Prop pitch cycling?
Old April 23rd 06, 09:14 PM posted to rec.aviation.piloting
Default Prop pitch cycling?
Hi!
I was told by my mechanic to only pull the prop handle until I could audibly
hear a slight pitch change to establish that it was working.
However, the aircraft manual says it should be cycled completely, and on a
cold engine three times to make sure oil is applied to the governor, or the
pitch mechanism.
Can someone elaborate on this?
What is recommended?
Thanks,
Frode
Old April 23rd 06, 10:16 PM posted to rec.aviation.piloting
"Frode Berg" wrote in message
Hi!
audibly
pitch mechanism.
Thanks,
Frode
POH rules of course, but aside from that, I always liked to exercise a prop
through several cycles, especially when cold, just to get everything nice
and warm and fluid up there.
Dudley Henriques
Old April 23rd 06, 11:12 PM posted to rec.aviation.piloting
The prop governor controls within a range and should hold a
steady rpm within that range. When the run-up is done at
say, 2400 rpm the prop should be cycled to the minimum rpm
and allowed to stabilize for a few seconds to check that the
governor is working properly. On a multiengine airplane the
prop should be reduced to just outside the feather detent
and allowed to run for several seconds to be sure that the
prop isn't feathering at the minimum governed speed [usually
2000 rpm on most piston engines]. If the prop control is
not rigged properly the prop will feather too soon. Then
the prop feather check should be done.
Most props have a certain amount of internal leakage to keep
warm oil circulating in the prop hub, but several cycles on
a cold engine/prop will assure that the prop does reach
proper operating temperatures.
In very cold temperatures, I like to vary the rpm every some
often to be sure the prop is functioning, but normal
internal flow should make this mostly an unneeded habit.
Remember, on a single-engine reducing rpm send oil to the
prop and on a multi, reducing rpm/feathering drain oil from
the prop.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Dudley Henriques" wrote in
message
ink.net...
| Hi!
until I could
| audibly
working.
the governor, or
| the
| pitch mechanism.
| Thanks,
| Frode
to exercise a prop
everything nice
| Dudley Henriques
Old April 23rd 06, 11:49 PM posted to rec.aviation.piloting
If all this was meant for me, I'm pretty sure I just might already know
these things
Dudley Henriques
"Jim Macklin" wrote in message
news:yZS2g.6789$ZW3.6526@dukeread04...
the prop.
James H. Macklin
ATP,CFI,A&P
some support
message
ink.net...
| Hi!
until I could
| audibly
working.
the governor, or
| the
| pitch mechanism.
| Thanks,
| Frode
to exercise a prop
everything nice
| Dudley Henriques
Old April 24th 06, 12:20 AM posted to rec.aviation.piloting
No, I know that, I just tacked it on the thread for the
benefit of the others. I think most pilots and many
mechanics don't really understand these things, judging by
the number of twins that feather before the prop lever gets
to the gate.
If I win the lottery, odds 146 million to one, we can have
that CFI round table and sell tickets to anyone without a
CFI. CFIs can come for free. I'll pay for you and me. If I
don't win the lottery, it will have to be in Wichita, can't
afford to go elsewhere without the lottery. ;-)'
James H. Macklin
ATP,CFI,A&P
some support
message
nk.net...
might already know
| these things
| Dudley Henriques
| "Jim Macklin" wrote
in message
hold a
at
rpm
detent
[usually
is
Then
keep
on
some
from
| the prop.
| James H. Macklin
| ATP,CFI,A&P
| some support
duties.
| message
ink.net...
| | Hi!
handle
| until I could
| | audibly
| working.
cycled
to
| the governor, or
| | the
| | pitch mechanism.
| | Thanks,
| | Frode
liked
| to exercise a prop
get
| everything nice
| | Dudley Henriques
Old April 24th 06, 01:11 AM posted to rec.aviation.piloting
I've done this a few times myself. :-)
On Usenet, if you underpost someone already in the thread but NOT the
original poster, what you post is considered addressed to the person you
underposted rather than simply an addition to the general thread.
Any general comment should be picked up as a post to the original poster by
clicking his/her post for reply. Then the comment appears referenced to the
initial question and not the sub poster.
I did the same thing once and gave a hundred word "lecture" on how to do a
slow roll to one of the world's best acro pilots by accidentally picking him
up to underpost instead of the initial poster who had asked about rolls. :-)
The pilot I gave the lecture to simply gave me a one word reply "Thanks"
with a smilie attached :-)
That get together sounds like fun. I'll bring the bottle!
