![]() "Larry Dighera" wrote in message ... With regard to low-level MTRs, isn't the ceiling 500' AGL to 1,500' AGL? Why not just fly over top of the proposed MTR restricted airspace? If that approach should happen to interfere with navigation, then the pilot would do what he always does to enter R airspace: Contact ATC. I don't see the problem you apparently do. What am I overlooking? That contacting ATC doesn't mean you'll be cleared to enter a Restricted Area. Isn't joint-use under VFR more practical? Joint use of MTR airspace causes a hazard to air navigation because of the high speeds involved. Practicality is trumped by air safety in my mind. Is it not in yours? Of course, military high-speed, low-level MTR operations outside the Restricted airspace bounds would be prohibited. So if a MTR run impaled a civil aircraft outside of R airspace, there would be no ambiguity about who was responsible (and don't give me that see-and-avoid weasel clause; it's absurdly unrealistic at the speeds involved). How much time do you have driving an airplane at 300 knots or more? I've got about 4000 hours of tactical jet operation and never seemed to find it too difficult to see-and-avoid other aircraft. Would you characterize yourself as typical of the skill level attained by the majority of military fighter pilots? Let's also note something regarding your favorite 250 knot restriction below 10M'. For a period of time (long ago, galaxy far, far away), I operated an aircraft that flew final approach at typical landing weight at 205 KIAS. That was landing configuration with gear and flaps down. In clean configuration, 350 knots was generally the minimum maneuverable speed. At 250 knots clean, my agile fighter suddenly became a shuddering block of non-aerodynamic technology with little more G available than your Cessna 172. Not practical. Today, aircraft operate comfortably at lower speeds, but still need operational flexibility and therefore the exemption of the 250 knot restriction remains necessary. I don't recall having said the exemption isn't necessary. My objection is to the _hazard_ operating in excess of the speed limit the National Airspace System designers chose while creating the system. If you think the 250 knot limit below 10,000' is unwarranted, perhaps your credentials are superior to those who designed the system. Doubtful. Let's do a little analysis. VFR minimum visibility: 3 statute miles = 15,480' 250 knots: 417' per second Time to impact at 250 knots closing: 37 seconds (3 statute miles) These times do not take into consideration the speed of BOTH aircraft, and more importantly, they do not allow for the time it takes to recognize the threat, decide to maneuver out of the path, and the time it takes for the aircraft to respond and actually finish clearing the path. More likely, the exemption was issued as a necessary expedient at a time when the sky was much bigger (if you know what I mean), and there was less oversight. Today that exemption creates a negative impact on air safety, and the whole issue should be objectively reexamined by qualified engineers. [...] |
airspace: Contact ATC. I don't see the problem you apparently do. What am I overlooking? That contacting ATC doesn't mean you'll be cleared to enter a Restricted Area. I think there's the implication that one might be able to obtain permssion to do so via ATC (and if not, one stays away). Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
On Thu, 03 Aug 2006 15:59:33 GMT, "Steven P. McNicoll"
wrote in . net: "Larry Dighera" wrote in message .. . With regard to low-level MTRs, isn't the ceiling 500' AGL to 1,500' AGL? Why not just fly over top of the proposed MTR restricted airspace? If that approach should happen to interfere with navigation, then the pilot would do what he always does to enter R airspace: Contact ATC. I don't see the problem you apparently do. What am I overlooking? That contacting ATC doesn't mean you'll be cleared to enter a Restricted Area. True. Wouldn't you presume, that any denial of access into R airspace would be predicated on the fact that there is training activity occurring with in that R airspace (it's hot)? If so, it probably wouldn't be a good idea to enter that MTR at that time even if it remained joint use. Right? |
AGL? Why not just fly over top of the proposed MTR restricted airspace? There may be overlying SUA, or overlying clouds, or GL may already be pretty high up. If that approach should happen to interfere with navigation, then the pilot would do what he always does to enter R airspace: Contact ATC. I've attempted that, and also contacting the FSS as printed on the charts themselves, and often the putative controlling agency doesn't know whether it's hot or not. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
