IFR use of handheld GPS
Old May 4th 06, 03:54 AM posted to rec.aviation.ifr
Default IFR use of handheld GPS
"William L.Snow, PE" wrote in message
Simply said, ifr use of vfr gps is not in the spirit of the far's.
Which FARs?
Old May 4th 06, 05:44 AM posted to rec.aviation.ifr
On Wed, 3 May 2006 19:55:06 -0400, "William L.Snow, PE"
Is it or isn't it? Think about it for a minute.
You can file IFR accept an IFR direct clearance by simply flying
vectors, so it matters little what you have in the plane for equipment
as long as you have the equipment necessary to make any required
approache(s)
Let's say there is a 100 miles of rain between where I am now which is
CAVU and my destination is CAVU. I have enough gas to turn around and
come back home if need be and I have only the minimum required
instruments for legally fly in IMC.
I see the storm ahead, air file, ATC gives me a vector or vectors as
need be. I come out the other side of the storm and close the flight
plan although I have in the real world had them ask that I stay with
them until the destination is in sight and VFR.
This is strictly legal when in a RADAR environment.
Now say I have my trusty 296 with me. I still file with the same
equipment suffix as I would have used without the 296. I am legal in
every sense of the FARs and in addition I have a backup hand held GPS
which I can use for my position and course and ATC is happy to have me
do so. I do not need to tell them I have GPS. I can request direct
and they can tell me cleared direct or direct when able to where ever
with out a request from me. I can accept said "cleared direct", reply
"unable, or request vectors.
Now in real life I happen to have RNAV (not GPS). I have the
equipment go from point A to point B in the system be it direct, by
vectors, or airways which meets the intent of the FARs. That I choose
to do so by following my 296 is immaterial as I have all of the
equipment in the plane to meet the equipment suffix I used when
filing.
If the internal batteries in the 296 die, and I've forgotten the
lighter plug adapter, it is my responsibility to be able to properly
fly the clearance even if it is done by requesting vectors. However I
have a panel full of *stuff* that should enable me to do so without
having to request vectors if I have been paying attention and I keep
everything set up including the ADF to watch stations along the route.
The thing I've never figured out is whey do they bother with "enroute
certified GPS" when there is no need for enroute certified GPS UNLESS
this pertains specifically to panel mounted instruments.
You don't need enroute certified anything as long as you are in RADAR
contact and you can not get a direct clearance if you are not in RADAR
contact regardless of what ever certified equipment you have..
www.rogerhalstead.com
Old May 5th 06, 02:32 AM posted to rec.aviation.ifr
You are not allowed to use an IFR-certified GPS for en route (domestic
airspace) in a non-radar environment except with the special Alaska
provisions.
The fact that ATC may clear you via direct via RNAV when non-radar does
not relieve you of your regulatory responsibilites.
approache(s)
filing.
Old May 5th 06, 02:03 PM posted to rec.aviation.ifr
provisions.
Perhaps you meant to say you're not allowed to fly off-airway?
If you really meant what you said, please explain / cite the rule.
Old May 6th 06, 12:42 AM posted to rec.aviation.ifr
provisions.
Part 95, IFR Altitudes establishes MEAs and is the authority for airways
and Jet Routes. Those airways are rules, just like an instrument
approach procedure is a rule.
With instrument approach procedures (in addition to RNAV/GPS IAPs) you
have VOR and NBD IAPs that are approved for overlay flight with GPS.
That is the authorization to substitute GPS for VOR, where authorized on
the chart.
You don't have any overlay (i.e., standalone, non-radar) authorization
fo Victor Airways or Jet Routes. Thus, if you are not in a radar
environment you cannot use RNAV as primary for Victor airways or Jet Routes.
Does anyone care? Only if something goes wrong.
There are a few Q Routes, which are predicated solely on RNAV, but thus
far they have been established where traffic volumne is high and radar
is available. They are pretty much for the airlines in the lower 48,
thus far. And, I believe they are all in the high altitude stratum.
As I said before, Alaska has a special authorization that specifically
permits GPS/RNAV overlay of Victor airways.
Old May 7th 06, 04:27 AM posted to rec.aviation.ifr
"Sam Spade" wrote in message
news:MpR6g.175231$bm6.132922@fed1read04...
and Jet Routes. Those airways are rules, just like an instrument approach
have VOR and NBD IAPs that are approved for overlay flight with GPS. That
is the authorization to substitute GPS for VOR, where authorized on the
chart.
You don't have any overlay (i.e., standalone, non-radar) authorization fo
Victor Airways or Jet Routes. Thus, if you are not in a radar environment
far they have been established where traffic volumne is high and radar is
available. They are pretty much for the airlines in the lower 48, thus
You haven't cited a rule.
Old May 7th 06, 08:05 AM posted to rec.aviation.ifr
chart.
I cited Part 95. It is a rule.
Old May 7th 06, 03:35 AM posted to rec.aviation.ifr
news:2Xx6g.175203$bm6.65816@fed1read04...
provisions.
Nonsense.
Old May 7th 06, 04:51 AM posted to rec.aviation.ifr
So, the initial purpose of this thread was to discuss whether or not one
could use a handheld GPS for IFR navigation. Lots of people have been
tossing around lots of opinions with little or no references to rules or
guidance to back them up (hardly surprising...this is usenet after all...)
Anyway, for my own personal edification and enlightenment, I went and
tracked down the official FAA Advisory Circular that specifies what
the requirements are for the use of GPS under IFR. It's entitled
"Airworthiness Approval of Navigation or Flight Management Systems
Integrating Multiple Navigation Sensors", and is FAA AC 20-130A.
It's about as exciting to read as the dictionary (again, hardly
surprising). However, the Gleim Instrument Pilot Flight Manueuvers and
Practical Test Prep guide (which is where I found the reference in the
first place) does a nice job of summarizing the requirements for use of
GPS under IFR as specified in AC 20-130A. It states:
Authorization to conduct any GPS operation under IFR requires that:
a) GPS navigation equipment used must be FAA-approved and the installation
must be done in accordance with FAA requirements
i) Approval for the use of the GPS for IFR operations, and any
limitations, will be found in the airplane's POH (also called
the FAA-approved Airplane Flight Manual) and the airplane's
logbook
ii) VFR and hand-held GPS systems are not authorized for IFR
navigation, for instrument approaches, or as a principle
instrument flight references. During IFR operations, they
may be considered only an aid to situational awareness.
Aircraft using GPS navigation equipment under IFR must be equipped with an
approved and operational alternate means of navigation appropriate to the
flight.
a) Active monitoring of the alternative navigation equipment is not required
if the GPS receiver uses RAIM for integrity monitoring.
b) Active monitoring of the alternative navigation equipment is required
when the RAIM capability of the GPS equipment is lost.
This seems fairly clear to me.....
-- Dane
Old May 7th 06, 08:54 AM posted to rec.aviation.ifr
Hmm. I couldn't stand reading through the whole Advisory Circular, but
as far as I can tell, the paragraph I above is the opinion of whomever
wrote the written test prep. AC 20-130A seems to only give
requirements for obtaining IFR approval for a panel mount system and
give criteria for when the "VFR Only" sticker must be applied. But
does it even say what "VFR Only" means operationally? It doesn't
mention handheld GPS at all (AFAIK).
HANDHELD RADIO [email protected] Soaring 22 March 17th 16 03:16 PM
Navcom - handheld VS panel ? [email protected] Home Built 10 October 31st 05 08:08 PM
GPS Handheld Kai Glaesner Instrument Flight Rules 2 November 16th 04 04:01 PM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