Dudley
news:nZT2g.6827$ZW3.3603@dukeread04...
to the gate.
James H. Macklin
ATP,CFI,A&P
some support
message
nk.net...
might already know
| these things
| Dudley Henriques
| "Jim Macklin" wrote
in message
hold a
at
rpm
detent
[usually
is
Then
keep
on
some
from
| the prop.
| James H. Macklin
| ATP,CFI,A&P
| some support
duties.
| message
ink.net...
| | Hi!
handle
| until I could
| | audibly
| working.
cycled
to
| the governor, or
| | the
| | pitch mechanism.
| | Thanks,
| | Frode
liked
| to exercise a prop
get
| everything nice
| | Dudley Henriques
Old April 24th 06, 01:46 AM posted to rec.aviation.piloting
to the gate.
Thanks, Jim, for the added information. That's how I read your post; not
a correction to Dudley's, but rather an addendum for us less knowledgeable.
Peter
Old April 24th 06, 02:21 AM posted to rec.aviation.piloting
Jim Macklin wrote:
snip/
Remember, on a single-engine, reducing rpm sends oil to the
prop and on a multi, reducing rpm/feathering drains oil from
the prop.
Well, generally this is true, but not always. Hamilton Standard
Hydro-Matic props, as used on the big radials, pump high pressure oil
*into* the hub for feathering. If you have complete oil loss, or let
the oil get too hot (and thin), you're out of luck for feathering.
Happy Flying!
Scott Skylane
Old April 24th 06, 03:01 AM posted to rec.aviation.piloting
Just to add to the total thread, for the uninitiated, a
constant speed prop isn't really constant, the blade angle
is hunting back and forth to adjust for varied aerodynamic
loads. So, once the plane is warm and in operation, oil in
the prop dome generally stays plenty warm. But if you are
flying a multiengine aircraft in cold weather and shut an
engine down in training including feathering, the oil may
congeal to the point the prop won't unfeather. So ME CFI be
careful what and where you practice.
I look forward to winning the lottery and buying you a
drink.
message
link.net...
but NOT the
the person you
thread.
original poster by
referenced to the
reply "Thanks"
| Dudley
| "Jim Macklin" wrote
in message
by
gets
| to the gate.
have
a
If I
can't
| James H. Macklin
| ATP,CFI,A&P
| some support
duties.
| message
nk.net...
| might already know
| | these things
| | Dudley Henriques
| | "Jim Macklin"
wrote
| in message
| hold a
done
| at
minimum
| rpm
that
| the
airplane
| the
| detent
that
| the
| [usually
control
| is
| Then
to
| keep
cycles
| on
reach
every
| some
habit.
to
| the
oil
| from
| | the prop.
| | James H. Macklin
| | ATP,CFI,A&P
rights;
overcome.
| | some support
| duties.
in
| | message
ink.net...
message
| | | Hi!
| handle
| | until I could
| | | audibly
was
| | working.
| cycled
applied
| to
| | the governor, or
| | | the
| | | pitch mechanism.
| | | Thanks,
| | | Frode
| liked
| | to exercise a prop
to
| get
| | everything nice
| | | Dudley Henriques
Old April 24th 06, 03:06 AM posted to rec.aviation.piloting
That's is true, but except for the Beech 18, are there any
HS props on an airplane under 12,500 pounds?
The feathering on the HS is a electrical relay that turns on
a high pressure pump that operates at a pressure above
governor pressure. The Prop is feathered and the pump shuts
off. To unfeather the button is held in so the pump
continues to run and that causes the internal valve to move,
re-routing the oil so it unfeathers.
I wonder many pilots will take this to heart and open their
POH to the systems section?
James H. Macklin
ATP,CFI,A&P
some support
"Scott Skylane" wrote in message
| Jim Macklin wrote:
| snip/
from
| the prop.
Standard
pressure oil
loss, or let
feathering.
| Happy Flying!
| Scott Skylane
PA28: Difference in constant speed prop vs fixed pitch Nathan Young Owning 25 October 10th 04 04:41 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
Pitch and Diameter of 3 blade prop for IO-360 200HP Bart D. Hull Home Built 1 December 11th 03 11:42 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
ALTRAK pitch system flight report optics student Home Built 2 September 21st 03 11:49 PM
