![]() "Roger" wrote in message ... On Thu, 11 May 2006 00:57:11 GMT, "Dudley Henriques" wrote: It's that "developing" that concerns me and I have to wonder what would have triggered such a response after several hundred hours. Of course there is such a thing as thinking about negative consequences too much and conditioning one's self to reinforce feelings we didn't realize were there. It would be my opinion that it's time to spend some time with a good instructor to find out why and to allay those fears and turn them into thoughtful concern. Done early this sort of thing is far, far easier to handle than later after it's had a chance to become entrenched. This is true. I have had several occasions in my career when I began to have doubts about my ability to survive the airshow demonstration venue. I know it happens to "normal" pilots as well. Usually it's exposure to an element of risk that for some reason you never actually considered as a high risk factor before. It causes you to step back and re-evaluate your exposure to risk. This is a key moment in a pilot's career if it ever happens. Most of the time it doesn't happen and you just continue on flying, but if you are exposed suddenly to something traumatic like witnessing a crash, the effect can be profound in some pilots. This is a point where individual personalities take hold. Most of us who fly, especially those of us who have flown professionally are deeply into deductive reasoning (even if we don't know it :-) and adjust to this kind of exposure by rationalization. I know I've watched many of my friends killed in airshow crashes. My rationalization of these incidents was such that I recognized the errors involved and took necessary steps to avoid making these same errors myself, or in the case of structrual failures, I rethought my own maintainence program and adjusted. My bottom line on fear was that I avoided it through rationalization that barring catestrophic events, I was in control of my own fate in the air. I think this works well for the everyday pilot also. Any normal deductive reasoning by a pilot should yield the rationalization that if a serious effort is made by a pilot to avoid trouble, barring catestrophic event, the odds are extremely favorable that one can fly an airplane through an entire lifetime and emerge safely at the other end of the road. For the pilot concerned about the possibility of a mid-air; the best way to avoid having a mid-air is simply to AVOID having a mid-air. Dudley |
![]() "Roger" wrote in message ... On Wed, 10 May 2006 15:20:32 -0700, Mark Hansen wrote: I've had thee close encounters since 1963. The last was nearly 10 years ago when landing. It was nearly dark and an ultralight pulled right in front of me just a few hundred feet off the ground when I was on final. The two previous "close encounters" were back in the 60's and within a couple of weeks of each other. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Most midair collisions seem to happen on a line aligned with the center of the runway and on an approach course. The classic midair, and probably the most common, is a low wing airplane making a steep final above a highwing airplane making a shallow final. Once they turn final, neither can see the other. The best cure is a thorough scan of the airport traffic area when approaching and a good look all around during all of the turns in the pattern. I also STRONGLY recommend at least a short wings level portion on the base leg when you can excercise the opportunity to thoroughly scan to your right for aircraft on a straight in approach. Remember, they can be on just about any approach slope from 2 degrees up to around 10 degrees. More than 10 degrees and it is probably a space shuttle and you are landing on the wrong runway! :-) Always look for people 100 feet or so above or below the pattern altitude. Also remember that the former "standard" pattern altitude was 800 feet AGL while the current "standard" pattern altitude seems to be 1000 feet AGL. Most airports use one or the other for their pattern altitude. At a strange airport you may easily find yourself proudly using the wrong one, or, if you are useing the correct one someone else may be using the other. Always check both carefully. Also check the pattern on BOTH sides of the runway. Someone may think there is a right/left hand pattern in effect and be using the incorrect one. When winds are light and variable virtually any runway may be in use. I remember one time starting my flare at the Flying W Ranch in New Jersey and looking up and seeing a Cessna 310 doing the exact same thing at the other end of the runway! It got MY attention! :-) Also be extremely careful if there are intersecting runways. Even if they only intersect or almost intersect at one end. I remember one very interesting landing at Philadelphia Internation back in the sixties. I was in a Piper Apache landing to the west. I was number two after a Boeing 720 landing to the south. Those runways kinda intersect at the east end of the EW runway and the north end of the NS runway. The big Boeing went by and touched down off to my left. I was on short final over the river when I suddenly found my self rolling at a very rapid rate well past ninety degrees. I didn't see anyway possible that I could