Approach Timing
Old September 8th 04, 02:58 AM
C Kingsbury
"Howard Nelson" wrote in message . com...
I really, really, really would recommend flying an airspeed under all
circumstances.
Ditto. Planes fly airspeed, not groundspeed. I was taught to fly
standard configurations of pitch, power, and trim. These should
produce known airspeeds which set the plane up well for the specific
phase of flight.
Do you use the distance to the airport to determine/verify the MAP, even
though the time may not have expired?
Legally your IFR approved clock for timed approaches and NDB for NDB
approaches are what you WILL use. Rationally if my clock or NDB disagreed
with my GPS and I had to make a choice I would trust the GPS.
The conservative choice would be to listen to the first box that cries
"miss." Let's say the wind shifts and your groundspeed changes, the
handheld says you're there. Might be good to miss it. If OTOH the
clock says you're there and the GPS doesn't, you're not going to
increase your risks by missing on that basis.
I can understand the FAA wanting to avoid a free for all by regulating GPS
usage so carefully. But each pilot, if faced with conflicting data, needs to
decide which technology they trust their life to. The best way to do that is
lots of practice under VFR checking clock vs. GPS, NDB vs. GPS, VOR vs. GPS,
Localizer vs. GPS and make up your own mind.
I use handheld GPS and panel Loran to cross-check everything else in
my non GPS-equipped C-172.
Like you say, there's no way the FAA will ever allow handheld GPS as
an official navigational device for IFR, but they've also made a wise
decision to not prevent it from being used anyway. A Decent handheld
GPS and COM radio give a pilot a fighting chance to get down through
the clouds in a total electrical failure, which is one of the
emergencies I worry about most in a middle-aged plane like mine. (NB-
I have a Precise Flight standby vacuum already)
Also if you are not a renter you might consider spending 15-20K for an IFR
certified GPS linked to your autopilot.
You could probably put a good used box in for a lot less, though
perhaps not linked to the A/P. 6K range for a used King/Apollo unit +
install/certification is the estimate I've seen from multiple sources
for a 172.
Old September 8th 04, 05:40 PM
C Kingsbury
Roy Smith wrote in message ...
"miss." snip
I don't know if I agree with that. Let's say your calculations are
wrong and the timer runs out when you're 1/2 mile from the MAP. Which
has less overall risk:
1) Continuing another 1/2 mile to the real geographic MAP based on your
GPS, finding the runway, and landing uneventfully.
2) Going missed, and being back in the clouds trying to decide if you
should try the approach again or divert.
#1 sure sounds safer to me.
You're begging the question: "If I listen to the GPS and land safely,
isn't it safer to listen to the GPS and not head back up into the
clouds?" Of course it is, but you don't know in advance that following
the GPS will lead you to a safe landing. Check out this approach:
http://204.108.4.16/d-tpp/0409/00654VG23.PDF (VOR-23 @ LWM on Airnav)
Stright-in this will bring you down into a real minefield of stacks
and towers. Now let's say on the way down you plan to dial the VOR
into the GPS to get a DME reading to use as the MAP. But in the heat
of the moment you put LWM the airport instead of LWM the VOR in. This
means you'll wait until you're past the airport to miss. You're
probably OK so long as you don't go down any further, but you've
unquestionably increased your risk.
Or perhaps you're used to an approach at your home field where the DME
counts down, instead of up. You get distracted and see 3DME here, and
think, OK, I have 1.5 to go. So you putter on until you're 5 miles
away. Right about where that 606' obstacle is. Downdraft anyone?
My situation is purely hypothetical, but not at all unrealistic. I've
made every one of these mistakes in isolation. Even if I used the GPS
as a primary means of determining MAP, I would back it up with the
timer, which would quickly catch the gross errors described above.
Second, your response assumes that diverting to the alternate actually
increases risk. This is a variable situation. Where I fly in the
Northeast, you usually don't have to go more than 20-30 miles to find
an airport serviced by an ILS, which is usually what you'll put in as
an alternate if you're headed to a field with no precision approaches.
If your alternate is an asphalt patch with an NDB on the field, well,
then maybe you're better off trying to limbo your way in.
Best,
-cwk.
Old September 8th 04, 04:02 AM
Howard Nelson
for a 172.
Yep. It's that install/linking/cert that runs the price up. Other than a
430/530 box the labor may well equal the price of the unit.
Howard
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.754 / Virus Database: 504 - Release Date: 9/6/2004
Old September 8th 04, 04:32 AM
Newps
Legally I will use the IFR approved GPS and the little mileage number on
the plate. Screw the timing.
Old September 8th 04, 05:02 AM
Howard Nelson
"Newps" wrote in message
Here I thought we were discussing portable GPS's. My bad.
Howard
Old September 7th 04, 08:44 PM
Michael
john smith wrote
For those of you using handheld GPS's when you fly IFR:
Do you use the throttle to increase/decrease power to match the ground
speed to the approach speed table so the time is correct to the MAP?
Absoutely not. It's a moronic way to do things. Only the Airbus
flight control system does anything of the sort.
I use the GPS to 'estimate' the winds and compute ground speed.
Because of this, my timing to the missed approach point is always
perfect .
Michael
Old September 7th 04, 10:02 PM
Brien K. Meehan
Mitty wrote:
Doesn't seem like the MAP is that important.
On an instrument approach, it's the most important thing in the world.
So what if you are a bit
early or late when you decide you can't see where you're going?
You'd better study this a bit, because if you manage to get through
your IFR checkride without busting it a bit, this attitude may soon
make you dead a bit.
Old September 7th 04, 11:55 PM
Mitty
On 9/7/04 4:02 PM, Brien K. Meehan wrote the following:
I don't want to turn this into a flame war, but I'll take the bait he
How (calculator, flight computer, mentally, etc.) and how precisely,
during an approach, do you calculate your time to the MAP based on your
ground speed crossing the FAF? Finally, to you, what is an acceptable
"bit?"
My checkride went fine, thanks.
Old September 8th 04, 12:21 AM
Roy Smith
"bit?"
A perfectly reasonable question. Lacking any better instrumentation
(DME, or GPS), here's what I do:
1) Estimate the surface wind based on the best information you've got
(which usually means ATIS or AWOS).
2) Add some random fudge factor to account for the fact that the winds
at 500 - 2000 AGL (where you're going to be flying the approach) will
tend to be a bit stronger than on the surface.
3) If it's not a direct head or tail wind, take a WAG at the
head/tailwind component.
4) Add this to the indicated airspeed you plan on flying the approach at
(at the speeds and altitudes you usually use for approaches, IAS is
close enough to TAS that you shouldn't worry about the difference).
5) You now have a reasonable estimate of your groundspeed. If you're
trying to refine this estimate to anything closer than the nearest 10
kts, you're fooling yourself.
6) Now, look at the FAF-to-MAP timing table and do a rough interpolation
between the listed entries.
If you spend more than about 30 seconds on the whole process, you're
working too hard. Without a reliable way to measure GS, the best you
can do is a reasonable guess, so don't knock yourself out trying to do
anything fancier.
With a handheld GPS, you're be insane not to take advantage of the
information it gives you. If the MAP itself is not in the database, set
it navigating to the ARP, or the FAF, or the last stepdown fix, or
whatever makes the most sense for that approach. Start your watch to be
legal, but use your GPS to be safe.
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Approach Question- Published Missed Can't be flown? Brad Z Instrument Flight Rules 8 May 6th 04 04:19 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
