Earlier, Richard Isakson wrote:
With my quick and dirty assumptions, I found that the spar would yield at 4.4 g's at 600 pounds gross weight. That is looking at bend moment stresses only. A betters analysis would raise that number. This includes the inserts. Without the inserts the spar yield at 2.3 g's at 600 pounds and 2.8 g's at 500 pounds. Interesting. When I run the moment of inertia for 2" tubing of .058" wall, I get 0.1667 in^4. Using that number and a yield strength of 35 ksi I get a yield moment of 5833 in/lbs. Do those numbers agree with yours? Of course, those figures disregard cripling or buckling, which I've not seen mentioned in this thread. I suspect that this whole thing will come down to a somewhat subjective matter of distributions and deflections. The distribution of loads between the forward and aft spars will make a big difference, and I think that the wing deflection will start to look scary before the spar tubes reach yield. But those are just more non-engineer's guesses, and there's been plenty too much of those already. Taking this out on a tangent, one thing about little airplanes like this that I don't understand is why so many of them use tubular spars. It seems to me that you can get so much better strength/weight and stiffness/weight using a built-up I-beam or C-section spar. Yeah, it's a bit more trouble. But the result is either better strength and stiffness for the same weight, or the same strength for less weight. But again, that's just my non-engineer wing developer perspective. Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
("Richard Isakson" wrote)
[snip] I've never liked powered ultralights that use the US part 103 definition of ultralight. The FAA limited the empty weight to far too light a weight. They could have added a hundred pounds to the empty weight and kept the other limitations as they are. This would have produced a real viable airplane class. Agreed, almost. 350 lbs would have been great (without floats). Low stall number is fine, but let's remove the speed limit on the upper end. If it weighs X and stalls at Y, carries one person and (8g) gallons of fuel ...who cares about its top-end speed! Montblack Hell ...I'M not 103 legal !!! :-) |
Richard Lamb and the Texas Parasol Plans ...and Sirius Aviation | Richard Lamb | Home Built | 12 | August 9th 05 08:00 PM |
want to trade 601 plans for 701 plans | [email protected] | Home Built | 0 | January 27th 05 07:50 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Texas Soars into Aviation History | A | Piloting | 7 | December 17th 03 02:09 AM |
good book about prisoners of war | Jim Atkins | Military Aviation | 16 | August 1st 03 10:18 AM |
