Ummm.. make sure the Knob is not loose and turning freely. We had the
same symptoms, loose knob slipped "in" on the shaft hard against the panel, so could not push the shaft in to uncage the gyro, so it coud not be "set". Slid knob back out to proper position on shaft, toghten set screw, fixed.. Maybe? Dave On Mon, 20 Feb 2006 22:33:53 -0600, "mbremer216" wrote: Well, it looks like my directional gyro just went belly up. When I went for a ride today, the setting knob was very sticky, and then suddenly not sticky at all as it now rotates freely and doesn't feel like it is engaging anything. The gyro card does not rotate with the knob. I have a Cherokee with a heading tracking Autocontrol III autopilot. What are opinions regarding having it rebuilt as opposed to replaced? Thanks Mike |
Pack a small amount of paper into the knob's shaft hole so that the knob
can't slide onto the shaft too far. Some DG knobs, if allowed to slide all the way onto the shaft, will hit the panel when you try to adjust the card. If there isn't enough "throw" before the knob hits the panel, it won't allow you to adjust the card. The set screw should hold it, but the paper trick makes it fool proof and relieves the pressure from the set screw. Jim "Dave" wrote in message ... Ummm.. make sure the Knob is not loose and turning freely. We had the same symptoms, loose knob slipped "in" on the shaft hard against the panel, so could not push the shaft in to uncage the gyro, so it coud not be "set". Slid knob back out to proper position on shaft, toghten set screw, fixed.. Maybe? Dave On Mon, 20 Feb 2006 22:33:53 -0600, "mbremer216" wrote: Well, it looks like my directional gyro just went belly up. When I went for a ride today, the setting knob was very sticky, and then suddenly not sticky at all as it now rotates freely and doesn't feel like it is engaging anything. The gyro card does not rotate with the knob. I have a Cherokee with a heading tracking Autocontrol III autopilot. What are opinions regarding having it rebuilt as opposed to replaced? Thanks Mike |
Thought about that one. The shaft turns with the knob and also goes in and
out. I was, at first hoping it was the knob. I have recently started some instrument training and when doind timed turns noticed quite a bit of discrepancy between the clock and the resulting turn (over 20 degrees). While I may not have been spot on in maintaining the turn rate via the needle & ball, there's no way I was that sloppy, particularly since the error was similar with turns in both directions. I'm just going to change it rather than fix it. Now the challenge is to find a replacement that won't break the bank. Thanks Mike "Dave" wrote in message ... Ummm.. make sure the Knob is not loose and turning freely. We had the same symptoms, loose knob slipped "in" on the shaft hard against the panel, so could not push the shaft in to uncage the gyro, so it coud not be "set". Slid knob back out to proper position on shaft, toghten set screw, fixed.. Maybe? Dave On Mon, 20 Feb 2006 22:33:53 -0600, "mbremer216" wrote: Well, it looks like my directional gyro just went belly up. When I went for a ride today, the setting knob was very sticky, and then suddenly not sticky at all as it now rotates freely and doesn't feel like it is engaging anything. The gyro card does not rotate with the knob. I have a Cherokee with a heading tracking Autocontrol III autopilot. What are opinions regarding having it rebuilt as opposed to replaced? Thanks Mike |
mbremer216 wrote:
I have recently started some instrument training and when doind timed turns noticed quite a bit of discrepancy between the clock and the resulting turn (over 20 degrees). While I may not have been spot on in maintaining the turn rate via the needle & ball, there's no way I was that sloppy, particularly since the error was similar with turns in both directions. I'm just going to change it rather than fix it. Now the challenge is to find a replacement that won't break the bank. Rmmmm? Maybe I'm just confused or you were unclear. This reads as if your timed turns aren't coming out on the right heading, so you're replacing your heading indicator. I hope I'm wrong. Dave |
I'm replacing the DG because the setting knob will no longer engage the
compass card. The DG is also behind the turns (turned at a rate slower than the mag compass). Also, it's pretty old and is probably past it's service life. Mike "Dave Butler" wrote in message news:1140790596.591398@sj-nntpcache-3... mbremer216 wrote: I have recently started some instrument training and when doind timed turns noticed quite a bit of discrepancy between the clock and the resulting turn (over 20 degrees). While I may not have been spot on in maintaining the turn rate via the needle & ball, there's no way I was that sloppy, particularly since the error was similar with turns in both directions. I'm just going to change it rather than fix it. Now the challenge is to find a replacement that won't break the bank. Rmmmm? Maybe I'm just confused or you were unclear. This reads as if your timed turns aren't coming out on the right heading, so you're replacing your heading indicator. I hope I'm wrong. Dave |
On Sat, 25 Feb 2006 09:18:22 -0600, "mbremer216"
wrote: I'm replacing the DG because the setting knob will no longer engage the Valid reason. compass card. The DG is also behind the turns (turned at a rate slower than Which could be quite normal. Mine, and most others, will at times even turn the opposite direction. Just a fact of life and physics. the mag compass). Also, it's pretty old and is probably past it's service life. If it still works it's not past a service life as I don't think they have one. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Mike "Dave Butler" wrote in message news:1140790596.591398@sj-nntpcache-3... mbremer216 wrote: I have recently started some instrument training and when doind timed turns noticed quite a bit of discrepancy between the clock and the resulting turn (over 20 degrees). While I may not have been spot on in maintaining the turn rate via the needle & ball, there's no way I was that sloppy, particularly since the error was similar with turns in both directions. I'm just going to change it rather than fix it. Now the challenge is to find a replacement that won't break the bank. Rmmmm? Maybe I'm just confused or you were unclear. This reads as if your timed turns aren't coming out on the right heading, so you're replacing your heading indicator. I hope I'm wrong. Dave |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Dead Reckoning, with the 'a' | David Megginson | Piloting | 8 | August 11th 04 02:22 PM |
Should Memorial Day and America's War Dead be commercialized? | Otis Willie | Naval Aviation | 0 | May 24th 04 02:29 AM |
Should Memorial Day and America's War Dead be commercialized? | Otis Willie | Military Aviation | 0 | May 24th 04 02:29 AM |
