"khobar" wrote in
news:apTKf.4201$Sp2.2506@fed1read02: "TRUTH" wrote in message ... Thank you for all the responses. It's nice to get other opinions. There's a few things that weren't commented on though. For instance..... "In the case of a Boeing 757 or 767, the pilot would be faced with an EFIS (Electronic Flight Instrumentation System) panel comprised of six large multi-mode LCDs interspersed with clusters of assorted "hard" instruments. These displays process the raw aircraft system and flight data into an integrated picture of the aircraft situation, position and progress, not only in horizontal and vertical dimensions, but also with regard to time and speed as well. When flying "blind", I.e., with no ground reference cues, it takes a highly skilled pilot to interpret, and then apply, this data intelligently. If one cannot translate this information quickly, precisely and accurately (and it takes an instrument-rated pilot to do so), one would have ZERO SITUATIONAL AWARENESS. I.e., the pilot wouldn't have a clue where s/he was in relation to the earth. Flight under such conditions is referred to as "IFR", or Instrument Flight Rules." "According to FAA radar controllers, "Flight 77" then suddenly pops up over Washington DC and executes an incredibly precise diving turn at a rate of 360 degrees/minute while descending at 3,500 ft/min, at the end of which "Hanjour" allegedly levels out at ground level. Oh, I almost forgot: He also had the presence of mind to turn off the transponder in the middle of this incredibly difficult maneuver (one of his instructors later commented the hapless fellow couldn't have spelt the word if his life depended on it)." "The maneuver was in fact so precisely executed that the air traffic controllers at Dulles refused to believe the blip on their screen was a commercial airliner. Danielle O'Brian, one of the air traffic controllers at Dulles who reported seeing the aircraft at 9:25 said, "The speed, the maneuverability, the way that he turned, we all thought in the radar room, all of us experienced air traffic controllers, that that was a military plane."" "And then, all of a sudden we have magic. Voila! Hanjour finds the Pentagon sitting squarely in his sights right before him." "But even that wasn't good enough for this fanatic Muslim kamikaze pilot. You see, he found that his "missile" was heading towards one of the most densely populated wings of the Pentagon-and one occupied by top military brass, including the Secretary of Defense, Rumsfeld. Presumably in order to save these men's lives, he then executes a sweeping 270-degree turn and approaches the building from the opposite direction and aligns himself with the only wing of the Pentagon that was virtually uninhabited due to extensive renovations that were underway (there were some 120 civilians construction workers in that wing who were killed; their work included blast-proofing the outside wall of that wing)." "I shan't get into the aerodynamic impossibility of flying a large commercial jetliner 20 feet above the ground at over 400 MPH. A discussion on ground effect energy, tip vortex compression, downwash sheet reaction, wake turbulence, and jetblast effects are beyond the scope of this article (the 100,000-lb jetblast alone would have blown whole semi-trucks off the roads.) "Let it suffice to say that it is physically impossible to fly a 200,000- lb airliner 20 feet above the ground at 400 MPH." According to the article, the alledged hijackers would have had to be trained instrument pilots, and thoroughly familiar with the 757/767 six large screen LCD display in order to pilot the aircraft. As the article states, "When flying "blind", I.e., with no ground reference cues, it takes a highly skilled pilot to interpret, and then apply, this data intelligently. If one cannot translate this information quickly, precisely and accurately (and it takes an instrument-rated pilot to do so), one would have ZERO SITUATIONAL AWARENESS. I.e., the pilot wouldn't have a clue where s/he was in relation to the earth. Flight under such conditions is referred to as "IFR", or Instrument Flight Rules." At no time were any of the aircraft flying blind, thus the established facts as to what happened that day are completely consistent with what the article claims. Oops. Paul Nixon The government's version of 9/11 is not established fact... not to those who can read between the lines ![]() |
... "khobar" wrote in news:apTKf.4201$Sp2.2506@fed1read02: "TRUTH" wrote in message ... Thank you for all the responses. It's nice to get other opinions. There's a few things that weren't commented on though. At no time were any of the aircraft flying blind, thus the established facts as to what happened that day are completely consistent with what the article claims. Oops. Paul Nixon The government's version of 9/11 is not established fact... not to those who can read between the lines ![]() Obviously you are reading between the lines - literallly. And I agree that the "Government's version" is not established fact - it's merely consistent with established fact. Paul Nixon |