On Thu, 03 Aug 2006 16:02:22 GMT, Jose
wrote in : then the pilot would do what he always does to enter R airspace: Contact ATC. I've attempted that, and also contacting the FSS as printed on the charts themselves, and often the putative controlling agency doesn't know whether it's hot or not. That is true. Why do you suppose that occurs? Do you think ATC is so disorganized, that they can't find the military activity information, or do you think the military has provided ambiguous information, what? It would seem, that given the system in place for activating and deactivating Restricted airspace, there should be a concrete answer available at all times. |
On Thu, 03 Aug 2006 15:28:47 GMT, Larry Dighera
wrote: On Tue, 01 Aug 2006 15:25:29 GMT, Ed Rasimus wrote in :: OK, your homework for this week is to pick a major USAF tactical base. You seem familiar with MacDill, but you could use Langley, Luke, Nellis, Seymour-Johnson or similar. Now, draw up a minimum of four low level MTRs, each a minimum of 300 miles in length. Be sure that entry and exit points are close enough to base of origin for local operations during a typical 90 minute flight. Have at least two of the routes terminate on a weapons range. Consider the routes restricted airspace. Now, how does your GA traffic go anywhere? You have effectively created boxes that don't allow anyone else to use the airspace. With regard to low-level MTRs, isn't the ceiling 500' AGL to 1,500' AGL? Why not just fly over top of the proposed MTR restricted airspace? If that approach should happen to interfere with navigation, then the pilot would do what he always does to enter R airspace: Contact ATC. I don't see the problem you apparently do. What am I overlooking? You've added a factor not previously in evidence. If you draw the MTR with those altitude specs, then you MAY be able to create routes that would be meet training requirements and allow for reasonably unhindered GA traffic. You're overlooking the fact that ATC doesn't usually have coverage at those altitudes in areas typically employed for MTRs. They won't be able to offer you the desired "no responsibility on the part of the GA pilot" guarantee of no threat because they can't see traffic at those altitudes. Additionally, training maneuvers on an MTR may require formation repositioning, simulated evasive maneuvers, simulated armed reconnaisance maneuvering and even simulated weapons delivery maneuvers and re-attacks. Those requirements could seriously mitigate your ability to create 500-1500' AGL corridors. Isn't joint-use under VFR more practical? Joint use of MTR airspace causes a hazard to air navigation because of the high speeds involved. Practicality is trumped by air safety in my mind. Is it not in yours? If you ask that last sentence question, you must not have been paying attention throught the last 120 messages here. The (relatively) high speeds involved are not the problem you continually try to make them. How much time do you have driving an airplane at 300 knots or more? I've got about 4000 hours of tactical jet operation and never seemed to find it too difficult to see-and-avoid other aircraft. Would you characterize yourself as typical of the skill level attained by the majority of military fighter pilots? You demonstrate here that you actually don't know many military fighter pilots (BTW, there is no other kind--all fighter pilots are military). Show me a fighter pilot who does not contend that his personal skill level is above the average and I'll show you a pilot who will lose tomorrow. My skill level was generally above the majority. But the training level I required of those who were my students, those in my squadron and those in my flights was more than adequate to do the job safely. Let's also note something regarding your favorite 250 knot restriction below 10M'. For a period of time (long ago, galaxy far, far away), I operated an aircraft that flew final approach at typical landing weight at 205 KIAS. That was landing configuration with gear and flaps down. In clean configuration, 350 knots was generally the minimum maneuverable speed. At 250 knots clean, my agile fighter suddenly became a shuddering block of non-aerodynamic technology with little more G available than your Cessna 172. Not practical. Today, aircraft operate comfortably at lower speeds, but still need operational flexibility and therefore the exemption of the 250 knot restriction remains necessary. I don't recall having said the exemption isn't necessary. My objection is to the _hazard_ operating in excess of the speed limit the National Airspace System designers chose while creating the system. If you think the 250 knot limit below 10,000' is unwarranted, perhaps your credentials are superior to those who designed the system. Doubtful. My credentials may be different than theirs. But, they recognized the operational and aerodyamic necessity of the exception as well as I do. You are apparently the only one who does not recognize that some high performance tactical aircraft require that exemption to operate safely. 