Scheibe/Alliance SF-34
Old April 7th 06, 04:29 AM posted to rec.aviation.soaring
Default Scheibe/Alliance SF-34
Bob:
Quite simple actually. Max gross weight doesn't change, but as gliders
get older and equipment is added or someone paints over the old gel
without grinding down to the glass, or grinds down to the glass them
repaints/gels and profiles the wings, they seem to get heavier. More
so if some repairs have been made. George is correct in that the glider
is most likely stronger, but increased strength does nothing for the
useful load. If the weight of the glider increases, but the max gross
doesn't then what suffers? The useful load.
Regards,
Billy Hill
Old April 6th 06, 08:58 AM posted to rec.aviation.soaring
Hi,
The build quality of the scheibe SF34s is very *variable*
There has been one case in the UK where the rear fuselage
failed in flight (but fortunately didn't quite fall
off)
Not sure if there are any details available on the
BGA website
The SF also has less span than a K21 or Grob so I'm
surprised at those who say it climbs better in weak
lift
