![]() soxinbox wrote: When doing steep turns, I noticed that there is a little resistance to pitch changes on the yoke. It seems it binds a little in the bearing through the panel. Does anyone have a suggestion for the type of lubricant I could use on this? Do they make anything for this purpose? What sort of airplane is it? Some of the older 172s had a problem with a bending/breaking panel brace that would let the panel flex enough that the control shaft bearing would start snagging and restricting elevator control. 172s also have a problem with cracking forward horizontal stab spars (caused mostly by people pushing down on the stab to turn the airplane on the ground when parking or whatever) and I have seen the spar broken clear through so that only the skin was keeping things straight. Under higher loadings (such as a steep turn) the stab will flex downward, misaligning the elevator hinges and making the elevator stiffer. A really bad sign. Might be a good idea to get it checked, if it's a 172. Look around the big lightening hole in the stab's forward spar. Sticky controls also result when pulley bearings dry out and the pulley stops (or resists) turning. Dan |
My plane is a turbo arrow IV. The sticking is definitely right in the
bearing that goes through the panel. It provides just a little bit of resistance so that when you try to make fine adjustments, its sticks and then gives a little causing me to slightly overshoot. It does not pose a real problem, but I think I would be more precise if it was smooth as silk. I am now working on my instrument rating and that is all about being smooth. wrote in message ps.com... soxinbox wrote: When doing steep turns, I noticed that there is a little resistance to pitch changes on the yoke. It seems it binds a little in the bearing through the panel. Does anyone have a suggestion for the type of lubricant I could use on this? Do they make anything for this purpose? What sort of airplane is it? Some of the older 172s had a problem with a bending/breaking panel brace that would let the panel flex enough that the control shaft bearing would start snagging and restricting elevator control. 172s also have a problem with cracking forward horizontal stab spars (caused mostly by people pushing down on the stab to turn the airplane on the ground when parking or whatever) and I have seen the spar broken clear through so that only the skin was keeping things straight. Under higher loadings (such as a steep turn) the stab will flex downward, misaligning the elevator hinges and making the elevator stiffer. A really bad sign. Might be a good idea to get it checked, if it's a 172. Look around the big lightening hole in the stab's forward spar. Sticky controls also result when pulley bearings dry out and the pulley stops (or resists) turning. Dan |
soxinbox wrote:
My plane is a turbo arrow IV. The sticking is definitely right in the bearing that goes through the panel. It provides just a little bit of resistance so that when you try to make fine adjustments, its sticks and then gives a little causing me to slightly overshoot. It does not pose a real problem, but I think I would be more precise if it was smooth as silk. I am now working on my instrument rating and that is all about being smooth. That sticking / overshooting phenomenon is endemic to the whole Cherokee model line if that bearing is not kept lubricated. I used a silicone lubricant when I owned one. It makes a huge difference in the flying qualities of the airplane. Reapply the silicone every oil change. |
I have a Cessna 150 that had silicone sprayed on the yoke shaft during it's
annual without me knowing. The next time I fly it the yoke was grabby. I wiped off most of the silicone and use a little Wd40. Was ok after that. Roger "Dave Butler" wrote in message news:1140709739.67207@sj-nntpcache-5... soxinbox wrote: My plane is a turbo arrow IV. The sticking is definitely right in the bearing that goes through the panel. It provides just a little bit of resistance so that when you try to make fine adjustments, its sticks and then gives a little causing me to slightly overshoot. It does not pose a real problem, but I think I would be more precise if it was smooth as silk. I am now working on my instrument rating and that is all about being smooth. That sticking / overshooting phenomenon is endemic to the whole Cherokee model line if that bearing is not kept lubricated. I used a silicone lubricant when I owned one. It makes a huge difference in the flying qualities of the airplane. Reapply the silicone every oil change. |
In my Seneca the bushing sort of floats and articulates as the shaft
changes angles as it is pulled aft. On the left side it doesn't and I think it is a bit of a binding problem for me. Very minor and keeping it lubed seems to fix it. soxinbox wrote: When doing steep turns, I noticed that there is a little resistance to pitch changes on the yoke. It seems it binds a little in the bearing through the panel. Does anyone have a suggestion for the type of lubricant I could use on this? Do they make anything for this purpose? |
O-360 sticking valve update | [email protected] | Owning | 19 | January 31st 06 01:04 PM |
Beech dual yoke w/rams horns/color preference | Dan Karshin | Aviation Marketplace | 1 | March 28th 04 05:04 PM |
CH yoke and peddals? | Tlewis95 | Simulators | 8 | December 2nd 03 11:58 AM |
CH Product Yoke with IP Trainer 6.5 | Sanjay Kumar | Instrument Flight Rules | 2 | October 10th 03 07:47 AM |
CFS-1 and CH Yoke / Pedals | Andy & Lucinda | Simulators | 3 | September 4th 03 01:14 PM |