'Tis you Moriarty, not I. Let's do a little analysis. VFR minimum visibility: 3 statute miles = 15,480' 250 knots: 417' per second Time to impact at 250 knots closing: 37 seconds (3 statute miles) OK, hold your breath for 37 seconds. It's an incredibly long time. These times do not take into consideration the speed of BOTH aircraft, and more importantly, they do not allow for the time it takes to recognize the threat, decide to maneuver out of the path, and the time it takes for the aircraft to respond and actually finish clearing the path. Three seconds? Maybe five if you can't make a decision quickly. More likely, the exemption was issued as a necessary expedient at a time when the sky was much bigger (if you know what I mean), and there was less oversight. Today that exemption creates a negative impact on air safety, and the whole issue should be objectively reexamined by qualified engineers. Not engineers you twit. Operators! Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
It's a lot of sky to scan. And if nose to nose, you only have 19 seconds. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
On Thu, 03 Aug 2006 16:08:14 GMT, Ed Rasimus
wrote in : On Thu, 03 Aug 2006 15:28:47 GMT, Larry Dighera wrote: On Tue, 01 Aug 2006 15:25:29 GMT, Ed Rasimus wrote in : With regard to low-level MTRs, isn't the ceiling 500' AGL to 1,500' AGL? Why not just fly over top of the proposed MTR restricted airspace? If that approach should happen to interfere with navigation, then the pilot would do what he always does to enter R airspace: Contact ATC. I don't see the problem you apparently do. What am I overlooking? You've added a factor not previously in evidence. Which factor is that? If you draw the MTR with those altitude specs, then you MAY be able to create routes that would be meet training requirements and allow for reasonably unhindered GA traffic. That seemed obvious to me. You're overlooking the fact that ATC doesn't usually have coverage at those altitudes in areas typically employed for MTRs. Agreed. Are you saying there is a requirement for ATC to have radar coverage of all R airspace? Or are you saying, that if the military is going to shoulder responsibility for the hazard to air safety their high-speed, low-level operations create, it would require ATC radar coverage? ATC had perfectly good radar coverage in Florida, but it didn't prevent the MAC. And the Cessna pilot was found to have been partially responsible as a result of being incapable of avoiding at the speeds involved. They won't be able to offer you the desired "no responsibility on the part of the GA pilot" guarantee of no threat because they can't see traffic at those altitudes. First, I never indicated that GA should have 'no responsibility'; I said the military should bear sole legal responsibility for the hazards it poses to air safety as a result of operating under its exemption to the 250 knot speed limit below 10,000' feet. Next, There would be no necessity for the military to take sole responsibility as mentioned above, if they were operating in Class R airspace (unless they failed to schedule it with ATC/FSS). Additionally, training maneuvers on an MTR may require formation repositioning, simulated evasive maneuvers, simulated armed reconnaisance [sic] maneuvering and even simulated weapons delivery maneuvers and re-attacks. Those requirements could seriously mitigate your ability to create 500-1500' AGL corridors. [Mitigate: to cause to become less harsh or hostile] Not being familiar with those operations, I ask, would it be feasible to conduct those operations above 10,000'? If not, why not? I presume formation repositioning, simulated evasive maneuvers, simulated armed reconnaissance maneuvering and simulated weapons delivery maneuvers and re-attacks may require larger lateral, and perhaps vertical, boundaries than are currently provided by MTRs. Is that correct? Isn't joint-use under VFR more practical? Joint use of MTR airspace causes a hazard to air