stop the roll and roll back before I landed so I pushed and cranked in the direction of the roll. I completed the roll and came wings level and then the mains touched down. I really hadn't intended an aileron roll on short final, but that's what happened. My charter pax were two airline pilots flying in for their ride. They were a bit pale when they climbed out of that Peachy Apache! Of course I was the cool calm and collected high time charter jock. I thanked them for the business, closed the door, and proceeded to get takeoff clearance back the way I came in, and took off to the east. As I got out over the river the door popped open. The cool, calm and collected high time charter jock hadn't remembered to latch the darn door. I can say from experience that if you are solo in a Piper Apache and the door pops open you are NOT going to get it closed and latched unless you land. There was no way I was going to turn around and go back into PHL! I flew on down to Bridgeton, NJ and landed there and closed and latched the door. Then I flew on home to MIV. Another day in the life of a charter jock! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
![]() "Highflyer" wrote in message ... I remember one time starting my flare at the Flying W Ranch in New Jersey and looking up and seeing a Cessna 310 doing the exact same thing at the other end of the runway! It got MY attention! :-) That was probably Bill Whitesell! :-) Dudley |
Highflyer schrieb:
I've had thee close encounters since 1963. The last was nearly 10 years ago when landing. The most dangerous near misses are those which you'll never know. Stefan |
On Sat, 29 Jul 2006 10:01:50 +0200, Stefan
wrote: Highflyer schrieb: I've had thee close encounters since 1963. The last was nearly 10 years ago when landing. The most dangerous near misses are those which you'll never know. Near miss. No, I've never had one that almost missed me. The closest was about a foot with the top of the tail of a Comanche under my seat. Although that vertical stabilizer had to be closer to that to the wheels on the old Piper Colt. He was flying the express way low and I do mean low. He had to gain altitude for the overpass and there we were on final for 36. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Stefan Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Stefan wrote:
The most dangerous near misses are those which you'll never know. Stefan I can see where the original poster's apprehension stems from, having flown once, from the FO's seat. I wasn't at all inhibited in doing a stall, steepish banks and other jiggles - in fact, I did them all merrily. But I was petrified throughout the ride because the craft, a JetFox, didn't have a radar and the only way of recognizing traffic in the immediate neighborhood was by actually looking out the window. Just felt a sense of being helplessly vulnerable in an open sky. It might go away if I fly more, because the Capn seemed very assured ![]() Is it correct to assume that one can always be whacked by traffic coming from between the 4 and 8 o'clock positions, especially if the other craft is faster and climbing? Ramapriya |
Mark
I spent about 15 years ag flying there near Modesto before I decided to get out of the PRC. I'm merely trying to illustrate the point that in a lot of hours flying I've never had any near mid-airs. I have seen the aftermath of a number of them however and have talked to pilots who were involved. So far they haven't given me nightmares nor do I expect them to. As Dudley and others have mentioned, I also train every pilot I fly with to keep their heads on a swivel looking out for the pilot who isn't! Sometimes they happen in spite of the best avoidance efforts. Cheers Ol Shy & Bashful |
"Ol Shy & Bashful" wrote:
I've been flying all over the world and much of it, about 13000 hours, crop dusting. I could see running into tall scarecrows, birds, or the occasional semi- trailer Magnum Oil truck while you try to kill Cary Grant, but I can't see you encountering many other planes at the low altitudes you probably spent all that time flying. :-) By the way, are you the pilot flying this plane: http://photos1.blogger.com/blogger/3...1600/NBN12.jpg ;-) |
Nah...I'm not quite THAT old!! Well, maybe I am but it wasn't me flying. I didn't start crop dusting until 1966.g Cheers |
On Wed, 10 May 2006 22:20:58 -0000, Jim Logajan
wrote: "Ol Shy & Bashful" wrote: I've been flying all over the world and much of it, about 13000 hours, crop dusting. I could see running into tall scarecrows, birds, or the occasional semi- trailer Magnum Oil truck while you try to kill Cary Grant, but I can't see you encountering many other planes at the low altitudes you probably spent all that time flying. :-) You do generally have to pull up to make the turns and that puts you into Piper Cub territory. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com By the way, are you the pilot flying this plane: http://photos1.blogger.com/blogger/3...1600/NBN12.jpg ;-) |
UBL wants a truce - he's scared of the CIA UAV | John Doe | Aviation Marketplace | 1 | January 19th 06 08:58 PM |
The kids are scared, was Saddam evacuated | D. Strang | Military Aviation | 0 | April 7th 04 10:36 PM |
Scared and trigger-happy | John Galt | Military Aviation | 5 | January 31st 04 12:11 AM |
