Not the crumbling yellowed pages I remembered, but give this a try...
Try he http://trs.nis.nasa.gov/archive/0000...1/asm-B200.pdf |
On Sun, 19 Feb 2006 00:25:35 GMT, Richard Lamb
wrote: clare at snyder.on.ca wrote: Clare, thanks for taking a reasonable position and tone. Muchly appreciated. I'll reply as best I can, ok? Richerd, You are getting ahead of yourself. Forget the pictures you saw in the Rec Av magazine. Those were projects some guys built. They were NOT the tests done by Gary. Gary did the tests on a wing BUILT ACCORDING TO PLANS, and IT FAILED THE TEST. That was not my take from the article, but if I'm wrong on that point, I'll offer an apology. The Test: I've never been offered any description of the set up - only the conclusions. The wing was supported as it would be on the plane, but inverted. It was then loaded with sandbags to iminent failure, with the load properly distributed. It was tested both with and without the jury strut. The jury strut is VERY CRITICAL (and it's attatchment according to the plans was not sufficient) and even with the jury strut upgraded the wing did not meet the specified G rating for the design specified gross weight. IIRC it is a 500 lb wing, not a 600 - but my memory of that detail may be fuzzy. What I DO know, is it did NOT meet the published spec, or the required G load for the published maximum gross weight. As I understand it, it was assumed that the front spar would take 100% of the load. That is, of course, true IF the spar is located at the center of pressure - as a normal wing is arranged. There were mo assumptions made. The wing was properly supported and loaded. But the wing in question is obviously NOT arranged that way. The spars are at the leading and trailing edges while the center of pressure remains back around 30% to 40% of the chord. The airfoil used is a Clark-Y. There is a minor deviation at the leading edge due to the 2" diameter of the leading edge being a bit larger than the radius shown in the tables. Which also causes aproblem when a larger spar diameter is used. IIRC it makes the stall more abrupt -which you do NOT want. At zero degrees AoA the CP is at 40%. At 12 degrees AoA it has moved forward to 30% In my work, I've ASSUMED that the front spar would only receive 70% of the total load. That makes a tremendous difference in the amount of deflection of the spar, and, seems to be much closer to what we observe in the actual structure in flight. I think this also explains why Beeson could build a wing using .035 wall spars tubes. My crude work on those indicates they wouldn't survive 2 G's at 100% load. But they do - although with noticeable deflection under load in flight. And Chuck BUILT the .035 wing, but did not fly it, from what I understand, as the wing was too flimsy even for HIS level of comfort. Just to be through, the wing structure should also be mounted at, in this case, 12 degrees nose down (it's inverted, remember) to account for the angle of attack at the test load. This will have the effect of pulling the load vector forward some, but the magnitude is tiny compared to a 30% offset. The other improvements I noted should/could be made HAVE NEVER BEEN IMPLEMENTED to the best of my knowledge. Hey, I'm not saying it's a bad idea. Like you pointed out there are some real benefits to it. Rivet heads under the fabric are a pain to work around. On my first parasol (PBJ) I use a thin piece of wood molding on the outboard side of the top longeron to avoid that. On the second one I just used flush rivet - and avoided the problem without adding the extra weight. As for the extruded aluminum truss construction, using the sizes listed in the plans, and the rivets specified, it is difficult, if not impossible, to achieve proper hole edge clearances in MANY locations. I know, for an ultralight there are no inspections, so you can get away with it - but you are NOT building to acceptable aircraft standards if proper edge clearances can not be maintained. The edge margins for thin sheet are well known and easily found. I'm not having much luck locating the tables for Lugs on short notice. The difference, as I recall, is the relative thickness of the metal being bolted or riveted. Those extrusions are five times thicker that .025 sheet metal. But I'm still looking for it and will post it here when I find it. 1.5 times the hole diameter rings a bell. Examining the results of some of the accidents, even the one straight in on the nose fatality, you do not find broken rivets. The angles bent, but seldom even break. In the bad one, the first bay of the fuselage truss was crumpled up like an accordion. The Texas Parasol is just an angle aluminum Baby Ace in concept - shortened and with bigger tailfeathers to compensate. It's a Texas airplane, guys. Texans just GOTTA have a lot of tail! Apparently you built yours one station longer, making it the same dimensions as the Ace. The wings are the same dimensions and planform as well, from what I understand. So the CONCEPT is a good one. The plane CAN be built as a safe, economical, fun-to-fly plane - but NOT as per plans. It's still quite a bit smaller than a Baby Ace. The added 15 inches was for weight and balance purposed only. A full dressed 2180 VW can weigh well over 200 pounds. Compared to a light weight 2 stroke, that can create a - situation! It was nearly TOO much extra tail arm as it was tough getting the CG far enough _forward_ to stay in an acceptable range. I think we've got it worked out though. Just