? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Watson" wrote
As an aside: Is your Va close to, or at Vno? (In the old days we called Va "Rough Air Penetration Speed" now it is called, rather inappropriately I think; "maneuvering speed". The 'Maneuver Envelope' with which the average pilot is familar, and which contains Va, is not the same as the 'Gust Envelope'. Section 23.333: Flight envelope (c) Gust envelope. (1) The airplane is assumed to be subjected to symmetrical vertical gusts in level flight. The resulting limit load factors must correspond to the conditions determined as follows: (i) Positive (up) and negative (down) gusts of 50 f.p.s. at VC must be considered......... (ii) Positive and negative gusts of 25 f.p.s. at VD must be considered........... Quoted from Aerodynamics for Naval Aviators: "As a general requirement, all airplanes must be capable of withstanding an approximate effective +/- 30 foot per second gust when at maximum level flight speed for normal rated power. Such a gust intensity has relatively low frequency of occurrence in ordinary flying operations. The highest reasonable gust velocity that may be anticipated is an actual veritical velocity, U, of 50 feet per second." Bob Moore ATP, CFI |
Va "Rough Air Penetration Speed" now it is called, rather inappropriately I think; "maneuvering speed". I may be misnterperting your message and if I am, my apologies. From your message it appeared that you are concerned about staying out of the yellow arc vs staying in the green arc in rough air. Can I then I assume your Vno and Va are close to each other? Crap -- you made me dig out my POH. (That hasn't happened in a while!) From Wikepedia: a.. VA: design maneuvering speed (stalling speed at the maximum legal G-force, and hence the maximum speed at which abrupt control movements will not cause the aircraft to exceed its G-force limit). - Va in our plane is 138 mph, and is not depicted on the ASI. While Vo is: a.. VNO: maximum structural cruising speed (the maximum speed to be used in turbulent conditions). On our plane, that's 156 mph (136 knots), which is the start of the "Yellow Arc". Since our plane cruises at 142 knots (at 23 squared), we're always aware of this airspeed. Now that we've established all this, what did you want to know? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
- Va in our plane is 138 mph, and is not depicted on the ASI. Isn't it usually placarded? |
It can be, but remember it varies with weight, so it would be placarded at a
specific weight. Higher Va for a higher weight. It was placarded in our 182RG, it's not placarded in our Aztec. Jim "B a r r y" wrote in message et... Jay Honeck wrote: - Va in our plane is 138 mph, and is not depicted on the ASI. Isn't it usually placarded? |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Devices for avoiding VNE? | John Galloway | Soaring | 100 | April 12th 04 08:53 PM |
My First Time In Severe Turbulence (Long) | David B. Cole | Instrument Flight Rules | 6 | March 10th 04 10:21 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
How much turbulence is too much? | Marty Ross | Instrument Flight Rules | 8 | August 21st 03 05:30 PM |
