![]() Peter Duniho wrote: Your strobes are required even in daytime. So a Cub with no electrical system, can't fly day vfr? |
"Jay Honeck" wrote in message
news:hQsdg.3183$No1.816@attbi_s71... [...] I've still got 12 to 17 minutes left. What're you doing that I'm not? I guarantee you that in three minutes, you do NOT check "every screw, bolt and connector". You are fooling yourself if you think that three minutes is sufficient time for a preflight inspection. |
and connector". You are fooling yourself if you think that three minutes is sufficient time for a preflight inspection. Well, maybe it's my familiarity with the bird. No, I'm not checking the torque of every bolt, but I do use the fuel tester Phillips screw driver to check screws for tightness. And I always sump the tanks, and check the oil. Additionally, I visually inspect every control surface hinge and manually move each control surface, checking for proper hinge pin placement, etc. On my plane, it's not possible to "open the engine up" (like we used to do in our Warrior), so that saves me a bit of time, too. (Time I'd rather spend, quite frankly; our one-piece fiberglass cowl may look better than the Warriors, but I sure miss being able to visually inspect the engine before each flight.) I have no idea what could take more than 3 - 5 minutes, unless you find something suspicious. Hopefully, that's a rare occasion, indeed. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
news:ynPdg.992508$xm3.784486@attbi_s21... You are fooling yourself if you think that three minutes is sufficient time for a preflight inspection. Well, maybe it's my familiarity with the bird. No, it's not. I've owned my airplane for 12 years. Three minutes is still insufficient. Frankly, every post you make you add stuff to your description of your preflight. I have no idea how you manage to do all that stuff in three minutes. You are either recklessly rushing through everything, or you have a completely distorted sense of time. Next time you do a preflight, get someone to actually time you, and do the preflight in a careful, relaxed, methodical manner. If you are really doing everything you claim to be doing, there's no way it takes three minutes. Three minutes is an incredibly short period of time. I'm a fast typist, and it took at least three minutes to compose this post. Pete |
still insufficient. Frankly, every post you make you add stuff to your description of your preflight. I have no idea how you manage to do all that stuff in three minutes. You are either recklessly rushing through everything, or you have a completely distorted sense of time. That's possible, I suppose. Time spent flying (and preflighting) is NOT deducted from your lifespan, so it pays to take your time... ;-) I still say you're suffering from time elongation during preflight. Unless I find something wrong or that needs adjustment, or lubrication (the yokes, for example), or cleaning (the windshield -- but we try to do that AFTER flight), I can't imagine taking 15 minutes on a preflight inspection. Not on a fixed gear, single engine plane, anyway. How long does your pre-takeoff checklist take you? Perhaps we're commingling different parts of the lists, and counting them differently as a result? (For example, Bob Noel checks his electric fuel pump during pre-flight, which adds some time. We check the pump at engine start, so we're not counting that particular check as part of our pre-flight inspection...) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Peter Duniho wrote:
"Jay Honeck" wrote in message news:ynPdg.992508$xm3.784486@attbi_s21... You are fooling yourself if you think that three minutes is sufficient time for a preflight inspection. Well, maybe it's my familiarity with the bird. No, it's not. I've owned my airplane for 12 years. Three minutes is still insufficient. Frankly, every post you make you add stuff to your description of your preflight. I have no idea how you manage to do all that stuff in three minutes. You are either recklessly rushing through everything, or you have a completely distorted sense of time. Next time you do a preflight, get someone to actually time you, and do the preflight in a careful, relaxed, methodical manner. If you are really doing everything you claim to be doing, there's no way it takes three minutes. Three minutes is an incredibly short period of time. I'm a fast typist, and it took at least three minutes to compose this post. I don't know about that. I counted roughly 120 words in your post. If that took three minutes, then you are typing at 40 words per minute. That isn't a fast typist by any means. I type 50+ and consider myself slow. Wife and daughters type well over 100. That is fast. I'm with Jay on this one. I could preflight my Skylane in no much more than three minutes. I'd probably say 5 just to be on the safe side, but it just doesn't take that long to walk around the airplane and pull, tug and view the essential items. Matt |
On Fri, 26 May 2006 01:27:41 GMT, "Jay Honeck"
wrote in hQsdg.3183$No1.816@attbi_s71:: I've still got 12 to 17 minutes left. What're you doing that I'm not? Sampling/draining all five fuel sumps? Testing the stall warning switch & ELT operation, inspecting the brake linings, looking for hydraulic leaks, tire treads, pitot/static ports, prop condition, spinner attachment, oleo-struts, and all the other items mentioned he http://www.dauntless-soft.com/PRODUC...info.asp?ID=29 |
Sampling/draining all five fuel sumps? Yep. Testing the stall warning switch Yep. & ELT operation Nope. But mine is brand, spanking new. inspecting the brake linings, looking for hydraulic leaks, tire treads No-can-do with Fancy Pants. Everything is inside. But I inspect for puddles. pitot/static ports Yep. prop condition, spinner attachment Yep. http://www.dauntless-soft.com/PRODUC...info.asp?ID=29 Your list counts a lot of stuff that I prefer to do more as "daily maintenance" than "pre-flight". For example, cleaning the windshield is a whole different thing when it's your plane, in your hangar. As a renter, cleaning the windshield was a "pre-flight" item. As an owner, it's a "post-flight" item, so that the plane is ready to go for the next flight. Same with fueling. My pre-flight checks have evolved over the years. As previously stated, I don't check my nav lights anymore unless I'm anticipating a night flight. (Do you fly with them on in the daytime?) Strobes are checked as a roll past my hangar rows, and I view their reflection. Checking my landing light before engine start used to be a critical item; now, with three of them, it's a non-event. (I can see them from the cockpit now...) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() Jay Honeck wrote: It's a basic part of the preflight actions. I also spend a good 15-20 minutes walking around my airplane before every flight I do a thorough pre-flight inspection before every flight. Every control surface is checked for continuity, all four gas tanks are visually inspected, oil is checked, wheel pants are given a tug, prop is examined, stall indicator movement verified, every screw, bolt and connector is visually inspected... A preflight before every flight? I don't think so. Once a day. Check the stall warner? Every year at the annual. |
How about checking the oil, and visually inspecting (dipping the tanks)
the fuel before every flight? Fuel guages aren't always trust-worthy, and I don't know that somebody hasn't siphoned fuel from my tanks while I was enjoying that $100 hamburger. 1st flight of the day... Always a thorough pre-flight inspection (including duats or wxbrief). If I stop somewhere for lunch, where the plane is out of my site for an hour or so... Walk-around, looking to see that nobody bumped into the bird while I was eating, dip the tanks, check the oil, and do a standard run-up and controls check. Day trip, where the plane has been sitting somewhere for an extended period of time... I treat it like the first flight of the day. I never take off, without dipping the tanks and checking the oil... Best Regards, Todd |
Busted TFR, what to expect? | bob | General Aviation | 98 | July 9th 06 04:00 PM |
CAP SAREX what to expect? | Robert M. Gary | Piloting | 8 | August 22nd 05 02:16 PM |
Class B busted...My problem or the controller's ? | Antoņio | Piloting | 130 | June 4th 05 02:59 PM |
IFR to & from CLT - Delays and Fees to Expect | David | Instrument Flight Rules | 6 | August 21st 04 04:57 AM |
Busted IFR Checkride | Jon Kraus | Instrument Flight Rules | 77 | May 4th 04 02:31 PM |
