Changes in Instrument Proficiency Check Requirements
Old June 8th 04, 06:17 AM
Richard Kaplan
"Bill Zaleski" wrote in message
wouldn't be called an STANDARD (PTS). if it wasn't a standard. Yup,
it's binding. Call 'em up like you finally did last time.
I do appreciate your help regarding the prior issue. Your advice was quite
correct and was confirmed by my inquiry to multiple FAA sources, by my
cross-check with multiple FAA written documents, and by inquiry to my FTD
manufacturer.
In this case the situation is different: every FTD manufacturer in
existence without exception supports the use of an FTD for a complete IPC
today, several FAA documents and personnel do support the use of an FTD for
an IPC, and every FTD manufacturer I have spoken with so far initially was
puzzled by the new PTS but has ultimately come to the conclusion that an IPC
will indeed remain legal in an FTD.
Richard Kaplan, CFII
www.flyimc.com
Old June 7th 04, 05:45 PM
Richard Kaplan
recertification seminar that the PTS is binding, and the task table
provided within sets the minimum areas of operation required to
complete an IPC. The term "representative tasks" are not at the
I have now spoken with most of the simulator/FTD manufacturers in the
industry. The consensus overall based upon multiple contact with various
FAA sources is that existing FTDs will remain legal for a full IPC. The
basis for this is that in the newest PTS there is a footnote to Appendix 1-1
indicating that FTDs which are now operating via a letter from the FAA
Administrator may continue to be used for their original acceptable use. In
other words, my FTD was originally approved for an IPC and therefore it will
remain approved for an IPC even with then new PTS goes into effect.
www.flyimc.com
Old June 7th 04, 09:12 PM
Barry
There are two relevant notes in that appendix:
NOTE: Users of the following chart are cautioned that use of the chart alone
is incomplete. The description and Objective of each TASK as listed in the
body of the practical test standard, including all NOTEs, must also be
incorporated for accurate simulation device use.
NOTE: 1. Level 1 FTDs that have been issued a letter authorizing their use by
the FAA Administrator, may continue to be used only for those TASKs originally
found acceptable.
It seems to me that these notes are intended to RESTRICT FTD use, by
preventing someone with a Level 1 FTD from doing something that wasn't
originally approved. I don't see how it would grandfather in all FTDs for any
Barry
Old June 7th 04, 09:16 PM
Richard Kaplan
"Barry" wrote in message ...
any
Yes, but per the FAA Inspector's Handbook one of the original acceptable
uses is a complete IPC so now an FTD will remain "restricted" to this use.
So for example an IPC will remain possible in a Level 1 FTD but for the
purpose of an IFR checkride the FTD will not be usable for a circling
approach because a circling approach was not originally an explicitly
approved maneuver. This is the text from the Inspector's handbook:
B. For use under 14 CFR§ 61.57(d)(1)(ii). Regulatory authorization for pilot
use of a level 1 FTD to conduct all or part of an instrument competency
check, consisting of a representative number of tasks required for the
instrument rating practical test when given by an authorized instructor:
. Aviation Simulation Technology, Inc.: AST 201 and 300 Models
. ATC Flight Simulator Company: ATC 112H, 610, 710, 810, and 920 Models
. Frasca International, Inc.: 121, 122, 131, 132, 141, 142, 241, 242,
242T, and 342 Models
. Pacer Systems Corporation: MK II Models
www.flyimc.com
Old June 7th 04, 04:36 PM
Robert M. Gary
Roy Smith wrote in message ...
In article m,
"Richard Kaplan" wrote:
"Robert M. Gary" wrote in message
om...
I"m not sure how far back you're going. My IFR PTS is pretty old but
still includes a table of things required for a PC. I think that a lot
of CFIIs just didn't know what an IPC was.
The difference is that the prior PTS versions did not state that all the IPC
items in the table are required for an IPC; thus a reasonable interpretation
has been that 61.57(d) givet a CFII the discretion to choose among those
items.
The newest PTS now explicitly states that all IPC items in the table must be
included in an IPC.