navigation because of the high speeds involved. Practicality is trumped by air safety in my mind. Is it not in yours? If you ask that last sentence question, you must not have been paying attention throught the last 120 messages here. The (relatively) high speeds involved are not the problem you continually try to make them. We disagree about that. (And you have evaded the question.) Would you characterize yourself as typical of the skill level attained by the majority of military fighter pilots? You demonstrate here that you actually don't know many military fighter pilots (BTW, there is no other kind--all fighter pilots are military) The Flying Tigers were a civilian group. Anyone who thinks the Flying Tigers were not fighter pilots is uninformed and/or delusional. My skill level was generally above the majority. Right. So using your own personal experiences as examples in this discussion is atypical of most military pilots, by your own admission. [...] therefore the exemption of the 250 knot restriction remains necessary. I don't recall having said the exemption isn't necessary. My objection is to the _hazard_ operating in excess of the speed limit the National Airspace System designers chose while creating the system. If you think the 250 knot limit below 10,000' is unwarranted, perhaps your credentials are superior to those who designed the system. Doubtful. My credentials may be different than theirs. But, they recognized the operational and aerodyamic necessity of the exception as well as I do. You are apparently the only one who does not recognize that some high performance tactical aircraft require that exemption to operate safely. 'Tis you Moriarty, not I. You'll find it impossible to locate a single instance in which I advocated operating an aircraft below its safe minimum speed. My issue is the operation in excess of the 250 knot speed limit in joint use airspace, and the hazard it causes to civil aviation. Let's do a little analysis. VFR minimum visibility: 3 statute miles = 15,480' 250 knots: 417' per second Time to impact at 250 knots closing: 37 seconds (3 statute miles) OK, hold your breath for 37 seconds. It's an incredibly long time. I am able to hold my breath for 1.5 minutes. Other's have done so recently for nearly 9 minutes. Of course, fast-movers operate in excess of 250 knots, and the equation does not consider head-on situations as occurred in Florida. The closing speed was 480 knots in that instance, which works out to a little over 19 seconds to visually identify the conflicting traffic at 3 statute miles, decide to take evasive action, and have the aircraft clear of the path of impact. These times do not take into consideration the speed of BOTH aircraft, and more importantly, they do not allow for the time it takes to recognize the threat, decide to maneuver out of the path, and the time it takes for the aircraft to respond and actually finish clearing the path. Three seconds? Maybe five if you can't make a decision quickly. Okay. Four seconds to make the decision to take evasive action, and a couple of seconds to input control commands and for the aircraft to actually clear the path, that leaves 13 seconds to visually identify the head-on traffic at 3 statute miles in minimum VMC. Now, if you consider a fighter at 300 knots approaching a 250 knot airliner head on, the closure rate would be 550 knots permitting only 17 seconds until impact. Subtracting six seconds for decision and maneuvering, leaves 11 seconds to visually identify the threat. That's precious little time to see-and-avoid in single pilot operations. More likely, the exemption was issued as a necessary expedient at a time when the sky was much bigger (if you know what I mean), and there was less oversight. Today that exemption creates a negative impact on air safety, and the whole issue should be objectively reexamined by qualified engineers. Not engineers you twit. Operators! [Ah. Invective and deprecation: the last refuge of the unarmed. Are you aware of how such loss of civility diminishes any respect you may have had? I don't expect you capable of apologizing. Disappointing.] Operators are not skilled in the disciplines of engineering. Operators have a vested interest in the decisions. Engineers use objective calculations to discover system limitations, not necessity nor emotion to arrive at unrealistic conclusions. -- DISCLAIMER If you find a posting or message from me offensive, inappropriate, or disruptive, please ignore it. If you don't know how to ignore a posting, complain to me and I will be only too happy to demonstrate... ;-) -- |
Scared of Mid-Airs?
