BFR
Old July 19th 04, 05:48 AM
Roger Halstead
On 19 Jul 2004 02:57:03 GMT, Andrew Sarangan
"fly low" wrote in
The BFR does not have to include any Instrument Currency component as
long as the Pilot is current, correct?
Whether you are instrument current or not has no bearing. What I care
about is whether you plan on flying IFR. If the answer is yes, then I
would insist on some instrument work during a flight review.
I have had a case where an instrument rated pilot had not flown IFR in
many years and said that he had no intention of ever becoming current.
In that case, I elected to not do any instrument work for the flight
review.
BTW, the phrase BFR is no longer used. It is Flight Review (FR).
Just as "Oshkosh" will always remain "Oshkosh" and not "AirVenture" to
most of us, so to will the BFR remain a BFR, regardless of what the
FAA calls it.
It is after a flight review done on a biennial basis and technically
is a "biennial", flight review.
And as to the issue of instrument work, I'm not currently... current,
but I fully expect to see instrument work on the next BFR.
www.rogerhalstead.com
If you are Instrument Current and due for a BFR, are you required
to or should you also be tested on Instrument Approaches, Holds,
etc?
A flight review consists of a minimum of an hour of ground and an
hour of flight instruction by FAR.
An instructor may conduct the flight review in any way he pleases as
long
as
it meets these parameters. I have known instructors who would not do
a flight review in less than 16 hours. It is whatever the instructor
feels comfortable in signing you off for.
Old July 19th 04, 06:23 AM
C J Campbell
"Andrew Sarangan" wrote in message
. 158...
Wrong. It was always flight review. BFR, like FBO, does not appear in the
FARs. :-) There is no legal definition of BFR or FR. BFR is the commonly
accepted usage and will continue to be until it is required at some period
other than every two years.
Honestly, trying to stamp out "BFR" is as nutty as the attempt to
artificially restrict the definition of "upwind" to a special case was
awhile ago. It matters not that AIM shows a line labeled "upwind." As long
as towers and aircraft have existed, departing traffic has been referred to
as "upwind" by both towers and pilots.
Old July 19th 04, 05:20 PM
OtisWinslow
to
They have? I always thought that was the departure leg. And likewise I've
always thought that "upwind" is the opposite side of the runway from
"downwind".
Old July 20th 04, 12:44 AM
Hankal
. I have known instructors who would not do a
He is milking the pilot big time
Old July 20th 04, 09:58 AM
Roy Smith
Roger Halstead wrote:
If an instructor really goes in for a 16 hour BFR it's time to run the
other way and find a competent instructor.
I've done long stretches of instruction (10+ hours) that ended in the
student getting a flight review endorsement, but usually in the context
of learning some new skill. For example, my club requires a 10 hour
checkout for our retracts. At the end of that time, I sign the person
off for both the club checkout and BFR (and, if appropriate, a
complex/high-performance endorsement, and maybe an IPC too). I suppose
by some narrow definition, you could call that a 10 hour BFR.
Old July 20th 04, 04:36 AM
C J Campbell
"Hankal" wrote in message
I did not say they were good instructors.
Old July 19th 04, 11:01 AM
Matt Whiting
fly low wrote:
If you are Instrument Current and due for a BFR, are you required to or
should you also be tested on Instrument Approaches, Holds, etc?
Not required to, but it can't hurt! :-)
Matt
Old July 19th 04, 12:19 PM
On Mon, 19 Jul 2004 06:01:55 -0400, Matt Whiting
Matt
It's interesting that the minimum 1 hour is mentioned for the BFR.
I checked out in Honolulu in January (MY previous BFR was 1998 as I
have a UK licence which is current but not the FAA certificate).
Ground school was well over the hour as I needed to understand the
local procedures but the flight was virtually finished after 45
minutes. The instructor said we needed a little longer to be legal so
we will do some additinal steep turns and a second partial PFL to make
up the time!
David
E-mail (Remove Space after pilot): pilot
Old July 19th 04, 05:18 PM
OtisWinslow
I always request that my FR be tilted toward IFR since that's where
I always need the most review work and I don't fly much IFR.
It's my attitude that the FR is the opportunity to spend time with
a CFI to improve my flying. So why not work on that which I'm
the least proficient at?
"fly low" wrote in message
