1984 Mooney M20K 231 for sale
Old February 19th 06, 10:25 PM posted to rec.aviation.marketplace,rec.aviation.owning
Default 1984 Mooney M20K 231 for sale
"Ken Reed" wrote in message
news
How did you find the 3 bladed prop to perform. Many in the Mooney
community seem to believe the 3 blade prop reduces cruise speed by
about 5 knots.
I believe that's only for the four cylinder models. The six cylinder ones
(as is Vince's 231) do not suffer any loss of cruise speed.
AIUI, the earlier three blade props were not optimal for higher
HP/displacement engines...not like he current stable.
Also, you could run higher RPMs with a three blade that, with a two blade
prop, would could unsuitable noise and vibration.
Old February 25th 06, 01:09 AM posted to rec.aviation.marketplace,rec.aviation.owning
One main advantage of more blades is that you can use more power for
the same prop diameter and construction. Each blade handles a portion
of the total thrust-power. In a two blade there is about 0.5/0.333 - 1
== 50% more stress per blade due to thrust - for same engine power.
Old February 25th 06, 02:25 AM posted to rec.aviation.owning
-----Original Message-----
Posted At: Friday, February 24, 2006 6:09 PM
Posted To: rec.aviation.owning
Conversation: 1984 Mooney M20K 231 for sale
Subject: 1984 Mooney M20K 231 for sale
[Jim Carter]
Isn't one feature of the 3 blade prop a smaller diameter that provides
better ground clearance?
And are you really using more power? Isn't number of blades related to
torque applied to the crankshaft? The engine doesn't change power output
based on the number of blades its swinging does it?
I know that smaller diameters tend to mean lower tip velocity and less
noise for the same amount of torque, but I've never heard more blades
means more power used before. But then, I could be wrong...it wouldn't
be the first time and it probably won't be the last.
Old March 10th 06, 05:54 PM posted to rec.aviation.marketplace,rec.aviation.owning
I haven't had any issues with cruise speed being lower than I expect.
Then again, I never owned the plane with a 2 bladed prop, but I cruise
as fast as my friend's 231 with a 2 bladed prop at the same MP.
Old February 23rd 06, 11:48 PM posted to rec.aviation.marketplace,rec.aviation.owning,rec.aviation
If you're too ashamed to post asking price and location, don't even
bother posting.
Vince wrote:
I have a 1984 Mooney M20K 231 for sale. 2483 TTSN, 1415 SFRM. Dual Garmin
430s.
Please see http://www.madness.net/n57568 for specifications and tons of
pictures, and email me directly with any questions. Thanks for looking!
Vince
Old March 10th 06, 05:52 PM posted to rec.aviation.marketplace,rec.aviation.owning
Asking price is $149k, located at ISP, NY. Offers of course are welcome.
Old March 10th 06, 06:02 PM posted to rec.aviation.marketplace,rec.aviation.owning
Not ashamed at all:
Full information about the aircraft and tons of pictures are available
at http://www.madness.net/n57568/ (make sure to click through to the
additional pictures, there are 50 of them). My asking price is
$149,000, with all ADs complied with and airworthy items fixed (if
any), delivered, if you want, to your location (negotiable) from mine,
which is ISP, in NY.
It has had over $40,000 in avionics put in since I've owned it, and has
had excellent maintenance (overhauled propeller, overhauled oxygen
system, overhauled HSI, overhauled AI, overhauled boost pump,
calibrated autopilot, new landing gear shock disks and many other new
or overhauled items). Last annual was in TX at Don Maxwell Aviation,
one of the best Mooney shops around.
Any questions after viewing the photos and specs should be directed to
me by email please. The aircraft's useful load is 943 lbs. It has long
range tanks, so if you fill the tanks you can fly for nearly 1600nm.
Vince
Landing a Mooney Jon Kraus Owning 42 November 16th 04 08:00 PM
Landing a Mooney Jon Kraus Piloting 42 November 9th 04 08:53 PM
Landing a Mooney iain_hutchison Piloting 0 November 4th 04 03:38 PM
Mooney M20 K on Grass ? Andrew Boyd Owning 0 August 13th 04 04:00 PM
Loading luggage in other than Mooney Robert M. Gary Piloting 21 June 28th 04 07:23 PM
