Upgrading from C172SP to 182S
Old May 27th 06, 04:29 AM posted to rec.aviation.piloting
Default Upgrading from C172SP to 182S
Jay,
He was probably thinking about a RENTAL 182.
I'd quit flying before I'd allow my airplane in the rental fleet!
Karl
"Curator" N185KG
"Jay Honeck" wrote in message
news:BgPdg.750203$084.242848@attbi_s22...
I sure wouldn't dream of coming in behind the power curve, hitting an
unpaved strip and locking up the brakes, though. I've just got too much
money tied up in our plane to treat it like that...
Treat it like what? Nothing happens to the plane.
Nothing bad happens to your aircraft when you lock up the brakes on a
gravel runway, with the prop spinning? In a 182?
No stone chips in the prop? No flat-spotted or gouged tires? No stones
tossed into the paint?
Consider the added stress on the airframe. Motor mounts in particular are
going to be under great duress in a landing like you described. The
nosewheel structure will also be heavily stressed. Do that particular
landing "procedure" incorrectly in a 182, and you'll be buying a new
firewall. Many Skylane owners before you have discovered just how fragile
that nosegear-to-firewall connection really is.
I'm glad you have off-road fun with your plane, but you probably shouldn't
suggest a guy that is new to 182s do the same. What you described doing
with your plane is a high-skill, relatively high-risk game, and is
probably more suited for a tail dragger. It surely isn't suited for a
newbie 182 driver, like the O.P.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 27th 06, 04:46 AM posted to rec.aviation.piloting
Me, too -- but I don't think Newps is a renter.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 27th 06, 05:46 AM posted to rec.aviation.piloting
newsYPdg.750263$084.581463@attbi_s22...
He's not, and he wasn't when he flew a 182.
Sure, there's more wear and tear on the airplane. But you don't get an
airplane suitable for rough, short, unpaved operations and then avoid those
situations so that you can save on maintenance costs.
You could buy a used Cherokee Six and a used 182 combined for the price of a
used Beaver, and you don't see the people getting Beavers going around
babying them. They buy the plane for a purpose, and they accept that the
purpose may incur additional wear and tear.
It's great that you can limit your flying to situations that are low-impact
to the airplane, and that you're happy and satisfied with that use. But not
everyone is satisfied sticking to nice, long, smooth runways. Why would you
question their use of their airplane? They're doing what they want to with
it. That's the whole point of having an airplane and flying it!
Pete
Old May 27th 06, 04:17 PM posted to rec.aviation.piloting
Jay Honeck wrote:
Nothing bad happens to your aircraft when you lock up the brakes on a gravel
How are stones going to defy the laws of physics? The plane is moving
forward. Rocks don't leap off the ground and jump into the prop.
Not as long as you are not on pavement.
No stones
Stones may or may not get tossed into the paint. That's a hazard of
flying off road.
My 182 was on its third firewall. You damage the firewall by landing
nosewheel first. There is no added stress to the airplane, matter of
fact there is probably less. The vertical speed is the same but the
airspeed is less.
You can't slow your plane to 10 mph above stall and hold that all the
way to the ground? That's a sad state of affairs.
and is probably
Nosewheel or tailwheel is irrelavant. A tailwheel can be limiting in a
crosswind. With the nosewheel I am not worried about operations on the
ground. The tailwheel guys don't start working until they are on the
ground.
Old May 27th 06, 06:43 PM posted to rec.aviation.piloting
I believe there is a low-pressure area in front of the prop which causes an
inflow of air from the area forward of the prop to compensate for the air
that is being directed aft. Combine that with the usual preferential
headwind takeoffs and it seems likely stuff on the ground can be wind blown
and/or sucked off the ground and into a prop.
Old May 27th 06, 09:30 PM posted to rec.aviation.piloting
There is a short video that you can see that shows a Cessna running its
engine up while parked in a puddle. The water is maybe an inch deep,
hard to tell. The prop will create a little tornado directly beneath
its lowest point. This is what causes prop damage. Get the plane
moving just slightly and this effect is lost. Any air being sucked in
from the front, and I don't believe there is, is not strong enough to
pick up rocks.
GAO: Option of Upgrading Additional EA-6Bs Could Reduce Risk in Development of EA-18G. Mike Naval Aviation 0 April 28th 06 02:32 PM
C172SP engine start with battery switch only? Robert Winn Piloting 8 April 13th 04 12:31 AM
Cessna 182S flaps EDR Piloting 7 January 16th 04 02:37 AM
1997 Cessna 182S EDR Piloting 2 December 28th 03 03:21 AM
Upgrading System Anthony Acri Simulators 1 July 17th 03 03:18 AM