![]() TRUTH wrote: Thank you for all the responses. It's nice to get other opinions. There's a few things that weren't commented on though. For instance..... "In the case of a Boeing 757 or 767, the pilot would be faced with an EFIS (Electronic Flight Instrumentation System) panel comprised of six large multi-mode LCDs interspersed with clusters of assorted “hard” instruments. These displays process the raw aircraft system and flight data into an integrated picture of the aircraft situation, position and progress, not only in horizontal and vertical dimensions, but also with regard to time and speed as well. When flying “blind”, I.e., with no ground reference cues, it takes a highly skilled pilot to interpret, and then apply, this data intelligently. They weren't *flying blind*. Quite the reverse. it was a lovely day with great visibility. If one cannot translate this information quickly, precisely and accurately (and it takes an instrument-rated pilot to do so), one would have ZERO SITUATIONAL AWARENESS. I.e., the pilot wouldn’t have a clue where s/he was in relation to the earth. Flight under such conditions is referred to as “IFR”, or Instrument Flight Rules." Hence not applicable. It was VFR weather. "According to FAA radar controllers, “Flight 77” then suddenly pops up over Washington DC and executes an incredibly precise diving turn at a rate of 360 degrees/minute while descending at 3,500 ft/min, at the end of which “Hanjour” allegedly levels out at ground level. Oh, I almost forgot: He also had the presence of mind to turn off the transponder in the middle of this incredibly difficult maneuver (one of his instructors later commented the hapless fellow couldn’t have spelt the word if his life depended on it)." The " precise diving turn " is simply someone's imagination. Probably the reporter's version of events. It makes for more 'compelling' copy. "The maneuver was in fact so precisely executed that the air traffic controllers at Dulles refused to believe the blip on their screen was a commercial airliner. Danielle O’Brian, one of the air traffic controllers at Dulles who reported seeing the aircraft at 9:25 said, “The speed, the maneuverability, the way that he turned, we all thought in the radar room, all of us experienced air traffic controllers, that that was a military plane.”" That's because they don't normally see commerical planes flown like that ! It doesn't mean it can't be done. Commercial flights have regard to passenger sensitivities. "And then, all of a sudden we have magic. Voila! Hanjour finds the Pentagon sitting squarely in his sights right before him." Typical journalist hype. The journalist wan't there on the flight deck was he so how does he or anyone else know what Hanjour *saw* ? Etc. Yawn. Graham |
Truth,
The consensus of the 9/11 Truth Movement Ah, the 9/11 Truth Movement! Thanks for giving me the laugh of the day. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote in
: Truth, The consensus of the 9/11 Truth Movement Ah, the 9/11 Truth Movement! Thanks for giving me the laugh of the day. Yes! And I shall have the last laugh. Believe me. |
One day at school, a fourth grade teacher ask the students
what their daddy did for a living. All the kids said the usual stuff. Doctor, lawyer, butcher, car mechanic, banker, carpenter..... One little girl said her daddy was an exotic dancer in a gay bar. He took his clothes off and danced for men. If he was offered money, he'd even go home with the customers and have sex with them. The teacher was shocked and stopped the "lesson" and sent the other kids out to play. The teacher then asked the child if what was said was TRUE. The child said, "No, he is a blogger pushing the theory that 9/11 was a conspiracy by the US government and I was to embarrassed to say so. "TRUTH" wrote in message ... | Thomas Borchert wrote in | : | | Truth, | | The consensus of the 9/11 Truth | Movement | | | Ah, the 9/11 Truth Movement! Thanks for giving me the laugh of the day. | | | | | Yes! And I shall have the last laugh. Believe me. |
Truth,
Yes! And I shall have the last laugh. Believe me. Oh, it's all a matter of belief to you. Sorry, I won't discuss your wacky religion. As for the facts, well, you're wrong. But you can believe all you want. -- Thomas Borchert (EDDH) |
TRUTH wrote: Yes! And I shall have the last laugh. Believe me. ....while wearing the nice white coat with the long sleeves that buckle in the back. |
The whole point of the EFIS display is that a picture is