had to come up with a lighter tail wheel and leg. But tell everyone how you built yours. It was not strictly to plans. What about the leave in the spar?? I don't know where that rumor came from. The wing on the new plane was built mainly according to the plans, with the exception of boxing in the compression struts at the strut attach bay. My reason for that was that the struts on this plane angle in a bit at the fuselage end, creating a small compression load at the spar ends. Probably not really necessary, but it made me feel better. The internal sleeves are as per plans. I also added a short .017 sheet metal cover over the leading edge. I'd not think that's a structural thing - purely cosmetic. A FULL truce is as close as the corrections to the plans. Just because nobody's killed themselves YET does not mean the plans, as they exist today, are safe. By your admission, many builders ARE making changes. Well, I think that was more of an accusation than an admission, Clare. I have had one friend who was killed in his. It was a hard loss to deal with. And it gave me pause to seriously reconsider. Please believe me folks, if we had ANY experience that indicated there were real structural problems with the thing, I'd be the first one to address them. But the physical evidence simply does not support that claim. At least - as shown in the plans - and not "improved" to be faster, heavier, etc. Mission Requirements: It is intended to be a very inexpensive, very light (ALmost UL), very slow, SINGLE seat baby buggy. Hand tools only - with very little welding (the main gear axle clusters) and little if any machine work needed. Relatively tolerant of "workmanship" issues. Protection for the pilot in the advent of an accident. (be real, folks!) Good flying qualities, and fun to fly. If that's not what you want, this is not the airplane to build. And I'd appreciate it if people would NOT try to make it into something it was never intended to be. There in lies the real danger. Richard *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** |
![]() Jean-Paul Roy wrote: Monty, I'm glad you made this intervention here. The Texas Parasol always attracted me as a project after my actual plane (CH701) is finished, just for the sake of enjoying building something. I downloaded the plans from Matronic last week and I was just going to send Richard $30.00 for his CD or DVD. As of NOW the files are DELETED and you just saved me $30.00. The Sky Pup: http://www.skypup.net/ is a scratch built ultralight. Pretty good plans are available and it has a good safety record. There are several flying, several more under construction, and an active builders/users/ club (note, not a group, a club on Yahoo: http://groups.yahoo.com/group/Skypup-club/ First time builders claim to have comkpleted theirs within the 400 hour estimare. Cost depends mostly on how much you pay for the engine and prop. The dry weight of the prototype was 200 lbs and it was designed for 400 lbs gross, by real engineers. -- FF |
![]() wrote The dry weight of the prototype was 200 lbs and it was designed for 400 lbs gross, by real engineers. I could not fly it, and I'm by no means, a lard butt. Under 170 lbs for the pilot, it looks like to me. -- Jim in NC |
"Morgans" wrote in message
... wrote The dry weight of the prototype was 200 lbs and it was designed for 400 lbs gross, by real engineers. I could not fly it, and I'm by no means, a lard butt. Under 170 lbs for the pilot, it looks like to me. -- Jim in NC I admit the same problem, due mostly to height. It would need to be scaled up, which is not always a good idea, since it is difficult to scale myself down. I am making some progress on the width and gross weight part of the problem. :-) None the less, an interesting design--even though it apears to be so "traditional" as to use a tail skid to double as a brake. Peter |
![]() Peter Dohm wrote: "Morgans" wrote in message ... wrote The dry weight of the prototype was 200 lbs and it was designed for 400 lbs gross, by real engineers. I could not fly it, and I'm by no means, a lard butt. Under 170 lbs for the pilot, it looks like to me. To be within design gross with 5 gallons of fuel, yes. -- Jim in NC I admit the same problem, due mostly to height. It would need to be scaled up, which is not always a good idea, since it is difficult to scale myself down. I am making some progress on the width and gross weight part of the problem. :-) The designer was tall ans skinny, over 6' IIRC. Evidently Height is not the problem that, er, girth is. None the less, an interesting design--even though it apears to be so "traditional" as to use a tail skid to double as a brake. From what I read on the Yahoo club it flies fine with pilots up to 200 lbs (not sure how much fuel, probably less than 5 gallons). A heavier pilot erodes the factor of safety. The stress analysis on the airframe was done by finite element analysis by competent engineers so you can be confident in the factor of safety, you know how much you have left if you fly over gross. -- FF |
Richard Lamb and the Texas Parasol Plans ...and Sirius Aviation | Richard Lamb | Home Built | 12 | August 9th 05 08:00 PM |
want to trade 601 plans for 701 plans | [email protected] | Home Built | 0 | January 27th 05 07:50 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Texas Soars into Aviation History | A | Piloting | 7 | December 17th 03 02:09 AM |
good book about prisoners of war | Jim Atkins | Military Aviation | 16 | August 1st 03 10:18 AM |
