Robert M. Gary wrote:
I learned to fly in the summer so we always took off with the doors open. It really helped keep us cooler. I was surprised teh first time I found out that most pilots close the doors before flight, even when its not cold. -Robert Doors are for barns. Real airplane have canopies. I've had the canopy pop open, but then it's legal for me to fly with it open. Oddly enough, just as with many aircraft doors, the aerodynamic forces make the Navion canopy want to pretty much close all the way in flight. You can really only fly with it open if you latch it open before takeoff. There is a cable that gives you the leverage to pull it open in flight, but my plane doesn't have it. |
Bob
Some excellent replies here and it sounds like some, by pilots who have experienced various doors opening, without disastrous result. I've had a number of doors come open on quite a variety of aircraft (does that say something about how really fragile they are?) and not much more than a fright to either me, or the PAX. As part of my own training regimine, I cause a door to open for many of the flights I give with students to show them the non-existent danger or proper procedures to close said door again. Have had baggage doors pop open on several aircraft and had to land to close them again. No big deal but certainly annoying. Open doors on some aricraft that disrupted the airflow, like the Pipers, and Beechcraft with the cabin doors that curved up on the fuselage. It is more of a fright factor than anything. Vertical cabin doors are nearly impossible to open more than a handspan in flight with airflow pushing them shut.... Cabin windows, like the emergency exit on Barons, cause nothing more than a loud roar and scare crap out of whoever is sitting there....especially over the Sierras at night out of Tahoeggg I participated in an accident investigation years ago on a Beech Queen Air A65/80 that crashed after a baggage door opened in flight shortly after takeoff at ABQ. It turned out the baggage was spilling out of the compartment into the left propellor causing an engine failure. It was not an aircraft design problem causing the crash, but one of pilot error. I got involved simply because the aircraft that crashed was one digit away from the one I was flying at the time and we used it to attempt duplication of the crash scenario to see if it was aircraft design or pilot error. Bottom line is, I don't think an unexpected door opening on any aircraft is cause for crash or panic. Structural integrity may be at risk in some high speed exotic aircraft, but I don't know of any that are that critically affected aerodynamically. Same can be said of instrument failure and a pilot doing the panic routine just because they didn't have the airspeed, or altimeter, or compass, or ???? If you are still concerned, go up in the aircraft you normally fly with an instructor or experienced pilot, and crack a door to see what it does. If nothing else it will prove how difficult it is to open the door enough to cause danger. I remember the time whan I tried to make a parachute jump from the backseat of a Piper TriPacer back in the early 60's and ......well thats a story for another time after we have a San Pablo.....ggg Ol Shy & Bashful |
![]() "Ol Shy & Bashful" wrote in message oups.com... Bob I participated in an accident investigation years ago on a Beech Queen Air A65/80 that crashed after a baggage door opened in flight shortly after takeoff at ABQ. It turned out the baggage was spilling out of the compartment into the left propellor causing an engine failure. It was not an aircraft design problem causing the crash, but one of pilot error. I got involved simply because the aircraft that crashed was one digit away from the one I was flying at the time and we used it to attempt duplication of the crash scenario to see if it was aircraft design or pilot error. I believe Ben Abruzzo the ballonist also died that way in ABQ in a Cessna 421. He was headed out on a ski trip with a plane load of passengers. The nose baggage door popped open and skis began to head for the propeller. I think someone said he intended to shut down the left engine but somehow wound up shutting them both down. Almost made it back to the runway but hit a raised road just short and burst into flames. I found this googling: February 11, 1985: Ben Abruzzo, a crew member on the Double Eagle II, the first balloon to cross the Atlantic Ocean nonstop, was killed along with several passengers when his twin-engine plane crashed shortly after taking off from the Albuquerque, New Mexico airport. An investigation showed that the probable cause of the crash was an external luggage compartment door which had been left open. The best idea from aircraft data was that he had pulled back on the gas of the closest prop to the door and then inadvertently feathered the wrong prop, thus rendering both engines inoperative. Before his death, Abruzzo was also a member of the first team to fly a balloon nonstop across the Pacific Ocean. |
Having a door pop open should be a non-event. Air pressure will keep it from
opening more than an inch or two, the noise is distracting, papers fly around the cockpit, and passengers freak out. IMHO it is a waste of time and energy to attempt closure in flight...land and do it right. There will be disturbed airflow over the horizontal stabilizer on the open-door side, but nothing that the pilot cannot deal with. Bob Gardner "bob" wrote in message . .. How serious is it on small twin engines with only one door? Or with 2 doors, for that matter? A friend of mine tells me that he once had a twin engine Piper crash to investigate due to ditching. It was later learned upon the conclusion of the investigation that a passenger in the back seat was trying to switch places with someone in the front and the door inadvertently popped open. At that point the investigator determined, from his own similar experience, that the plane sunk like a rock due to critical disruption of the airflow to that could not be corrected in flight. --The door could not be closed again!--- As for my friend with his similar experience, his friend's hand was all bloody from trying to hold it closed as much as he could. Fortunately, they made a safe emergency landing at an island the just happened to be nearby. I've only flow small single engines and had NO IDEA how serious this could be. They don't teach you that in flight school. Or is it because single engines with only one door do not react the same as the twins. Tell me the straight skinny so I know next time I go flying. Thanks |
There was a Mooney crash a few years back caused by the baggage door opening in flight. Apparently the airflow over the tail was disrupted on final and caused the crash. If the baggage door opens in flight the recommendation in the Mooney community now is to keep your speed up on final (which in a Mooney means find a really long runway). -Robert |
The critical issue would be Vmca with a door open, it has