I seem to remember there used to be wording to the effect that an
ICC/IPC needed to include a "representative sample" of the PTS checkride
tasks. I can't remember if that was in the PTS itself or part 61/91
somewhere. Or maybe it's just a faulty memory circuit?
That being said, I'm about to give my first IPC in an plane with an
approach certified GPS. I spent some time re-reading the PTS to make
sure my plan is up to snuff, and here's what I came up with for the
flight portion:
Actually, if you read the current PTS, you will notice that in the
table of tasks to be done, there is a column for IPC. Today, the PTS
spells out the IPC. You can call AOPA and hear it for yourself. Of
course you can argue the PTS is not regulatory. One guy tried to argue
that the AIM wasn't regulatory too. The NASA admin law judge didn't
seem to buy that story either. Right or wrong doesn't make any
difference, its all what the judge is going to say when you plead to
keep your ticket.
-Robert
Old June 7th 04, 05:41 PM
Richard Kaplan
om...
There is nothing in the current PTS which states that the ENTIRE table has
to be conducted on every IPC; 61.57(d) allows a CFII the discretion to
select representative tasks from that list.
www.flyimc.com
Old June 7th 04, 09:40 PM
Barry
Page 2 of the current PTS states:
Applicants for an instrument proficiency check required by 14 CFR section
61.57, must perform to the standards of the TASKS listed under PC in the
Rating Task Table on page 15.
The Rating Task Table heading states:
Required TASKS are indicated by either the TASK letter(s) that apply(s) or an
indication that all or none of the TASKS must be tested.
Note the word "required". These two statements, taken together, indicate to
me that the intent was to require all items on the table. (The FAA's Part 61
FAQ, though admittedly not regulatory, also supports this view.) One can
claim that there's some ambiguity, and that the list is not legally binding.
However, if this interpretation is wrong, the CFII jeopardizes not just
himself, but also the pilots to whom he provides the endorsement. Is this
something a conscientious CFII should do? In the absence of a formal FAA
interpretation, I feel obligated to make a good faith effort to comply by
including all the "required" items.
Barry
Old June 7th 04, 09:42 PM
Richard Kaplan
this
How about if I do an IPC in an airplane on a day when weather is below
circling minimums at the aiport where the IPC is conducted?
That seems like an excellent way to assess an instrument pilot's
capabilities, yet there is no way to conduct a circling approach.
Should the conscientious CFII not do the IPC and thus miss this opportunity?
Should the conscientious CFII require a return to conduct a circling
approach on another day to complete the IPC?
And how do we reconcile this with the FAA Inspector's Handbook clearly
approves of an IPC in a Level 1 FTD which cannot perform circling
approaches?
www.flyimc.com
Old June 7th 04, 11:52 PM
Barry
I'd say this should be treated the same way one would treat a failure of the
glide slope transmitter - go to another airport where the requirement can be
met. If all requirements can't be met, don't sign off the IPC. I'm not
claiming this all makes sense, but it seems to be required.
approaches?
I don't know. It sounds like whoever updated the PTS didn't talk to whoever's
in charge of the Handbook. Maybe there's some kind of waiver. The best way
to find out is probably to ask the FSDO that approved the FTD.
Old June 8th 04, 03:36 AM
Bill Zaleski
On Mon, 07 Jun 2004 16:41:32 GMT, "Richard Kaplan"
. com...
www.flyimc.com
Once again, READ the info at the top of the current rating task table.
It states"AREA
OF
OPERATION
that apply(s) or an indication that all or none of the TASKS
must be tested.
What does the word "MUST" mean to you?
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
CFI logging instrument time Barry Instrument Flight Rules 21 November 11th 03 12:23 AM
Instrument Rating Ground School at Central Jersey Regional (47N) john price Instrument Flight Rules 0 October 29th 03 12:56 PM
Instrument Rating Ground School at Central Jersey Regional (47N) john price Instrument Flight Rules 0 October 12th 03 12:25 PM
Use of hand-held GPS on FAA check ride Barry Instrument Flight Rules 1 August 9th 03 09:25 PM