Me too, so I stay away from 'em. It's easier if you know where they are. Larry Dighera wrote: (Have you ever been successful contacting Flight Service at 500' AGL to inquire if a MTR is hot?) Rarely, and that's an FAA problem. It could be that the lack of FSS coverage is the real culprit in MAC's. Maybe you should look into it. FSS performance is a contributing factor in at least one of the accidents you cite, and the unwillingness of civilian pilots to consult with the FSS is a factor in two of them. In all four of the accidents, military pilots were in contact with the appropriate agencies. Alternatively, we could REQUIRE BY REGULATION, that all MTR participants employ TCAS.... Interesting. Try convincing AOPA that all civilian light planes need to have TCAS so that they can participate in the system. A TCAS unit will cost more than the value of most of the aircraft in which it would be installed. Within the airspace where you'll find MTR's, civilian light planes are not required to have even a basic transponder. Perhaps the civilian community should begin to do its part to insure no more MAC's? We could surely do without MTR routes in the CONUS, and did until a few years ago. Low level training routes have been around for more than 40 years, that I know of. Never liked 'em, only because though I had to be there, the Cessna's didn't and they didn't care enough to know that I was there. 1. The presence of 450 knot military training flights within congested terminal airspace without benefit of the required ATC clearance cannot be allowed to kill innocent civilians either. You keep ignoring the facts, about which you have repeatedly been reminded. None of the four accidents you've cited in your rants actually fits the above. 2. ...Now we've got [MTR] here in the US. Perhaps there is a...less congested venue someplace else. You could be the head negotiator. Let us know how many such venues you find. Moving all military training offshore sounds like a real interesting proposition. Have you given it even 5 seconds of thought? Two should be more than enough. 3. As currently implemented, Military Training Routes are joint-use airspace. To expect that airspace to be free of non-military aircraft is unrealistic and contrary to federal civil and military regulations. It would be safer. Isn't that your concern? Just so we all understand the definition of a MTR: http://www.globalsecurity.org/milita...y/airspace.htm A Military Training Route, or MTR, is basically a long, low-altitude [joint use] corridor that serves as a flight path to a particular destination [with aircraft speeds up to mach 1]. The corridor is often 10 miles wide, 70 to 100 miles long [although it's not charted that way], and may range from 500 to 1,500 feet above ground level [and unrealistically relies solely upon see-and-avoid for collision avoidance in VMC]; occasionally, they are higher. MTRs are designed to provide realistic low-altitude training conditions for pilots. In times of conflict, to avoid detection by enemy radar, tactical fighter aircraft are often called upon to fly hundreds of miles at low altitude over varying terrain. Obviously, navigation is extremely difficult on high-speed low-altitude flights. That's why it is imperative that fighter pilots have ample opportunity to practice these necessary and demanding skills [even if it endangers the lives of the public]. Yes, read that last sentence again, the one with the word "imperative". The civil pilot chooses to transit airspace where he knows or should know that military missions are being flown. He enters at his own risk, and increases the risk to those military missions in so doing. Either he is an equal player or he is not. If he can't, as you claim, be expected to bear an equal share of responsibility for traffic avoidance, then he has no business operating in that air space. Those who imply otherwise would increase the danger to all involved. Have you considered the implications of certain forms of political dissent which could involve obstruction of these routes by civilian aircraft of various categories? Perhaps you have, after all. No I haven't. Only someone with a death wish would consider committing such a stupid act. And yet, you advocate the military take full responsibility for those who choose, for whatever reason, to enter an MTR, even for those with what you describe as a death wish? You can't have it both ways. In order for that to happen the presence of civilian aircraft would require the cessation or at least the modification of the mission and the resulting loss of training, increased costs, and ultimately less safety as these missions would have to be reflown, requiring a higher sortie count to achieve the necessary training. What would what you suggest that might accomplish besides a dead civilian airman and two destroyed aircraft? It comes as a complete surprise to you, I am sure, that there are people in this world who haven't the brains to assess the risks, and another group who actually treasure the opportunity to be splattered in a righteous cause. Nothing new about it, really, but you should pick up a newspaper now and then, and try to keep up. As pointed out in the preceding paragraphs, the mere presence of civilian aircraft in the airspace would be enough to shut down training under the restrictions you're advocating. Get real. Reality is the province of the fighter pilot, Larry. The "hundred-dollar hamburger" is