"Richard Kaplan" wrote in message news:1095562995.6eAYDxNjAfSfAEnPws5pJw@teranews. ..
"C Kingsbury" wrote in message om... With WAAS underway, it seems predictable that non-precision approaches will be joining colored airways in the dustbin of history. If the FAA This is unlikely when one considers that a number of airports which currently have WAAS approaches have non-precision minimums which are lower than the WAAS minimums. Hmmm, is this just a matter of the TERPS guys being conservative until WAAS is better understood? I can't see any case where WAAS provides poorer positional accuracy than a VOR, and it should at least be very close to the performance of a localizer. Also consider that WAAS approaches can only be designed to airports clear of obstructions according to TERPS; thus lots of airports will remain eligible only for non-precision approaches. Heh. Good point, I hadn't thought about that so much. Actually, an interesting case-study can be seen looking at the different approaches for Rutland, VT (http://www.airnav.com/airport/KRUT) which is down in a valley with a gaggle of towers. With its proximity to several major ski resorts it gets a fair deal of light bizjet traffic. Approach | Minima AGL (all straight-in) ===========|============= LOC 19 | 2100 VOR-DME 19 | 1800 GPS 19 | 1400 LOC+DME 19 | 900 According to these plates, the angle of descent in the final segment ranges between 3.35-3.72 degrees, as compared to a 3deg standard ILS. Is there any reason why using WAAS, it wouldn't help to basically setup a virtual glideslope that brings the plane down to the minimum at the appropriate point, and then "levels off" until the missed approach point? Well, other than the fact that perhaps no one has thought about designing such a procedure, I suppose... Still, at the very least every airport should be able to support minimums equivalent to those that would be provided by a LOC-DME installation. You can't change the dictates of terrain but at least you don't have to pay to install and maintain a shed full of radio equipment. Best, -cwk. |
TLS is a system that was originally conceived as a system with ILS CAT I
minima, but that didn't need the expensive siting and grading required by a normal ILS system. Right now it appears that the original 200' HAT that was hoped for is being limited to a 350 HAT, at least temporarily. It is also considered "special" so you won't see them on the approach plates and will need to have special training and permission to fly it. FEDEX is using one in the Phillipines, and FAA has one set up in Atlantic City. The system still requires ILS equipment on board the aircraft, but also requires an operator on the ground to acquire the transponder code and operate the ground equipment. Rather than try to explain it in my own words, check this website out that has a good description; http://avnwww.jccbi.gov/icasc/docs/1...essibility.doc or; http://www.gaavionics.com/tls.htm JPH Trent D. Sanders wrote: Have you ever heard of, or have any experience with a thing called the "Transponder Landing System", a form of IFR approach using a transponder? What is it, how does it work, does it work, do you have to have a special "endorsement" to fly it, etc? TDS N2997Y |
"bush flying" in the suburbs? | [email protected] | Home Built | 85 | December 28th 04 11:04 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 12:18 AM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
2nd update on Review of Plasma II Ignition System | MikeremlaP | Home Built | 8 | July 22nd 03 01:37 AM |
