TE Probe repairable?
Old July 26th 06, 02:55 PM posted to rec.aviation.soaring
Bill Daniels
Default TE Probe repairable?
I broke my TE probe at the fin socket. (Imagine cussing and dirt kicking)
After a bit more cussing, I managed to fish the broken end out of the fin
socket. (Of course, I did this AFTER assembling the Nimbus.)
The TE probe appears to have been a RU single function type with aluminum
two-hole tip, O-ring end that inserts into the 8mm fin socket and carbon
fiber tube between. The break was at one of the O-ring grooves. The probe
forward of the break is good. It seems possible that a new O-ring plug end
could be epoxied to the carbon tube.
Q's
Should I just buy a new probe?
Is there a source for the aluminum O-ring part to repair the broken probe?
Should I abandon the fin mounting altogether and consider converting to a
less vunerable fuselage probe over the wing?
Bill Daniels
JPI EGT probe failure typical signs Robert M. Gary Owning 5 March 3rd 06 11:29 PM
CHT probe + resistor installed (final) Jim Burns Owning 8 September 10th 05 02:34 PM
T.E. Probe Question KP Soaring 2 July 27th 05 02:58 PM
Cleaning a 3-way TE probe Jack Glendening Soaring 37 November 5th 03 06:45 PM
Broken line to Oil Temperature Probe, Repairable? rkane33 Owning 2 July 25th 03 03:19 AM
