With the wind?
Old April 5th 06, 11:38 AM posted to rec.aviation,rec.aviation.piloting
Default With the wind?
"Greg Farris" wrote in message
The same thing
happens at any major airport, changing to the other runway is quite a
production.
Yeah, I was a passenger on a commercial flight into Schiphol (Amsterdam)
last year; the captain came onto the intercom to say: "We were second in
line to land, and they just changed runways on us". Took us the best part of
15-20 minutes to muck about and get down.
I have also seen airports where the apron and terminal are all the way on
one end of the runway. In these cases pilots sometimesprefer to take a
slight tailwind to land toward their destination, rather than have to
taxi back.
We used to see this a lot at Norwich (probably still do if they've reopened
04 - last time I flew there it was shut for maintenance). The main runway is
27/09, but we also have 04/22. The terminal is right at the starting end of
04 (in fact, there's a displaced threshold because the terminal building is
in the way). So the smaller commercial aircraft, particularly those heading
to Amsterdam, would often choose 04 if the wind was within limits, because
it was only a 60-second taxi and a quick right turn instead of a drive
around the airfield.
D.
  #32
Old April 5th 06, 11:46 AM posted to rec.aviation.piloting
On Wed, 05 Apr 2006 01:21:56 GMT, "Steven P. McNicoll"
Maverick: "Requesting permission for flyby."
"Cleared for the option"
All right, all right! I hear this all the time (well, I hear it
sometimes) at PSM nearby.
What does "cleared for the option" mean? Is it any whim on the part of
the pilot in the pattern, like a touch&go?
In other words, is it a way of saying "your request is approved"?
(The problem, I suppose, is that with a handheld I didn't hear the
request.)
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
In Search of Lost Time: www.readingproust.com
  #34
Old April 5th 06, 11:50 AM posted to rec.aviation.piloting
On Tue, 04 Apr 2006 14:15:24 -0400, Peter Clark
The local airport PSM has a single runway, with the SE end more or
less pointing toward the small city nearby. I believe the "calm"
status is defined as up to 7 knots (possibly 7 mph). So if the wind is
blowing 7 knots or less, you take off to the NW. Perhaps your airfield
has a like orientation and reason for taking off into the wind.
With 11,300' of runway at sea level you could have a 20 knot tailwind
and still not worry
Indeed, I could land on the crosswise taxiways at Pease.
(And of course I meant to say *with* the wind.)
  #35
Old April 5th 06, 02:31 PM posted to rec.aviation.piloting
It means the pilot can land to a full stop, or touch and go, or do a low
approach to the runway ("peek and go?") without advising the controller
which option he will pick. Otherwise, if you are cleard for (say) a
touch and go, you are not cleared to do a full stop landing - you'd have
to tell him you want a full stop and he would have to clear you for that.
Jose
Nothing takes longer than a shortcut.
  #36
Old April 5th 06, 10:42 PM posted to rec.aviation,rec.aviation.piloting
David Cartwright wrote:
"Newps" wrote in message
Baloney. If you get a chance go to any big airport on a day with light
winds. Most of these airports have preferred runways, landing in a
particular direction is preferred by the controllers for any number of
reasons. If the wind shifts to make that runway a tailwind, but it's only
5 knots or so, you will land with a tailwind or you will go somewhere
else. Same as my previous example about the crosswind.
Frankly, if a controller tells me I'm to land with a tailwind, he can get
stuffed.
That's fine. You land with the flow or you don't land. Your inability
to handle a 5 knot tailwind is not my problem.
Aside from the "hey, that fence is rushing at me quite quickly"
factor,
If a 5 knot tailwind does that to you, you are way too fast on final.
you also have the issue of the extra strain it's putting on the
tyres/landing gear because the ground speed is so much higher.
Yep, 5 knots. A real tire buster.
  #37
Old April 5th 06, 10:44 PM posted to rec.aviation.piloting
As well as a stop and go.
  #38
Old April 6th 06, 02:22 AM posted to rec.aviation,rec.aviation.piloting
"David Cartwright" wrote in message
stuffed. Aside from the "hey, that fence is rushing at me quite quickly"
factor, you also have the issue of the extra strain it's putting on the
So would you go somewhere else or land without a clearance?
I've been a passenger in a light aircraft where the controller has
insisted on the PIC using a particular (shortish) runway with a tailwind,
though. Fortunately, the PIC was (a) a 14,000-hour veteran and (b) a
stroppy, but polite old git. The discussion was an interesting one to
hear, but the one-sentence summary goes something like: "You don't have a
clue what you're saying, you don't have the performance documents or POH
for this aircraft to hand, and you're not responsible for the safety of
this aircraft; I am, though, so I'm going to do a visual approach to RWXX
instead, and you can lump it. When we're safely on the ground, if you want
to come and argue with me, that's fine". To the controller's credit, we
sat and had a coffee with him later and both sides explained their point
of view in a grown-up manner, and the controller went away with the
understanding that if we'd landed with the tailwind, we stood a good
chance of being in the hedge at the other end.
Did he land without a clearance?
  #39
Old April 6th 06, 02:23 AM posted to rec.aviation.piloting
"Cub Driver" usenet AT danford DOT net wrote in message
CLEARED FOR THE OPTION- ATC authorization for an aircraft to make a
touch-and-go, low approach, missed approach, stop and go, or full stop
landing at the discretion of the pilot. It is normally used in training so
that an instructor can evaluate a student's performance under changing
situations.
  #40
Old April 6th 06, 02:43 AM posted to rec.aviation,rec.aviation.piloting
The PIC can always say UNABLE, a magic word to controllers.
The controller cannot turn the whole airport around at a
busy air carrier airport, there may be dozens of airplanes
in trail for a hundred miles. But the PIC can usually work
something out to get a more favorable runway within a
reasonable time. It helps if you can fly your approach at
higher speeds, nothing like getting a C172 at 62 knots on
final to really slow the airport down.
Don't accept a clearance you can't safely fly, and practice
some non-standard operations to find out how to fly fast and
slow down for the landing.
Most POHs show landing distances with a tailwind, but you
should understand that many pilots fly and land too fast and
waste a lot of runway and have other landing problems [wheel
barrow]. Tires have a speed limit, but that is usually not
a problem on light aircraft.
If you want to fly to a big, busy airport with noise
problems, learn to deal with it.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Steven P. McNicoll" wrote in
message
nk.net...
message
me quite quickly"
putting on the
higher.
clearance?
controller has
with a tailwind,
veteran and (b) a
interesting one to
"You don't have a
documents or POH
for the safety of
approach to RWXX
ground, if you want
away with the
stood a good
Outfly the wind Doug Piloting 7 July 6th 05 03:18 PM
LX4000 wind calculation AttentionLEcureuil Soaring 2 June 23rd 04 04:33 AM
