"Bill Zaleski" wrote in message
... the current PTS became effective in March 1999. AFS 640, the branch of the FAA that sets training policy, told me during the last examiner recertification seminar that the PTS is binding, and the task table Bill, The question of whether the PTS is legally binding upon a CFII is a bit more complex than this, as is often the case for areas where law and administrative regulations overlap. Your answer is sort of like saying you called a specific division of the IRS for a ruling on a complex taxation and that gave you a definitive answer. Actually, getting a definitive answer on federal tax regulations is quite complex and often has gray areas until a court reaches a final decision. Sometimes courts even give different answers in different districts around the country. It is very clear that the Advanced ATD concept was introduced after the 1999 PTS and that the Advanced ATD was intended for completing a full IPC. Yet if the PTS is considered to be legally binding, the Advanced ATD cannot be used for an IPC because a literal interpretation of the PTS requires landing out of an approach for an IPC, yet no Advanced ATD and no FTD is approved for landings. Thus if the PTS is legally binding then a huge percentage of piston IPCs done at virtually every major simulator center in the past 5 years are invalid. And if the PTS is legally binding then the whole concept of approving the Advanced ATD is inconsistent within the FAA's regulatory framework. I think the best answer is that there are some unclear or gray areas here which need to be resolved. Saying the PTS is obviously legally binding rather than advisory is like saying the AIM is obviously legally binding. Do you believe items in the AIM are advisory or binding? -------------------- Richard Kaplan, CFII www.flyimc.com |
![]() Do you believe items in the AIM are advisory or binding? They are advisory until there is an accident. Then they were binding. I say this tongue in cheek, but it does seem to be the FAA way. Jose -- (for Email, make the obvious changes in my address) |
On Mon, 07 Jun 2004 11:48:39 GMT, "Richard Kaplan"
wrote: "Bill Zaleski" wrote in message .. . the current PTS became effective in March 1999. AFS 640, the branch of the FAA that sets training policy, told me during the last examiner recertification seminar that the PTS is binding, and the task table Bill, The question of whether the PTS is legally binding upon a CFII is a bit more complex than this, as is often the case for areas where law and administrative regulations overlap. Your answer is sort of like saying you called a specific division of the IRS for a ruling on a complex taxation and that gave you a definitive answer. Actually, getting a definitive answer on federal tax regulations is quite complex and often has gray areas until a court reaches a final decision. Sometimes courts even give different answers in different districts around the country. It is very clear that the Advanced ATD concept was introduced after the 1999 PTS and that the Advanced ATD was intended for completing a full IPC. Yet if the PTS is considered to be legally binding, the Advanced ATD cannot be used for an IPC because a literal interpretation of the PTS requires landing out of an approach for an IPC, yet no Advanced ATD and no FTD is approved for landings. Thus if the PTS is legally binding then a huge percentage of piston IPCs done at virtually every major simulator center in the past 5 years are invalid. And if the PTS is legally binding then the whole concept of approving the Advanced ATD is inconsistent within the FAA's regulatory framework. I think the best answer is that there are some unclear or gray areas here which need to be resolved. Saying the PTS is obviously legally binding rather than advisory is like saying the AIM is obviously legally binding. Do you believe items in the AIM are advisory or binding? -------------------- Richard Kaplan, CFII www.flyimc.com So, in effect, you are saying that those who wrote the PTS are not in a position to provide accurate information on it's use, validity, or legality. Again, laughable. Who do you plan to go to for any meaningful guidance? You've already said that the FSDO's don't know how to handle queries on this issue. I recall giving you information on the use of the FTD without an instructor present for currency that you were steadfast against until the simulator branch confirmed to you what you didn't want to hear. Time to use common sense here. It wouldn't be called an STANDARD (PTS). if it wasn't a standard. Yup, it's binding. Call 'em up like you finally did last time. |
... recertification seminar that the PTS is binding, and the task table provided within sets the minimum areas of operation required to complete an IPC. The term "representative tasks" are not at the I have now spoken with most of the simulator/FTD manufacturers in the industry. The consensus overall based upon multiple contact with various FAA sources is that existing FTDs will remain legal for a full IPC. The basis for this is that in the newest PTS there is a footnote to Appendix 1-1 indicating that FTDs which are now operating via a letter from the FAA Administrator may continue to be used for their original acceptable use. In other words, my FTD was originally approved for an IPC and therefore it will remain approved for an IPC even with then new PTS goes into effect. -------------------- Richard Kaplan, CFII www.flyimc.com |
industry. The consensus overall based upon multiple contact with various FAA sources is that existing FTDs will remain legal for a full IPC. The basis for this is that in the newest PTS there is a footnote to Appendix 1-1 indicating that FTDs which are now operating via a letter from the FAA Administrator may continue to be used for their original acceptable use. In other words, my FTD was originally approved for an IPC and therefore it will remain approved for an IPC even with then new PTS goes into effect. There are two relevant notes in that appendix: NOTE: Users of the following chart are cautioned that use of the chart alone is incomplete. The description and Objective of each TASK as listed in the body of the practical test standard, including all NOTEs, must also be incorporated for accurate simulation device use. NOTE: 1. Level 1 FTDs that have been issued a letter authorizing their use by the FAA Administrator, may continue to be used only for those TASKs originally found acceptable. It seems to me that these notes are intended to RESTRICT FTD use, by preventing someone with a Level 1 FTD from doing something that wasn't originally approved. I don't see how it would grandfather in all FTDs for any original acceptable use. Barry |
Roy Smith wrote in message ...
