Landing lights, incandescent, halogen and Xenon HID
I have finally got my wing tips painted and on my Seneca, they have the
hid lights in them. I had the Piper wingtip recognition lights before, 35 watters, not good enough to show a light in daylight. My attention is now turning towards my actual landing lights. These are located on the nosegear strut. I am thinking of getting halogens to replace the incandescents. Has anybody done this and did you see much of a difference, if so, how much? I don't want to get hid's for the nose gear, there is only one manufacturer that has an stc for this. I don't like the installation set up. Specifically the ballast being glued up inside the wheelwell. Also in cold weather it will take awhile to warm them up, I will probably have landed by then. For those who don't know, the lights go out when the gear goes up (a good thing really) even if the switches are still on. 4509 110,111 cp 100 watts used incandescent Q4509 140,000 cp 100 watts used halogen So has anybody anything to offer by way of comparison? John |
The,
4509 110,111 cp 100 watts used incandescent Q4509 140,000 cp 100 watts used halogen So has anybody anything to offer by way of comparison? Go with the halogen by all means! In our Tobago, the light is much brighter than what we had with incandescent (same bulb types you quote). The beam is a little more narrowly focussed, though. Major benefit is the vastly improved life-time of the halogen bulbs. -- Thomas Borchert (EDDH) |
Thanks Thomas. That is the sort of stuff I was looking for. I read the
halogens are 7x7 degrees and the incandescents were 12x7 or 8 degrees. I can live with that. And I think that is with the filliament horizontal, but it did not say. Most people mount the filament vertical and I guess that would be better for a landing light. I can have two on my nosewheel strut. I guess I will have some fooling around to do, aiming them. I just really wanted someone to tell me yea or nay. Again thanks. John Thomas Borchert wrote: The, 4509 110,111 cp 100 watts used incandescent Q4509 140,000 cp 100 watts used halogen So has anybody anything to offer by way of comparison? Go with the halogen by all means! In our Tobago, the light is much brighter than what we had with incandescent (same bulb types you quote). The beam is a little more narrowly focussed, though. Major benefit is the vastly improved life-time of the halogen bulbs. |
The Visitor wrote:
I have finally got my wing tips painted and on my Seneca, they have the hid lights in them. I had the Piper wingtip recognition lights before, 35 watters, not good enough to show a light in daylight. My attention is now turning towards my actual landing lights. These are located on the nosegear strut. I am thinking of getting halogens to replace the incandescents. Has anybody done this and did you see much of a difference, if so, how much? I don't want to get hid's for the nose gear, there is only one manufacturer that has an stc for this. I don't like the installation set up. Specifically the ballast being glued up inside the wheelwell. Also in cold weather it will take awhile to warm them up, I will probably have landed by then. For those who don't know, the lights go out when the gear goes up (a good thing really) even if the switches are still on. 4509 110,111 cp 100 watts used incandescent Q4509 140,000 cp 100 watts used halogen So has anybody anything to offer by way of comparison? John As long as you're considering lamps that may not be approved for your aircraft, you may want to look at H7604 or H7614 bulbs. Comparable light, less current. Rip |
"Rip" wrote in message . net... As long as you're considering lamps that may not be approved for your aircraft, you may want to look at H7604 or H7614 bulbs. Comparable light, less current. Rip I knew this was coming. |
Michael Ware wrote:
"Rip" wrote in message . net... As long as you're considering lamps that may not be approved for your aircraft, you may want to look at H7604 or H7614 bulbs. Comparable light, less current. Rip I knew this was coming. Excellent! Unfortunately, many owner/operators are not aware that a "will fit" part is not necessarily acceptable. Kudos to you, and others who are so aware. Rip |
Rip wrote:
: I knew this was coming. : : : Excellent! Unfortunately, many owner/operators are not aware that a : "will fit" part is not necessarily acceptable. Kudos to you, and others : who are so aware. ... wake me up when this is over. Zzzzzzzzzzzzz... -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
. .. Michael Ware wrote: "Rip" wrote in message . net... As long as you're considering lamps that may not be approved for your aircraft, you may want to look at H7604 or H7614 bulbs. Comparable light, less current. Rip I knew this was coming. Excellent! Unfortunately, many owner/operators are not aware that a "will fit" part is not necessarily acceptable. Kudos to you, and others who are so aware. Rip But, on the other hand, feel free to add Marvel Mystery Oil, or whatever you want to your engine oil / fuel - after all, the engine is not nearly as improtant to safe operation as a light bulb... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
Rip wrote: look at H7604 or H7614 bulbs. I want cp! H7601 100 kcp H7614 2 kcp In Canada it seems they (Q4509) are treated as a direct replacement. Is there something hazardous I should know about? |
From Avtek======== http://www.avtek2.com/halogen_lights.htm
Test environment was a dark country road, power supply holding a consent 13.8 volts and a grove of trees 1/3 mile away. Judges were six NON-Pilots with no bias at all as to the test results. 1) 4509 barely hit the trees and no details could be observed, due to the "Yellowish light" 2) Halogen hit the trees, and details such as green leaves and branches were seen. However the pattern was tight. 3) H-I-D hit the trees unlike Halogen, the H-I-D light-up the all the Trees and nests could be seen. The light was Pure White 4) Q-4509 Hit all the Trees as with H-I-D but the light went further and beyond to houses 3/4 mile away, in a wider pattern, and a deer was seen in the field, not seen by the other lights. Wow, interesting. However, with two quarts bulbs going, I get the feeling I may have them dim down in the flare as the throttles are closed. I am again leaning toward the hid option for the nosewheel. At the cost not being too significant I may put in the Q's just for an experiment. John Thomas Borchert wrote: 4509 110,111 cp 100 watts used incandescent Q4509 140,000 cp 100 watts used halogen So has anybody anything to offer by way of comparison? Go with the halogen by all means! In our Tobago, the light is much brighter than what we had with incandescent (same bulb types you quote). The beam is a little more narrowly focussed, though. Major benefit is the vastly improved life-time of the halogen bulbs. |
Similar Threads | ||||
Advice on landing lights? | Rob Turk | Home Built | 29 | January 23rd 06 06:32 PM |