not been flight tested and how much Vmca will increase is just a guess. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Bob Gardner" wrote in message ... | Having a door pop open should be a non-event. Air pressure will keep it from | opening more than an inch or two, the noise is distracting, papers fly | around the cockpit, and passengers freak out. IMHO it is a waste of time and | energy to attempt closure in flight...land and do it right. | | There will be disturbed airflow over the horizontal stabilizer on the | open-door side, but nothing that the pilot cannot deal with. | | Bob Gardner | | | | "bob" wrote in message | . .. | How serious is it on small twin engines with only one door? Or with 2 | doors, for that matter? | | A friend of mine tells me that he once had a twin engine Piper crash to | investigate due to ditching. It was later learned upon the conclusion of | the investigation that a passenger in the back seat was trying to switch | places with someone in the front and the door inadvertently popped open. | At that point the investigator determined, from his own similar | experience, that the plane sunk like a rock due to critical disruption of | the airflow to that could not be corrected in flight. | --The door could not be closed again!--- | | As for my friend with his similar experience, his friend's hand was all | bloody from trying to hold it closed as much as he could. Fortunately, | they made a safe emergency landing at an island the just happened to be | nearby. | | I've only flow small single engines and had NO IDEA how serious this | could be. They don't teach you that in flight school. Or is it because | single engines with only one door do not react the same as the twins. | | Tell me the straight skinny so I know next time I go flying. | | Thanks | | | |
Several years ago, in Plane & Pilot magazine, there was an article on a
six-place Piper (Saratoga?). One of the pictures showed the upper latch of the cabin door clearly unlatched, with the resulting gap visible. Apparently they had no problems (except for the noise) A few years ago, I departed IFR in my Seneca, and the forward door became unlatched. There was a lot of wind noise, but like other posters here said, there was no need to hold the door open. I was flying from Palmer MA, to Islip, NY. (Turning back to Palmer was out of the question) I made a request for a landing at Groton, CT. The controllers put my IFR in suspense, and after landing I was on my merry (and quieter) way. "bob" wrote in message . .. How serious is it on small twin engines with only one door? Or with 2 doors, for that matter? A friend of mine tells me that he once had a twin engine Piper crash to investigate due to ditching. It was later learned upon the conclusion of the investigation that a passenger in the back seat was trying to switch places with someone in the front and the door inadvertently popped open. At that point the investigator determined, from his own similar experience, that the plane sunk like a rock due to critical disruption of the airflow to that could not be corrected in flight. --The door could not be closed again!--- As for my friend with his similar experience, his friend's hand was all bloody from trying to hold it closed as much as he could. Fortunately, they made a safe emergency landing at an island the just happened to be nearby. I've only flow small single engines and had NO IDEA how serious this could be. They don't teach you that in flight school. Or is it because single engines with only one door do not react the same as the twins. Tell me the straight skinny so I know next time I go flying. Thanks |
ummm. let's change "hold the door open" to "hold the door closed"
![]() "tom418" wrote in message news:fTmbg.130490$k%3.2538@dukeread12... Several years ago, in Plane & Pilot magazine, there was an article on a six-place Piper (Saratoga?). One of the pictures showed the upper latch of the cabin door clearly unlatched, with the resulting gap visible. Apparently they had no problems (except for the noise) A few years ago, I departed IFR in my Seneca, and the forward door became unlatched. There was a lot of wind noise, but like other posters here said, there was no need to hold the door open. I was flying from Palmer MA, to Islip, NY. (Turning back to Palmer was out of the question) I made a request for a landing at Groton, CT. The controllers put my IFR in suspense, and after landing I was on my merry (and quieter) way. "bob" wrote in message . .. How serious is it on small twin engines with only one door? Or with 2 doors, for that matter? A friend of mine tells me that he once had a twin engine Piper crash to investigate due to ditching. It was later learned upon the conclusion of the investigation that a passenger in the back seat was trying to switch places with someone in the front and the door inadvertently popped open. At that point the investigator determined, from his own similar experience, that the plane sunk like a rock due to critical disruption of the airflow to that could not be corrected in flight. --The door could not be closed again!--- As for my friend with his similar experience, his friend's hand was all bloody from trying to hold it closed as much as he could. Fortunately, they made a safe emergency landing at an island the just happened to be nearby. I've only flow small single engines and had NO IDEA how serious this could be. They don't teach you that in flight school. Or is it because single engines with only one door do not react the same as the twins. Tell me the straight skinny so I know next time I go flying. Thanks |
I've had a door pop open on a Baron, and it does get loud. All of the charts
on the front seat and my jacket nearly got sucked out. The plane definitely did not fly as well with the door open. The extra drag was very noticeable, even though it trailed open only around two inches. I was able to get it partially closed, and the acceleration was very apparent, but I finally gave up and landed. While distraction is an issue, the handling was a lot different. |
![]() "bob" wrote in message . .. I've only flow small single engines and had NO IDEA how serious this could be. They don't teach you that in flight school. Or is it because single engines with only one door do not react the same as the twins. Tell me the straight skinny so I know next time I go flying. I posted about this a couple of weeks ago when the door on the Arrow II I was flying unlatched. A high-wing door -should- close itself enough that it won't disrupt airflow. A low-wing door, which is what I was flying, is a little trickier, I THINK because the low pressure over the wing draws the door out slightly, but the airflow keeps it closed enough that I determined that trying to close it in solo flight was more of a distraction that landing the airplane at a nearby strip and resecuring the door. My windbreaker and sectional vanished, though. -c |
CFI without commercial? | Jay Honeck | Piloting | 75 | December 8th 10 04:17 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Dumb Reg question | John Gaquin | Piloting | 67 | May 4th 05 04:54 AM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
