![]() wrote: I'm pretty sure where the prop stops doesn't measure anything. How do you know it stopped in the same place "horizontally" each time? Because I've been watching it carefully for 3 years. A prop that stops in an unusual position can indicate a cylinder with poor compression, as I discovered when I had cylinder trouble 3 years ago. There are at least two possibilities. Why would the prop stop in a preferential position anyway? Seems like it would be on any one of the 4 compression strokes. Becaues of the crankshaft geometry of the horizonally-opposed Lyc. O-360, the prop will stop in the same compass position every time as it bounces back from the last TDC. I'm also convinced that even the differential compression check doesn't show what you really want to know. The rings are AC coupled, tho less so in the Lycomings. ? So I'd guess one would need something worse to worry about. Maybe price of gas or user fees! No. Something has changed, and that's something to worry about. -- Dan C172RG at BFM |
![]() Update: I went to the airport first thing this morning to turn the prop with the engine cold. As before, I felt good compression at each cylinder, and the prop stopped at 02:30/04:30. So I ran the engine for 3-4 minutes, just to get the oil a little warm, and shut it down. Voila': the prop stopped at its usual 09:00/03:00 position. I don't know WTF to think, now. Wait a minute, yes I do: I think I'll have a couple of Coronas and forget about it.. -- Dan C-172RG at BFM |
Dan -
Does the engine always feel tight only when hot? If so, as a precaution, do an oil analysis next change or next time the cowl is off. Don't waste money on a more formal compression test. You don't have top end trouble, but you just might have a problem at the bottom end. |
![]() "nrp" wrote in message Dan - Does the engine always feel tight only when hot? No. If so, as a precaution, do an oil analysis next change or next time the cowl is off. Don't waste money on a more formal compression test. You don't have top end trouble, but you just might have a problem at the bottom end. Like what? |
the bottom end. I mentioned that to my wife a few days back... and got slapped... |
Like what? Possibly, and I want to emphasize just possibly - a shelled
out camshaft system contaminating the crank bearings such that they shrink onto the crankshaft on cooldown. An oil filter check (assuming there is one) would also show if something is shelling out. Maybe even just looking critically at the oil on the dipstick would show aluminum or steel "paint" immediately after a shutdown. |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
GPS and old-fashioned thinking? | G Farris | Instrument Flight Rules | 92 | December 22nd 05 05:39 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
3 blade prop position on 6cyl engine. | Paul Lee | Home Built | 3 | February 26th 04 12:47 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
