T? or F? Acetone In Fuel Said to Increase Mileage
Old April 14th 06, 08:58 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default T? or F? Acetone In Fuel Said to Increase Mileage
On 14 Apr 2006 04:18:55 -0700, "Denny" wrote:
Gee, if a little acetone will do this much good just think about what
putting MEK into the tank will do for your mileage...
Hey! I have a bunch of MEKP. It's *almost* the same thing except for a
few extra oxygen atoms. I'm afraid the IO-470N in the Deb has too
much compression so we might have to use Fat Albert with those lower
compression engines.:-))
Kinda reminds me of a guy who ran up the engines on his Queen Air up
at Terry's. They have manually adjustable waste gates on the turbos.
Blew one of the jugs right off the engine. As I recall the case wasn't
left in that great a shape either.
www.rogerhalstead.com
denny, aka P.T. Barnum
Old April 16th 06, 01:58 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Montblack wrote:
Has this one been around the block a few times?
It was an interesting read.
http://www.pureenergysystems.com/new...00069_Acetone/
"Readily-available chemical added to gas tank in small proportion
improves the fuel's ability to vaporize completely by reducing the
surface tension that inhibits vaporization of some fuel droplets."
http://toyotaownersclub.com/forums/i...howtopic=44575
Chat room chat about acetone - mostly diesel cars.
This is for diesels mostly ...and mogas WITHOUT alcohol in it. A few
ounces/10 gallons is all you use.
Montblack
go ahead try it. see how long your seals last. Acetone is in the same
family as Methyl Ethyl Ketone (MEK).
Michelle
Old April 16th 06, 03:11 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Michelle
So Michelle, are you out west, yet?
We want to hear Michelle's Montanna Maule Mountain Flying Reports!
Old April 16th 06, 02:44 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Michelle
John,
I am on my way west right now.
I officially started west Thursday. I am making several stops in Ohio.
Including the factory that built my travel trailer.
Next stop after that will be Jay and Mary's. Looks like that will be
Wednesday night or more.
Next planned stop Mount Rushmore. Maybe Devil's tower and then into Montana.
Then onto Missoula.
My airplane is at my old boss getting an annual. It will probably be
done in mid to late may....
Michelle
Old April 17th 06, 02:50 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
If you are near Columbus, OH, email me privately.
The BARNSTORMER is closed, perhaps we can sit down for coffee or
something.
eroodATrrohio.com
make the necessary substitution
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
"Tanks on both" checklist item Koopas Ly Piloting 46 December 12th 03 03:42 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 09:14 AM
