![]() Chris Brooks wrote: I am training in the maryland area. I was cleared for an ILS approach to runway 27 at HGR the other day. Here is a plate: http://204.108.4.16/d-tpp/0406/05114I27.PDF I was about 17 miles out at 5000 feet when I got cleared for the approach. My question is, when can I descend to 4000 feet? Anyone? At 17 miles you were not within a published segment of the approach. ATC was required to give you an altitude to maintain and which to cross HAIGS. A proper clearance would have been "X miles from HAIGS. Cross HAIGS at, or above, 4,000, cleared for the ILS Runway 27 approach." The word "established" is inappropriate in this instance. If you did not receive such a clearance you were obligated to maintain 5,000 and question the clearance because 5,000 is not a reasonable altitude to cross HAIGS. REF: ATC Handbook 7110.65P, Paragraph 4-8-1 b.2., Example for Aircraft 2 under that subparagraph. And, if you were vectored to the localizer that far out, then Paragraph 5-9-4 2. would apply, which is the radar arrival equivalent of the first cite; specifically the Example Aircraft 4 under that subparagraph. This section of approach clearances has often been misapplied and was the subject of an Air Traffic Bulletin about three years ago. |
When does a published part of the approach begin? At HAIGS? Can you be
considered on a published part of the approach before crossing HAIGS? Also, if he said cross HAIGS at or above 4,000 feet, is that a clearence to descend to 4,000 feet? Most of the time when shooting ILS's the controller will step you down to the altitude that is on the chart. wrote in message ... Chris Brooks wrote: I am training in the maryland area. I was cleared for an ILS approach to runway 27 at HGR the other day. Here is a plate: http://204.108.4.16/d-tpp/0406/05114I27.PDF I was about 17 miles out at 5000 feet when I got cleared for the approach. My question is, when can I descend to 4000 feet? Anyone? At 17 miles you were not within a published segment of the approach. ATC was required to give you an altitude to maintain and which to cross HAIGS. A proper clearance would have been "X miles from HAIGS. Cross HAIGS at, or above, 4,000, cleared for the ILS Runway 27 approach." The word "established" is inappropriate in this instance. If you did not receive such a clearance you were obligated to maintain 5,000 and question the clearance because 5,000 is not a reasonable altitude to cross HAIGS. REF: ATC Handbook 7110.65P, Paragraph 4-8-1 b.2., Example for Aircraft 2 under that subparagraph. And, if you were vectored to the localizer that far out, then Paragraph 5-9-4 2. would apply, which is the radar arrival equivalent of the first cite; specifically the Example Aircraft 4 under that subparagraph. This section of approach clearances has often been misapplied and was the subject of an Air Traffic Bulletin about three years ago. |
![]() "Chris Brooks" wrote in message ... We need more information. Exactly where were you and exactly what did the controller say? If you were VFR and practicing approaches while VFR then it doesn't matter what he said because the last thing he'll say is maintain VFR. When you are VFR it is not necessary for the controller to follow the regs as if you were IFR. When does a published part of the approach begin? On any thick black line. At HAIGS? Sure. Can you be considered on a published part of the approach before crossing HAIGS? While doing the procedure turn. Also, if he said cross HAIGS at or above 4,000 feet, is that a clearence to descend to 4,000 feet? Yes. Most of the time when shooting ILS's the controller will step you down to the altitude that is on the chart. Were you IFR at the time? If you were VFR then the controller does not ever have to mention an altitude. |
I was 17 miles EAST of the airport, intercepting the localizer. I was at
5000 feet, and just got "cleared for the approach". I was IFR. Also, if he said cross HAIGS at or above 4,000 feet, is that a clearence to descend to 4,000 feet? Yes. Can you provide a reference for that fact? So if that is the case, when can the descent be initiated? Pilots discretion? "Newps" wrote in message ... "Chris Brooks" wrote in message ... We need more information. Exactly where were you and exactly what did the controller say? If you were VFR and practicing approaches while VFR then it doesn't matter what he said because the last thing he'll say is maintain VFR. When you are VFR it is not necessary for the controller to follow the regs as if you were IFR. When does a published part of the approach begin? On any thick black line. At HAIGS? Sure. Can you be considered on a published part of the approach before crossing HAIGS? While doing the procedure turn. Also, if he said cross HAIGS at or above 4,000 feet, is that a clearence to descend to 4,000 feet? Yes. Most of the time when shooting ILS's the controller will step you down to the altitude that is on the chart. Were you IFR at the time? If you were VFR then the controller does not ever have to mention an altitude. |