easier to understand than a few dozen dials. There is no secret anymore about transponders and the hijack codes, turning the transponder off is SOP for a hijackers. If the transponder is on and the aircraft is maneuvering and changing altitude faster than the refresh rate of the radar sweep, it will blank on the screen and go into a coast mode. The hard part of crashing into a particular spot is finding the spot, the Pentagon is easy to see as were the WTC towers, but just try to find the Wal-Mart store from 3,000 feet 15 miles away. Atlantic Ocean, Long Island, Manhattan Island, easy to see and they point to the WTC. "TRUTH" wrote in message ... | Thank you for all the responses. It's nice to get other opinions. There's | a few things that weren't commented on though. | | For instance..... | | "In the case of a Boeing 757 or 767, the pilot would be faced with an | EFIS (Electronic Flight Instrumentation System) panel comprised of six | large multi-mode LCDs interspersed with clusters of assorted "hard" | instruments. These displays process the raw aircraft system and flight | data into an integrated picture of the aircraft situation, position and | progress, not only in horizontal and vertical dimensions, but also with | regard to time and speed as well. When flying "blind", I.e., with no | ground reference cues, it takes a highly skilled pilot to interpret, and | then apply, this data intelligently. If one cannot translate this | information quickly, precisely and accurately (and it takes an | instrument-rated pilot to do so), one would have ZERO SITUATIONAL | AWARENESS. I.e., the pilot wouldn't have a clue where s/he was in | relation to the earth. Flight under such conditions is referred to as | "IFR", or Instrument Flight Rules." | | | "According to FAA radar controllers, "Flight 77" then suddenly pops up | over Washington DC and executes an incredibly precise diving turn at a | rate of 360 degrees/minute while descending at 3,500 ft/min, at the end | of which "Hanjour" allegedly levels out at ground level. Oh, I almost | forgot: He also had the presence of mind to turn off the transponder in | the middle of this incredibly difficult maneuver (one of his instructors | later commented the hapless fellow couldn't have spelt the word if his | life depended on it)." | | "The maneuver was in fact so precisely executed that the air traffic | controllers at Dulles refused to believe the blip on their screen was a | commercial airliner. Danielle O'Brian, one of the air traffic controllers | at Dulles who reported seeing the aircraft at 9:25 said, "The speed, the | maneuverability, the way that he turned, we all thought in the radar | room, all of us experienced air traffic controllers, that that was a | military plane."" | | "And then, all of a sudden we have magic. Voila! Hanjour finds the | Pentagon sitting squarely in his sights right before him." | | "But even that wasn't good enough for this fanatic Muslim kamikaze pilot. | You see, he found that his "missile" was heading towards one of the most | densely populated wings of the Pentagon-and one occupied by top military | brass, including the Secretary of Defense, Rumsfeld. Presumably in order | to save these men's lives, he then executes a sweeping 270-degree turn | and approaches the building from the opposite direction and aligns | himself with the only wing of the Pentagon that was virtually uninhabited | due to extensive renovations that were underway (there were some 120 | civilians construction workers in that wing who were killed; their work | included blast-proofing the outside wall of that wing)." | | "I shan't get into the aerodynamic impossibility of flying a large | commercial jetliner 20 feet above the ground at over 400 MPH. A | discussion on ground effect energy, tip vortex compression, downwash | sheet reaction, wake turbulence, and jetblast effects are beyond the | scope of this article (the 100,000-lb jetblast alone would have blown | whole semi-trucks off the roads.) | | "Let it suffice to say that it is physically impossible to fly a 200,000- | lb airliner 20 feet above the ground at 400 MPH." | | | | | According to the article, the alledged hijackers would have had to be | trained instrument pilots, and thoroughly familiar with the 757/767 six | large screen LCD display in order to pilot the aircraft. | | Also, how did the alledged highjacker fly into the Pentagon and make that | expert maneuver? Where's the 757 wreakage? How did such a large plane | make such a small hole? What about Sagadevan's comments about it not | being physically possible to fly a 757 twenty feet above the ground at | 400MPH? | | | | To answer some of your questions... The consensus of the 9/11 Truth | Movement is that the planes were flown remote control, and that the | passengers' voices were synthesized using a new technology. (One piece of | evidence for this is this cell phone call quote from a passenger: "Hello | mom, this is Mark Bingham." When was the last time your called your | mother and announced your last name?) Very weird... |
