"Ernest Christley" wrote in message
... I think you're missing the forest for the trees. A wood steamer is your answer. Make a form out of sheet metal, then bend the graphlite around it. Tg is around 180F for most epoxies, so an hour at 212F should turn it to it's plastic state throughout. The internal bending stresses will pull themselves out. Take it out of the oven, and it should hold whatever shape it had been forced into. Now, what I understand of graphlite is that it gets it's strength from having all the fibers aligned and equally tensioned. Doing the above, you will probably get something only marginally better than a hand layup. But you won't know until you try. You are making some assumptions that are incorrect. First, movement of the fibers inside a resin system heated to Tg degrades the mechanical properties of the mass after it cools. This is because Tg is a temperature point that is usually used to define destruction of the member due to it's inability to maintain designed mechanical properties. In your description, epoxy is a thermoplastic that can be heated/formed and cooled repeatedly without loss of properties. In reality it is a thermoset and is not remoldable. The loss of mech properties happens as a microshear failure inside the matrix as the resin and fiber move relative to each other "crumbling" the crystaline structure of the resin. Be very careful when suggesting that heating a laminate to Tg, bending it, allowing it to cool is an answer to "reshaping" the part without serious degradation of the properties of the resin. OBTW, Graphlite is a BIS F Epoxy with a Tg of 100C. |
![]() J.Kahn wrote: Bob Kuykendall wrote: Earlier, wrote: I'm thinking like making a stick rib. Maybe try making the rib out of straight pieces, and let the rib truss lock in the curve for the upper and lower cap strips. I bet that'd work. Also, Graphlite comes in a variety of round, square, and rectangular cross-sections. I think the standard round sections go down to 0.020"; it might not show on the Web but Jim Marske can get it for you. Thanks, Bob K. Go to this page on graphlite http://www.aist-nara.ac.jp/~rieken/projects/composites.html The stuff is rolled into coils for shipment. Scroll down and check out the flat version bent by hand into a half circle. Yes, mine came rolled into a circle. When you cut the tape it straightens back out. I want it to hold a curve by itself. If I have to add other materials to hold it into the curve I want that kinda defeats some of the advatange to using it in the first place. If you are using a material to reinforce something, pre-stressing the reinforcement may or may not be a good idea, depending on whether it is pre-stressed in the same orientation as the applied stress, or contrary to it. For wing spars, it may be helpful to droop the rod down as it runs along the spar flange from root to tip. The leading edge of a stick rib would be another matter. Yes, there are other ways to make ribs. -- FF |
Bending sheet stock | Michael Horowitz | Restoration | 1 | April 24th 06 04:28 AM |
Wing Bending Oscillation | jcarlyle | Soaring | 18 | February 21st 06 04:37 PM |
Bending extruded angle | Veeduber | Home Built | 8 | August 29th 04 12:58 AM |
Building the Po' Boy Bending Brake | Veeduber | Home Built | 14 | March 1st 04 06:15 PM |
Minimum bending radius for 0.050" 6061-T6? | Bob Chilcoat | Home Built | 11 | February 5th 04 04:59 PM |
