Or even had the wrong airport chart. Something was
certainly wrong, we know what happened from the NTSB report, but why has not been answered. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Wizard of Draws" wrote in message news:C038EDAE.66524%jeffbREMOVE@REMOVEwizardofdraw s.com... | On 3/11/06 7:13 PM, in article SPJQf.116929$QW2.4426@dukeread08, "Jim | Macklin" wrote: | | The entire approach was flown improperly. And the missed | approached was out of the protected area and as you said, | does require an immediate climbing turn. | | | I wonder if they had current, or correct charts, or even looked at it from | the way the approach was flown. | -- | Jeff 'The Wizard of Draws' Bucchino | | Cartoons with a Touch of Magic | http://www.wizardofdraws.com | | More Cartoons with a Touch of Magic | http://www.cartoonclipart.com | |
In article SPJQf.116929$QW2.4426@dukeread08,
says... The entire approach was flown improperly. And the missed approached was out of the protected area and as you said, does require an immediate climbing turn. Everything in the report suggests they did not realize they were past the airport, or the MAP. Perhaps they knew they had to turn right, but they probably had no idea they were out of the protected area, and thus didn't see the urgency of it. We all know about "expect to land" syndrome, and the unpreparedness for the missed that results from it. All the more in that the preceding crew landed easily. It seems they were, as others here suggest, thrown a curve by the unexpected early clearance, then misread the GPS, which had already cycled to the last programmed point. What do you bet if they didn't have the GPS, they would have used the DME, and it would have been second nature to them to check what it was tuned to. They may not have lost situational awareness and bumbled along as they did, seemingly waiting for something to happen in their favor. We can guess they may have been discussing the situation, trying to figure out where they were - but then we don't really know. . . GF |
The failure to make a climbing right turn missed approach
was just the last link in a long chain of errors. I would describe the crew as "head up and locked" because anytime you have any question about your position on an approach, a climb is in order and if the crew had cross-checked any of the readouts that were in front of them, they would have [should have] known they were about to kill their passengers. The King Air had RMI, HSI, DME, a GPS all with dual displays and a two person crew... why they failed to perform is subject to interpretation. They were in a hurry? They were careless? They had equipment problems that were not reported? Food poisoning? -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Greg Farris" wrote in message ... | In article SPJQf.116929$QW2.4426@dukeread08, | says... | | | The entire approach was flown improperly. And the missed | approached was out of the protected area and as you said, | does require an immediate climbing turn. | | | Everything in the report suggests they did not realize they were past the | airport, or the MAP. Perhaps they knew they had to turn right, but they | probably had no idea they were out of the protected area, and thus didn't | see the urgency of it. | | We all know about "expect to land" syndrome, and the unpreparedness for | the missed that results from it. All the more in that the preceding crew | landed easily. It seems they were, as others here suggest, thrown a curve | by the unexpected early clearance, then misread the GPS, which had | already cycled to the last programmed point. | | What do you bet if they didn't have the GPS, they would have used the | DME, and it would have been second nature to them to check what it was | tuned to. They may not have lost situational awareness and bumbled along | as they did, seemingly waiting for something to happen in their favor. We | can guess they may have been discussing the situation, trying to figure | out where they were - but then we don't really know. . . | | GF | |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
18 Oct 2005 - Todays Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | October 19th 05 02:19 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
12 Dec 2003 - Todays Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
