Cherokee 6 manual/info?
Old June 26th 06, 10:32 PM posted to rec.aviation.owning
Default Cherokee 6 manual/info?
On Mon, 26 Jun 2006 09:11:50 -0700, "Al"
It looks like I will have a mission to pick up a PA32-300 on Thurs. Can
anyone point me to an online copy of the flight maual, or perhaps some of
the pertinent information? I've got a couple of hours in a PA32-260 some
years ago, and will have a copy of the manual available when I pick up the
airplane, however I would like to prepare myself somewhat. Any warnings or
items I should watch out for?
Thanks,
Al G
Best glide is 110 MPH if I remember correctly. If you need it, pick
something pretty much right below you.
Other than that, just a fat Cherokee.
Be safe and Have fun!
z
Old June 26th 06, 10:28 PM posted to rec.aviation.owning
"zatatime" wrote in message ...
Thanks,
Al G
z
Yea, and the nose blocks a lot of the view up front when landing.... ;-0
Old June 26th 06, 10:49 PM posted to rec.aviation.owning
the airplane, however I would like to prepare myself somewhat. Any
warnings or items I should watch out for?
Al, if you need pages from a manual, let me know, I can scan them and
email them to you.
Where will you be picking it up and flying it to?
Old June 26th 06, 11:36 PM posted to rec.aviation.owning
"john smith" wrote in message
email them to you.
Thanks John, I'd appreciate that, amybe just one of the intro specification
pages, best rate, gross weight, etc. Also, I just got a fax, The aircraft
is a:
1974 PIPER CHEROKEE 6/300, S/N: 32-7440103, N77RH, 1880 TT, 10 SPOH, Garmin
GNS-430, All Logs, No Damage.
The probable new owner and I will be moving it from Bend, Ore, SO7, to
Roseburg, KRBG, thursday afternoon.
I've got 1k hrs in a TU206, so I'm probably used to the right rudder
requirement.
Al G.
Old June 27th 06, 12:17 AM posted to rec.aviation.owning
"Al" wrote in message ...
email them to you.
Thanks John, I'd appreciate that, amybe just one of the intro specification pages, best rate, gross weight, etc.
Also, I just got a fax, The aircraft is a:
1974 PIPER CHEROKEE 6/300, S/N: 32-7440103, N77RH, 1880 TT, 10 SPOH, Garmin GNS-430, All Logs, No Damage.
The probable new owner and I will be moving it from Bend, Ore, SO7, to Roseburg, KRBG, thursday afternoon.
I've got 1k hrs in a TU206, so I'm probably used to the right rudder requirement.
Al G.
A different beast than the Cessna - sounds like a nice plane. Watch not to exceed forward CG limits in the 300...
Old June 27th 06, 02:15 AM posted to rec.aviation.owning
is a:
requirement.
You should do alright.
One thing I forgot... the PA32-300 can be a real bitch to hot start.
Unlike the Continentals on the Cessna's, the Lycoming fuel injecteds do
not have a return line that you can purge by keeping the throttle open
and mixture full lean/closed with the fuel pump on.
The flooded procedure seems to work best.
I will scan the pertinent pages.
Send me an email to , and I will forward them to you.
If you aren't familiar with the G430, you can download a PDF file from
the Garmin website.
Old February 11th 08, 11:28 PM
JOM JOM is offline
Junior Member
First recorded activity by AviationBanter: Jan 2008
You can get a POH and checklist for a PA32-260 here- http://www.bomar.biz/
Hope this helps.
John
Thanks,
Al G
A Piper Cherokee 140... good first plane? Cecil Chapman Owning 20 September 4th 05 02:50 PM
Cherokee Pilots Association Fly-In Just Gets Better and Better Jay Honeck Piloting 7 August 8th 05 07:18 PM
CHEROKEE NATIONAL FLY-IN - MORE INFORMATION Don Owning 0 June 16th 04 05:14 AM
Cherokee National Fly-In & Convention - THIS MONTH Don General Aviation 0 June 3rd 04 05:01 AM
Cherokee National Fly-In & Convention Don General Aviation 0 March 20th 04 02:15 AM
