AUTOPILOT AWRY
Old February 13th 06, 07:51 PM posted to rec.aviation.owning
Default AUTOPILOT AWRY
Thanks for the help!!
I am going to do some detective work and will report back.
Bill Snow
"William Snow" wrote in message
I have a piper Arrow and out of the blue...(no pun intended)... the
Autopilot banked hard left (30 deg.) for no apparent reason. It was on Hdg
Mode and the bug was centered.
Each time it was shut off and re-engaged it continued to bank hard left.
I have a long trip to FL planned over the school break and sure would like
to have the Autopilot working.
Does anyone know why this would happen?
Thank You All.
Bill Snow
Old February 18th 06, 09:58 PM posted to rec.aviation.owning
Looking forward to your findings Bill. Reason being, the Autocontrol
III in our Arrow only works in heading bug mode. I'm interested to know
how much time/money you wind up putting into your repair. It would be
nice to have ours work in all modes but I'm not so sure I'd want to
spend more than a couple tenths of an AMU on it.
Jack Allison
PP-ASEL-IA Student
Arrow N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old February 18th 06, 10:26 PM posted to rec.aviation.owning
Sheesh - can you even get a tire changed for that much?
.... by the way, it costs me nuthin' to get a tire changed ;-)
On the other hand, the mixture control is bottoming out against the firewall
and the maintenance folks believe this is working correctly ;-\
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old February 19th 06, 12:51 AM posted to rec.aviation.owning
Dunno...but will find out soon as the nose wheel is due. Stay tuned.
Hehe...ya, and you don't need to wipe bugs off the plane after each
flight either. OTOH, I can be a hangar rat whenever I want. :-)
firewall
Hmmm, I like our maintenance program better, even if we can't get a tire
changed for free :-)
Jack Allison
PP-ASEL-IA Student
Arrow N2104T
- Leonardo Da Vinci
Old February 19th 06, 01:09 AM posted to rec.aviation.owning
Oh, it's true, it's true ... I have no hangar
firewall
I can't argue with that.
Sacramento, CA
Old February 19th 06, 10:21 PM posted to rec.aviation.owning
Are you saying it doesn't work in ROLL mode, but does work in HDG mode?
Unusual, but if so then it's a pretty simple fix. The HDG switch
essentially disables the ROLL pot, so if it works okay in HDG but not
in ROLL, then either the switch is bad, or the POT is bad, not much
else involved.
Old February 20th 06, 12:04 AM posted to rec.aviation.owning
else involved.
Sorry, I should have clarified. Heading mode works, roll works (sort
of, I'll explain in a sec.). It is the other modes (NAV, OMNI, LOC, LOC
back course) that don't work.
For roll mode, if I turn the round roll knob slightly one direction, the
ailerons keep moving to the stops. If the knob is centered though, the
ailerons stay centered. I've only tried this on the ground. In the
air, heading mode works fine but none of the other modes mentioned above.
Jack Allison
PP-ASEL-IA Student
Arrow N2104T
- Leonardo Da Vinci
Old February 21st 06, 11:50 PM posted to rec.aviation.owning
I thought that is the way it is supposed to work on the ground. I thought,
and I might be wrong on this, that the roll pot set a desired angle of bank,
not a desired aileron position. Next time I have some time, I will check
this out.
Just another data point for consideration: My auto pilot was not working
right on my arrow when I bought it ( or should I say it always worked
"right"). It would turn to the right in VOR/LOC modes. I had the shop look
at it along with other items on my squawk list. They fixed it with no parts
and about an hour of labor. I don't know what the problem was. Just goes to
show you that autopilots are not always expensive to get fixed. It is
definitely worth having someone look at it.
"Jack Allison" wrote in message
else involved.
Sorry, I should have clarified. Heading mode works, roll works (sort of,
I'll explain in a sec.). It is the other modes (NAV, OMNI, LOC, LOC back
ailerons stay centered. I've only tried this on the ground. In the air,
Jack Allison
PP-ASEL-IA Student
Arrow N2104T
- Leonardo Da Vinci
Old February 22nd 06, 07:19 AM posted to rec.aviation.owning
else involved.
That's OK - the autopilot rolls till the roll feedback
from the horizon gyro matches the request from the pot.
You're ordering a certain amount of roll. If the horizon
does not follow, turn more on the ailerons till the order
is fulfilled.
Tauno Voipio (CPL(A) - avionics engineer)
tauno voipio (at) iki fi
KAP140 autopilot and a KLN94 GPS question STICKMONKE Instrument Flight Rules 5 November 12th 05 04:06 AM
mitchell autopilot dave Owning 1 May 5th 04 06:11 PM
IMC without an autopilot Jon Kraus Instrument Flight Rules 101 April 18th 04 07:17 PM
Chelton AP-3C autopilot Kyler Laird Owning 0 April 2nd 04 03:08 PM
KAP140 Autopilot Details News Instrument Flight Rules 27 October 22nd 03 02:01 AM
