A question on reversers
Old June 24th 06, 03:56 PM posted to rec.aviation.piloting
Default A question on reversers
If you float in above the threshold a fair bit higher than Vref, is it
acceptable technique to chance the reverser to preclude landing too far
down the runway?
It is bad technique to "chance" anything. Jim is right in that if you're
out of position for landing a miss should be your first consideration.
I can't speak for all transports, but I seem to recall on the 727 and 747
there are lockouts that prevent reverse actuation in flight. Not 100% sure
of the physical lockout on the 727, and too lazy right now to look it up.
:-) I do recall that inflight reverser use was possible on at least some
models of the DC8.
In any event, I wouldn't consider use of reverse immediately before landing
a good idea.
Old June 24th 06, 04:10 PM posted to rec.aviation.piloting
models of the DC8.
John, I'm sure the Thailand Air Lauda A320 crash of about 10 years ago
has escaped your attention
The pilots somehow accidentally deployed the reversers on finals and
couldn't recover the craft
Ramapriya
Old June 24th 06, 04:39 PM posted to rec.aviation.piloting
The Lauda aircraft was a B767, and the accident occurred as a result of a
system failure some 20 minutes or so after T.O., not during a landing
approach. In normal operation, inflight reverse should be prevented in the
767.
In my post I was speaking in general terms, that as a matter of design,
operation of reversers in flight is usually prevented. However, there are
some exceptions, and in the event of a system failure or malfunction, all
sorts of unanticipated things can occur.
"John Gaquin" wrote in message . ..
down the runway?
It is bad technique to "chance" anything. Jim is right in that if you're out of position for landing a miss should be
I can't speak for all transports, but I seem to recall on the 727 and 747 there are lockouts that prevent reverse
actuation in flight. Not 100% sure of the physical lockout on the 727, and too lazy right now to look it up. :-) I
do recall that inflight reverser use was possible on at least some models of the DC8.
http://en.wikipedia.org/wiki/Lauda_Air_Flight_004
Old June 24th 06, 04:42 PM posted to rec.aviation.piloting
".Blueskies." wrote in message
I'm sorry, but I don't see how that relates to my post. Lauda crashed due
to a malfunction.
Old June 24th 06, 05:31 PM posted to rec.aviation.piloting
I'm sorry, but I don't see how that relates to my post. Lauda crashed due to a malfunction.
Oops, thanks. I was thinking all along that a pilot deployed it
accidentally. Or was that the EgyptAir crash off Massachussetts?...
Ramapriya
Old June 24th 06, 05:40 PM posted to rec.aviation.piloting
It seems that was an act of terrorism, the co-pilot for what
ever reason seemed to be crashing the aircraft, but that was
just some news reports, don't know if there ever was a final
and official determination made.
deployed it
Massachussetts?...
| Ramapriya
Old June 25th 06, 02:13 AM posted to rec.aviation.piloting
On the B727, the throttles must be in idle position in order to activate the
reversers. In the limitations section of the AFM, one is advised that
operation of reversers is not permitted in flight. I'm not aware of other
interlocks (Z-bar, etc)
down the runway?
sure
models of the DC8.
landing
a good idea.
Old June 26th 06, 05:09 AM posted to rec.aviation.piloting
Okay, I mainly just lurk here but thought I'd throw my two cents on
this.
When I was flying KC-135's in the '70's we'd air refuel a C-5 every now
and then.
It was very interesting just getting the C-5 into contact position, but
what was more interesting was when we'd practice a break-away. The C-5
would employ their thrust reversers and pretty much disappear.
Anyway, it's the only time I've known that thrust reversers were
employed in flight.
Today I'm retired and am flying my Warrior around Montana, and don't
plan on refueling a C-5 any time soon.
--Walt
Bozeman, Montana
down the runway?
models of the DC8.
a good idea.
Old June 26th 06, 05:15 AM posted to rec.aviation.piloting
Wow. And there evidently doesn't appear to be a maximum thrust limit
for deployment of the reversers either
Ramapriya
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