a lolly-gag for the casual recreationist, be he ever so experienced. BTDT, all the way round the block, and back again. Or are you referring to the glider that was hit on a MTR by an A6 [sic]? The glider pilot, who had the right of way, was found by the NTSB to be the cause of the MAC! There's justice for you. Have you complained to the NTSB? Perhaps the Federal Government should be responsible for traffic separation -- there's a novel notion. Civil aircraft to the right of military aircraft: http://www.ntsb.gov/ntsb/brief.asp?e...26X00109&key=1 The usual NTSB pointless response amounting to, "they ran into each other because they ran into each other," or, in NTSB-speak, "both pilots failed to...maintain clearance from other aircraft." But you think it was all the military's fault. There was nothing about this accident that made it a "military" type of accident. Any two civilian aircraft could have had exactly the same accident in the same place. The T-37 was at 200 kts, well below the speed any number of civilian aircraft could have been traveling, and was not on an MTR. The Ag plane was invisible to ATC while operating in marginal VFR conditions, having neither a transponder nor a radio. F-16s lacked required ATC clearance: http://www.ntsb.gov/ntsb/brief.asp?e...12X22313&key=1 Flight lead screws up; and "ATC’s lack of awareness that there was more than one F-16 aircraft in the formation flight, which reduced the ATC controllers ability to detect and resolve the conflict that resulted in the collision," despite the fact that fighters don't go anywhere alone. Maybe ATC could train their people better, too. What do you think? A6 pilot expected to exit MTR eight minutes after route closu http://www.ntsb.gov/ntsb/brief.asp?e...11X12242&key=1 AG Cat pilot unaware of the existence of MTR; this FSS habitually fails to give useful info to local flights; and so the NTSB cites "inherent limitations of the see-and-avoid concept." How about the inherent limitations of ignorant Ag Cat pilots and apathetic FSS employees? A6 hit glider that had right of way: http://www.ntsb.gov/ntsb/brief.asp?e...13X33340&key=1 "THE _A7E_ PLT HAD INFORMED THE NECESSARY FLT SERV STATIONS THAT THE ROUTE WAS ACTIVE; THE GLIDER PLT HAD NOT CONTACTED THE FLT SERV STATIONS TO DETERMINE IF THE ROUTE WAS ACTIVE." Poor preflight planning and preparation on the part of the glider pilot, according to the NTSB. A proper evaluation of the dangers of operating in a hot MTR cannot possibly be made if he doesn't know about the MTR. He just didn't give himself a fighting chance. Would he even have known if he was circling over the VOR on a busy airway? Sure, you go where the lift is, within reason, in a glider, but "situational awareness" -- the same thing you so correctly demand of the F-16 flight lead above -- is required even of glider pilots. I would say, "especially of glider pilots", given the characteristics of that beautiful sport. BTDT, got the glider. I would like to see the military assume responsibility for the hazard their operations under FAR § 91.117(d) cause to civil flights in all airspace. That exemption to the 250 knot speed limit below 10,000' is an affront to the design of the NAS. Then change the NAS. The laws of physics remain beyond the reach of the legislature, despite your passionate objections. If not, why have a speed limit at all? Simply to minimize UNNECESSARY high speed operation in an area of mixed traffic. You cannot continue to ignore the aerodynamic as well as the operational necessity for some military aircraft to operate well above your beloved 250 kts, and still expect that you should be taken seriously. Does it surprise you to know that there are civilian aircraft which also must operate above 250kts below 10,000'? Their reasons too are valid. BTDT, got the ATPR and the fancy hat. If military operations create a civil hazard, they should be segregated from civil flights. We disagree only on the mechanism to achieve that end. As has been stated elsewhere, this is a problem that has no answer but cooperation and an assumption of both risk and responsibility by all parties. So you've read all I've written on this subject over the past six years? Unfortunately. Redundant, shallow, and obtuse though it has been. It is easy to be destructive...but it takes effort to be constructive.... Good advice, perhaps you will keep it in mind. Implicit in that parting shot is the notion that I have somehow been destructive. EXPLICIT in that parting shot is the well-regarded notion that "it takes effort to be constructive." A great deal of effort is required to go beyond where the NAS is today -- effort that you seem unwilling to undertake, given your six-year crusade against the windmills of your own ignorance. Jack |
On Wed, 02 Aug 2006 15:43:18 GMT, 588 wrote in
: Scared of Mid-Airs? Me too, so I stay away from 'em. It's easier if you know where they are. Another inane remark like that, and you'll find yourself without my readership. I find no humor in the needless death and destruction of a MAC. I sincerely hope your arrogance and disregard for air safety are not typical of military airmen. |
UBL wants a truce - he's scared of the CIA UAV | John Doe | Aviation Marketplace | 1 | January 19th 06 08:58 PM |
The kids are scared, was Saddam evacuated | D. Strang | Military Aviation | 0 | April 7th 04 10:36 PM |
Scared and trigger-happy | John Galt | Military Aviation | 5 | January 31st 04 12:11 AM |
