A tower controller could do it but, like you say, there aren't many towered
fields without a low minimiums approach and no terrain issues. Generally it is terrain that limits minimiums. Mike MU-2 "C Kingsbury" wrote in message om... "Mike Rapoport" wrote in message thlink.net... It isn't cheaper when you consider that it requires an operator. Mike MU-2 Does it require a dedicated operator, or can any old controller hanging out in the tower run it? Out East I can't think of any Class D fields that don't have at least 1 ILS, but perhaps in other regions that's sometimes the case? -cwk. |
C Kingsbury wrote:
Out East I can't think of any Class D fields that don't have at least 1 ILS, but perhaps in other regions that's sometimes the case? Sniff Now you've made me feel badly about my home class D airport in Northern New Jersey, CDW, that has no precision approach (but we do have a localizer). I'd feel really badly did I not know that Hartford, in CT, also lacks a precision approach. They don't even have a localizer; just an LDA. [I think that this LDA lets you off pointing not at the airport, but at a now closed airport across a river. But I may be recalling incorrectly.] - Andrew |
In article ne.com,
Andrew Gideon wrote: C Kingsbury wrote: Out East I can't think of any Class D fields that don't have at least 1 ILS, but perhaps in other regions that's sometimes the case? Sniff Now you've made me feel badly about my home class D airport in Northern New Jersey, CDW, that has no precision approach (but we do have a localizer). I'd feel really badly did I not know that Hartford, in CT, also lacks a precision approach. They don't even have a localizer; just an LDA. [I think that this LDA lets you off pointing not at the airport, but at a now closed airport across a river. But I may be recalling incorrectly.] - Andrew In addition to Hartford and Caldwell, there's also Danburry which only has a localizer. |
It isn't cheaper when you consider that it requires an operator. It doesn't require a DEDICATED operator. There is no reason that the squawk code could not be issued by the approach/center controller. Typically, a non-busy airport would have no tower or a VFR tower, so one-in, one-out. The code could be set by a remote landline from approach/center, or it could simply use a fixed discrete code that would not be used for other purposes in that sector. Michael |
Could be, would be, should be...whatever the case, the SZT airport was going
to have to hire a DEDICATED operator. Most uncontrolled fields around here don't even have a RCO. In theory, I'm sure that you are right. Mike MU-2 "Michael" wrote in message om... "Mike Rapoport" wrote It isn't cheaper when you consider that it requires an operator. It doesn't require a DEDICATED operator. There is no reason that the squawk code could not be issued by the approach/center controller. Typically, a non-busy airport would have no tower or a VFR tower, so one-in, one-out. The code could be set by a remote landline from approach/center, or it could simply use a fixed discrete code that would not be used for other purposes in that sector. Michael |
Could be, would be, should be...whatever the case, the SZT airport was going to have to hire a DEDICATED operator. Most uncontrolled fields around here don't even have a RCO. In theory, I'm sure that you are right. The difference between theory and practice is much greater in practice than it is in theory. The real issue is that what started as a good idea had to get by the FAA. Michael |
"Gerry Caron" wrote in message ...
It works by using a Mode A interrogator and multiple receivers around the periphery of the airport. By measuring the time difference of arrival (TDOA) of your transponder replies, it calculates your position relative to the airport and the approach path. It then broadcasts thru an omni antenna an "ILS" signal modulating the 90 and 150 Hz tones to drive your CDI to indicate the proper guidance to the approach path. Fascinating the things people thought up back in the days before a constellation of satellites could provide a 3D positional fix with an accuracy measured in inches. With WAAS underway, it seems predictable that non-precision approaches will be joining colored airways in the dustbin of history. If the FAA had the resources and motivation it could probably be accomplished in 5 years, though I suppose 20 is more likely... -cwk. |
"C Kingsbury" wrote in message =
om... "Gerry Caron" wrote in message = ... =20 It works by using a Mode A interrogator and multiple receivers around = the periphery of the airport. By measuring the time difference of = arrival (TDOA) of your transponder replies, it calculates your position = relative to the airport and the approach path. It then broadcasts thru an omni = antenna an "ILS" signal modulating the 90 and 150 Hz tones to drive your CDI = to indicate the proper guidance to the approach path. =20 Fascinating the things people thought up back in the days before a constellation of satellites could provide a 3D positional fix with an accuracy measured in inches. =20 With WAAS underway, it seems predictable that non-precision approaches will be joining colored airways in the dustbin of history. If the FAA had the resources and motivation it could probably be accomplished in 5 years, though I suppose 20 is more likely... =20 -cwk. Five years? Twenty years? Probably about a year ago, the FAA mentioned the rate at which they were converting (IIRC) GPS approaches to LNAV/VNAV approaches. The number sounded fairly good, until doing the math showed it would = take them about thirty years to finish the current number of runways at that = rate. ---JRC--- |
om... With WAAS underway, it seems predictable that non-precision approaches will be joining colored airways in the dustbin of history. If the FAA This is unlikely when one considers that a number of airports which currently have WAAS approaches have non-precision minimums which are lower than the WAAS minimums. Also consider that WAAS approaches can only be designed to airports clear of obstructions according to TERPS; thus lots of airports will remain eligible only for non-precision approaches. -------------------- Richard Kaplan www.flyimc.com |
currently have WAAS approaches have non-precision minimums which are lower than the WAAS minimums. Do you have some examples? |
"bush flying" in the suburbs? | [email protected] | Home Built | 85 | December 28th 04 11:04 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 12:18 AM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
2nd update on Review of Plasma II Ignition System | MikeremlaP | Home Built | 8 | July 22nd 03 01:37 AM |