In article m, "Richard Kaplan" wrote: "Robert M. Gary" wrote in message om... I"m not sure how far back you're going. My IFR PTS is pretty old but still includes a table of things required for a PC. I think that a lot of CFIIs just didn't know what an IPC was. The difference is that the prior PTS versions did not state that all the IPC items in the table are required for an IPC; thus a reasonable interpretation has been that 61.57(d) givet a CFII the discretion to choose among those items. The newest PTS now explicitly states that all IPC items in the table must be included in an IPC. I seem to remember there used to be wording to the effect that an ICC/IPC needed to include a "representative sample" of the PTS checkride tasks. I can't remember if that was in the PTS itself or part 61/91 somewhere. Or maybe it's just a faulty memory circuit? That being said, I'm about to give my first IPC in an plane with an approach certified GPS. I spent some time re-reading the PTS to make sure my plan is up to snuff, and here's what I came up with for the flight portion: Actually, if you read the current PTS, you will notice that in the table of tasks to be done, there is a column for IPC. Today, the PTS spells out the IPC. You can call AOPA and hear it for yourself. Of course you can argue the PTS is not regulatory. One guy tried to argue that the AIM wasn't regulatory too. The NASA admin law judge didn't seem to buy that story either. Right or wrong doesn't make any difference, its all what the judge is going to say when you plead to keep your ticket. -Robert |
![]() "Robert M. Gary" wrote in message om... Actually, if you read the current PTS, you will notice that in the table of tasks to be done, there is a column for IPC. Today, the PTS spells out the IPC. You can call AOPA and hear it for yourself. Of There is nothing in the current PTS which states that the ENTIRE table has to be conducted on every IPC; 61.57(d) allows a CFII the discretion to select representative tasks from that list. -------------------- Richard Kaplan, CFII www.flyimc.com |
to be conducted on every IPC; 61.57(d) allows a CFII the discretion to select representative tasks from that list. Page 2 of the current PTS states: Applicants for an instrument proficiency check required by 14 CFR section 61.57, must perform to the standards of the TASKS listed under PC in the Rating Task Table on page 15. The Rating Task Table heading states: Required TASKS are indicated by either the TASK letter(s) that apply(s) or an indication that all or none of the TASKS must be tested. Note the word "required". These two statements, taken together, indicate to me that the intent was to require all items on the table. (The FAA's Part 61 FAQ, though admittedly not regulatory, also supports this view.) One can claim that there's some ambiguity, and that the list is not legally binding. However, if this interpretation is wrong, the CFII jeopardizes not just himself, but also the pilots to whom he provides the endorsement. Is this something a conscientious CFII should do? In the absence of a formal FAA interpretation, I feel obligated to make a good faith effort to comply by including all the "required" items. Barry |
"Barry" wrote in message ...
himself, but also the pilots to whom he provides the endorsement. Is this something a conscientious CFII should do? In the absence of a formal FAA interpretation, I feel obligated to make a good faith effort to comply by including all the "required" items. How about if I do an IPC in an airplane on a day when weather is below circling minimums at the aiport where the IPC is conducted? That seems like an excellent way to assess an instrument pilot's capabilities, yet there is no way to conduct a circling approach. Should the conscientious CFII not do the IPC and thus miss this opportunity? Should the conscientious CFII require a return to conduct a circling approach on another day to complete the IPC? And how do we reconcile this with the FAA Inspector's Handbook clearly approves of an IPC in a Level 1 FTD which cannot perform circling approaches? -------------------- Richard Kaplan, CFII www.flyimc.com |
![]() On Mon, 07 Jun 2004 16:41:32 GMT, "Richard Kaplan" wrote: "Robert M. Gary" wrote in message . com... Actually, if you read the current PTS, you will notice that in the table of tasks to be done, there is a column for IPC. Today, the PTS spells out the IPC. You can call AOPA and hear it for yourself. Of There is nothing in the current PTS which states that the ENTIRE table has to be conducted on every IPC; 61.57(d) allows a CFII the discretion to select representative tasks from that list. -------------------- Richard Kaplan, CFII www.flyimc.com Once again, READ the info at the top of the current rating task table. It states"AREA OF OPERATION Required TASKS are indicated by either the TASK letter(s) that apply(s) or an indication that all or none of the TASKS must be tested. What does the word "MUST" mean to you? |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
CFI logging instrument time | Barry | Instrument Flight Rules | 21 | November 11th 03 12:23 AM |
Instrument Rating Ground School at Central Jersey Regional (47N) | john price | Instrument Flight Rules | 0 | October 29th 03 12:56 PM |
Instrument Rating Ground School at Central Jersey Regional (47N) | john price | Instrument Flight Rules | 0 | October 12th 03 12:25 PM |
Use of hand-held GPS on FAA check ride | Barry | Instrument Flight Rules | 1 | August 9th 03 09:25 PM |
