Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Busted TFR, what to expect?
Old May 26th 06, 05:41 AM posted to rec.aviation.piloting,rec.aviation.misc
Default Busted TFR, what to expect?
"Jay Honeck" wrote in message
news:hQsdg.3183$No1.816@attbi_s71...
I've still got 12 to 17 minutes left. What're you doing that I'm not?
I guarantee you that in three minutes, you do NOT check "every screw, bolt
and connector".
You are fooling yourself if you think that three minutes is sufficient time
for a preflight inspection.
Old May 27th 06, 04:07 AM posted to rec.aviation.piloting,rec.aviation.misc
and connector".
time for a preflight inspection.
Well, maybe it's my familiarity with the bird. No, I'm not checking the
torque of every bolt, but I do use the fuel tester Phillips screw driver to
check screws for tightness. And I always sump the tanks, and check the
oil.
Additionally, I visually inspect every control surface hinge and manually
move each control surface, checking for proper hinge pin placement, etc.
On my plane, it's not possible to "open the engine up" (like we used to do
in our Warrior), so that saves me a bit of time, too. (Time I'd rather
spend, quite frankly; our one-piece fiberglass cowl may look better than the
Warriors, but I sure miss being able to visually inspect the engine before
each flight.)
I have no idea what could take more than 3 - 5 minutes, unless you find
something suspicious. Hopefully, that's a rare occasion, indeed.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 27th 06, 05:41 AM posted to rec.aviation.piloting,rec.aviation.misc
news:ynPdg.992508$xm3.784486@attbi_s21...
No, it's not. I've owned my airplane for 12 years. Three minutes is still
insufficient.
Frankly, every post you make you add stuff to your description of your
preflight. I have no idea how you manage to do all that stuff in three
minutes. You are either recklessly rushing through everything, or you have
a completely distorted sense of time.
Next time you do a preflight, get someone to actually time you, and do the
preflight in a careful, relaxed, methodical manner. If you are really doing
everything you claim to be doing, there's no way it takes three minutes.
Three minutes is an incredibly short period of time. I'm a fast typist, and
it took at least three minutes to compose this post.
Pete
Old May 27th 06, 01:39 PM posted to rec.aviation.piloting,rec.aviation.misc
still insufficient.
have a completely distorted sense of time.
That's possible, I suppose. Time spent flying (and preflighting) is NOT
deducted from your lifespan, so it pays to take your time... ;-)
I still say you're suffering from time elongation during preflight. Unless
I find something wrong or that needs adjustment, or lubrication (the yokes,
for example), or cleaning (the windshield -- but we try to do that AFTER
flight), I can't imagine taking 15 minutes on a preflight inspection. Not
on a fixed gear, single engine plane, anyway.
How long does your pre-takeoff checklist take you? Perhaps we're
commingling different parts of the lists, and counting them differently as a
result? (For example, Bob Noel checks his electric fuel pump during
pre-flight, which adds some time. We check the pump at engine start, so
we're not counting that particular check as part of our pre-flight
inspection...)
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 27th 06, 05:42 PM posted to rec.aviation.piloting,rec.aviation.misc
news:QLXdg.5074$1i1.1849@attbi_s72...
Preflighting *is* part of flying, as you say. I know for a fact it takes me
15 minutes, but I also know for a fact that it doesn't feel like 15 minutes
because time flies when you're having fun. I enjoy the inspection, and the
minutes just pass by like water.
I suffer from the same time distortion you do. It doesn't seem like 15
minutes. But I've checked the clock on several occasions. I know how long
it actually takes.
a result?
I do a normal run-up. Electric fuel pump is my primer, and so operation is
checked during engine start, like for your airplane. In any case, even on a
172, with much simpler systems than on my own airplane, my preflight is
generally over 10 minutes, and that's an airplane I can't even get into the
engine compartment with.
I don't know what else you might be considering...my pre-takeoff checks are
pretty typical as far as I know, except for the flight control check (only
the ailerons are visible from the cockpit, so I do check the flight controls
during the walkaround). If anything, I would guess my pre-takeoff checks
are fewer than others' for that reason.
Pete
Old May 28th 06, 03:07 AM posted to rec.aviation.piloting,rec.aviation.misc
"Jay Honeck" writes:
inspection...)
Another data point -- I am not nearly as experienced as you are, but
going through every item on the Citabria checklist takes me 20-30
minutes.
I know this 'cause I have to make sure I have this done before my
instructor shows up. :-)
Chris
Chris Colohan Email: PGP: finger
Web:
www.colohan.com Phone: (412)268-4751
Old May 28th 06, 03:38 AM posted to rec.aviation.piloting,rec.aviation.misc
inspection...)
minutes.
Wow, you've got to get out of 1st gear. :-)
I could preflight my 182, wash the windshield, change the oil and check
the tire pressures in 10 minutes time. I didn't realize a Citabria was
so complex. Does the preflight require ultrasonic inspection of the
structure or some such? :-)
Matt
Old May 27th 06, 01:54 PM posted to rec.aviation.piloting,rec.aviation.misc
insufficient.
I don't know about that. I counted roughly 120 words in your post. If
that took three minutes, then you are typing at 40 words per minute.
That isn't a fast typist by any means. I type 50+ and consider myself
slow. Wife and daughters type well over 100. That is fast.
I'm with Jay on this one. I could preflight my Skylane in no much more
than three minutes. I'd probably say 5 just to be on the safe side, but
it just doesn't take that long to walk around the airplane and pull, tug
and view the essential items.
Matt
Old May 27th 06, 05:46 PM posted to rec.aviation.piloting,rec.aviation.misc
"Matt Whiting" wrote in message
Most of the time spent composing a post isn't the typing. It's the figuring
out what to say, proof-reading, etc. My point about being a fast typist was
just to make sure it's understood that typing isn't the bottleneck in my
case, artificially increasing the time taken to post.
You aren't doing a sufficient preflight either.
I easily recognize that there are pilots doing three minute preflights.
That doesn't mean those preflights are effective. Try that in one of the
Embry-Riddle-style preflight competitions and you'd be laughed off the ramp.
Pete
Old May 26th 06, 05:27 PM posted to rec.aviation.piloting,rec.aviation.misc
Jay Honeck wrote:
It's a basic part of the preflight actions. I also spend a good 15-20
minutes walking around my airplane before every flight
I do a thorough pre-flight inspection before every flight. Every control
surface is checked for continuity, all four gas tanks are visually
inspected, oil is checked, wheel pants are given a tug, prop is examined,
stall indicator movement verified, every screw, bolt and connector is
visually inspected...
A preflight before every flight? I don't think so. Once a day. Check
the stall warner? Every year at the annual.
CAP SAREX what to expect? Robert M. Gary Piloting 8 August 22nd 05 02:16 PM
Class B busted...My problem or the controller's ? Antoņio Piloting 130 June 4th 05 02:59 PM
Busted IFR Checkride Jon Kraus Instrument Flight Rules 77 May 4th 04 02:31 PM
rec.aviation.questions is busted Dan Jacobson General Aviation 2 November 18th 03 05:39 PM
Q: What can a Commercial Helicopter Pilot Licence holder expect to earn? Trentus Rotorcraft 24 November 15th 03 01:46 AM
Copyright Š2004-2025 AviationBanter.