![]() "Chris Brooks" wrote in message ... Also, if he said cross HAIGS at or above 4,000 feet, is that a clearence to descend to 4,000 feet? Yes. Can you provide a reference for that fact? What's the alternative? What else could you do? That clearance is essentially a pilots discretion descent. All you gotta do is make the crossing restriction which in this case is an at or above altitude. Most pilots in this situation would just stay at your previous altitude until intercepting the glideslope, then follow it down. So if that is the case, when can the descent be initiated? Right now if you want. Pilots discretion? Yes. |
![]() "Chris Brooks" wrote in message ... I was 17 miles EAST of the airport, intercepting the localizer. I was at 5000 feet, and just got "cleared for the approach". I was IFR. You can descend to 4000 immediately. |
![]() Chris Brooks wrote: I was 17 miles EAST of the airport, intercepting the localizer. I was at 5000 feet, and just got "cleared for the approach". I was IFR. Also, if he said cross HAIGS at or above 4,000 feet, is that a clearence to descend to 4,000 feet? Yes. Can you provide a reference for that fact? So if that is the case, when can the descent be initiated? Pilots discretion? Did you read the ATC Handbook references I provided to you? The current ATC Handbook is on the FAA's web site: http://www.faa.gov/atpubs/ATC/index.htm |
![]() "Chris Brooks" wrote in message ... I was 17 miles EAST of the airport, intercepting the localizer. I was at 5000 feet, and just got "cleared for the approach". I was IFR. In that case, you can descend to 4000 immediately. But why descend to 4000 at all? At the time you were cleared for the approach you were about 900 feet below the glideslope. |
"Newps" wrote:
We need more information. Exactly where were you and exactly what did the controller say? If you were VFR and practicing approaches while VFR then it doesn't matter what he said because the last thing he'll say is maintain VFR. When you are VFR it is not necessary for the controller to follow the regs as if you were IFR. From a purely instructor-centric point of view, I would prefer that controllers treat VFR practice approaches *exactly* like IFR ones. It's a training exercise; the more things you do differently from real life, the less effective the training is. One thing I see fairly often is controllers not assigning altitudes on VFR practice approaches. You end up with one of two scenarios, neither of which is very useful: 1) You stay high until you're so far above the charted descent profile that you can't possibly make it down in time. 2) You ask the controller for lower and get back, "altitude your descretion, maintain VFR". A not so sharp student might start to think that the altitude is ALWAYS his discretion in a situation like this. In any case, you end up eating up brain cycles sorting out how high you should be, when the issue would never come up on an IFR flight. |
Roy Smith wrote in
: "Newps" wrote: We need more information. Exactly where were you and exactly what did the controller say? If you were VFR and practicing approaches while VFR then it doesn't matter what he said because the last thing he'll say is maintain VFR. When you are VFR it is not necessary for the controller to follow the regs as if you were IFR. From a purely instructor-centric point of view, I would prefer that controllers treat VFR practice approaches *exactly* like IFR ones. It's a training exercise; the more things you do differently from real life, the less effective the training is. One thing I see fairly often is controllers not assigning altitudes on VFR practice approaches. You end up with one of two scenarios, neither of which is very useful: 1) You stay high until you're so far above the charted descent profile that you can't possibly make it down in time. 2) You ask the controller for lower and get back, "altitude your descretion, maintain VFR". A not so sharp student might start to think that the altitude is ALWAYS his discretion in a situation like this. In any case, you end up eating up brain cycles sorting out how high you should be, when the issue would never come up on an IFR flight. Every region must have different operating pratices because around here VFR and IFR approaches are treated almost exactly the same except for the phrase "maintain VFR". |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question: DP altitude vs MCA/MEA | Doug Easton | Instrument Flight Rules | 7 | April 7th 04 03:29 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 01:51 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
