Wondering What Light Sport Can Do For You?
Old July 29th 06, 07:26 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student,rec.aviation.ultralight
Highflyer
Default Wondering What Light Sport Can Do For You?
"Jose" wrote in message
. com...
The ONLY dammage (other than the curly prop) was an antenna on the belly.
Heck, the pain wasn't even scratched!
If I landed a 210 on its belly, I can guarantee you my pain will be more
than scratched. But if it has a curly prop, chances are good it will need
an engine teardown.
Jose
Actually chances are not "good" it will need an engine teardown. The FAA
has issued a circular to all IA's stating
that "any prop strike, even one where the engine is not stopped but only
suffers a loss of RPM" is likely to cause unseen internal damage and will
require an inspection teardown to be returned to service. Using a dial
indicator on the prop flange to check for runout is no longer considered
sufficient inspection.
I recently saw a Lycoming where the prop flange was as close to perfect as
they get. No runout at all. However the crank was in two pieces. It had
broken between the two rows of cylinders. The break was diagonal and the
engine still ran and developed power. However, it did stop pretty quickly
when you pulled the mixture out!
Highflyer
Highflight Aviation Services
Pinckneyville Airport ( PJY )
Old July 25th 06, 05:54 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student,rec.aviation.ultralight
Da Monk wrote:
http://groups.yahoo.com/group/Sport_Aircraft/
Is that guy landing that thing "wheels up" on the grass or did he
retract them that early in the takeoff?
Retractable landing gear are not permitted on Light Sport Aircraft.
Supposedly the FAA has approved at least one exemption for
an amphiban and may extend that to all amphibians.
Otherwise, someone needs to work on designs for retractable
floats...
FF
Old July 25th 06, 10:33 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student,rec.aviation.ultralight
CB
IIRC (Ron, back me up on this?) dual-position gear are permitted for
amphibian LSAs. You don't need a case-by-case exemption.
floats...
FF
Old July 25th 06, 11:13 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student,rec.aviation.ultralight
floats...
Another point of contention was the distinction between
retractible and in-flight repositionable gear.
FF
Old July 25th 06, 11:12 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student,rec.aviation.ultralight
Jim Macklin
But in the wisdom of a government career employee, they
can't be changed in flight, makes it rather hard to take-off
on the water with the wheels down so you can land on terra
firma.
"CB" wrote in message
permitted for
grass or did he
Sport Aircraft.
for
retractable
| floats...
| FF
Old July 26th 06, 03:33 AM posted to rec.aviation.owning,rec.aviation.piloting
Peter Duniho
"Jim Macklin" wrote in message
news:Rozxg.84176$ZW3.80192@dukeread04...
firma.
Given the risk of landing gear down on the water, I think this is an example
of where the FAA got it right. You decide before the flight whether you are
doing a seaplane flight or a land flight.
The whole point of LSA is to allow greatly reduced training costs and
airplane certification costs without reducing safety. Effectively creating
a limited seaplane rating does this.
Pete
Got to fly a light sport aircraft Jay Honeck Piloting 13 May 26th 06 10:30 PM
Towing w LSA (Light Sport Aircraft) Jeffrey Banks Soaring 12 September 14th 05 02:48 AM
Sport Light Aircraft regs Bill Daniels Soaring 13 July 22nd 04 08:02 PM
Mooney to Offer Light Sport Airplane Rick Pellicciotti Home Built 4 September 24th 03 02:08 PM
Effect of Light Sport on General Aviation Gilan Home Built 17 September 24th 03 07:11 AM