![]() TRUTH wrote: "In the case of a Boeing 757 or 767, the pilot would be faced with an EFIS (Electronic Flight Instrumentation System) panel comprised of six large multi-mode LCDs interspersed with clusters of assorted “hard” instruments. These displays process the raw aircraft system and flight data into an integrated picture of the aircraft situation, position and progress, not only in horizontal and vertical dimensions, but also with regard to time and speed as well. When flying “blind”, I.e., with no ground reference cues, it takes a highly skilled pilot to interpret, and then apply, this data intelligently. If one cannot translate this information quickly, precisely and accurately (and it takes an instrument-rated pilot to do so), one would have ZERO SITUATIONAL AWARENESS. I.e., the pilot wouldn’t have a clue where s/he was in relation to the earth. Flight under such conditions is referred to as “IFR”, or Instrument Flight Rules." It was a clear sunny day so everything you said above is irrelavant. Also it does not take an instrument rated pilot to do lok at the EFIS and determine where you are. It is much easier to tell where you are BECAUSE of the EFIS. "According to FAA radar controllers, “Flight 77” then suddenly pops up over Washington DC The radar controller never said he popped up without warning. and executes an incredibly precise diving turn at a rate of 360 degrees/minute There was nothing incredibly precise about it, or did there need to be. while descending at 3,500 ft/min, A descent of that rate is in the middle of the normal range for an airliner. at the end of which “Hanjour” allegedly levels out at ground level. He didn't level out, he crashed into the building. Oh, I almost forgot: He also had the presence of mind to turn off the transponder in the middle of this incredibly difficult maneuver If you know where it is it's like turning off a light. (one of his instructors later commented the hapless fellow couldn’t have spelt the word if his life depended on it)." He was a foreigner, spelling was not second nature. "The maneuver was in fact so precisely executed that the air traffic controllers at Dulles refused to believe the blip on their screen was a commercial airliner. Danielle O’Brian, one of the air traffic controllers at Dulles who reported seeing the aircraft at 9:25 said, “The speed, the maneuverability, the way that he turned, we all thought in the radar room, all of us experienced air traffic controllers, that that was a military plane.”" Because it was unexpecte, not because it was difficult. "And then, all of a sudden we have magic. Voila! Hanjour finds the Pentagon sitting squarely in his sights right before him." Have you seen a picture of the area from the air? Antbody could pick out the Pentagon. "But even that wasn’t good enough for this fanatic Muslim kamikaze pilot. You see, he found that his “missile” was heading towards one of the most densely populated wings of the Pentagon—and one occupied by top military brass, including the Secretary of Defense, Rumsfeld. He wouldn't have any idea who occupied that part of the Pentagon. Presumably in order to save these men’s lives, he then executes a sweeping 270-degree turn and approaches the building from the opposite direction and aligns himself with the only wing of the Pentagon that was virtually uninhabited due to extensive renovations that were underway (there were some 120 civilians construction workers in that wing who were killed; their work included blast-proofing the outside wall of that wing)." He did that because he was going to miss the building on his first attempt. "I shan’t get into the aerodynamic impossibility of flying a large commercial jetliner 20 feet above the ground at over 400 MPH. Nothing impossible about it. A discussion on ground effect energy, No such thing. tip vortex compression, You're making **** up. downwash sheet reaction, Now that's just funny. wake turbulence, and jetblast effects are beyond the scope of this article Wake turbulence and jet blast affect aircraft behind the one making it. (the 100,000-lb jetblast alone would have blown whole semi-trucks off the roads.) Sure, if the trucks were within a couple hundred feet and the aircraft was sitting on the ground. But a flying aircraft cannot blow any vehicle over. "Let it suffice to say that it is physically impossible to fly a 200,000- lb airliner 20 feet above the ground at 400 MPH." It's well within the capabilities of every airliner. According to the article, the alledged hijackers would have had to be trained instrument pilots, No. and thoroughly familiar with the 757/767 six large screen LCD display in order to pilot the aircraft. No. |
Aeronautical Engineer says Official 9/11 Story Not Possible | Robert M. Gary | Piloting | 1 | March 14th 06 12:44 AM |
Aeronautical Engineer says Official 9/11 Story Not Possible | Miss L. Toe | Piloting | 11 | February 23rd 06 02:25 PM |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Funny story about piloting | [email protected] | Piloting | 0 | December 20th 04 12:34 AM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
