On Fri, 04 Aug 2006 15:12:37 GMT, Ed Rasimus
wrote in : On Fri, 04 Aug 2006 14:49:54 GMT, Larry Dighera wrote: On Fri, 04 Aug 2006 13:28:28 GMT, Ed Rasimus wrote in : Every flight, every day, by the military is on a flight plan. Even those flights on VFR MTRs? Yes. Then why are there IFR MTRs and VFR MTRs? |
On Fri, 04 Aug 2006 15:59:32 GMT, Larry Dighera
wrote: On Fri, 04 Aug 2006 15:12:37 GMT, Ed Rasimus wrote in : On Fri, 04 Aug 2006 14:49:54 GMT, Larry Dighera wrote: On Fri, 04 Aug 2006 13:28:28 GMT, Ed Rasimus wrote in : Every flight, every day, by the military is on a flight plan. Even those flights on VFR MTRs? Yes. Then why are there IFR MTRs and VFR MTRs? Because some can be flown in visual conditions and some can be flown in instrument conditions as well. Regardless of weather conditions, IAW regulations all military flights are conducted on an IFR flight plan ("to the maximum extent practicable" -- which is regulation-speak for all of them). A "flight plan" is merely a record of your intended route of flight--it can be a VFR or IFR flight plan. Flight plans are filed with Flight Service Stations--an entity of the FAA, but not an air traffic controlling agency. Regardless, the flight plan type for the military is IFR. (I use the term "military" with some trepidation as I do not know if Army rotary wing craft do that.) You really don't know a lot about this do you? Yet, you are steadfast in your opinions. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
![]() "Larry Dighera" wrote in message ... Every flight, every day, by the military is on a flight plan. Even those flights on VFR MTRs? Yes. Then why are there IFR MTRs and VFR MTRs? Are there IFR and VFR flight plans? |
Even those flights on VFR MTRs? Yes. Does ATC track those flights in real time, at least with non-radar position reporting? If so, then ATC should be able to provide better information that a civilian pilot could use to determine whether or not to transition a route at a particular point at a particular time. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
On Fri, 04 Aug 2006 16:01:36 GMT, Jose
wrote: Every flight, every day, by the military is on a flight plan. Even those flights on VFR MTRs? Yes. Does ATC track those flights in real time, at least with non-radar position reporting? If so, then ATC should be able to provide better information that a civilian pilot could use to determine whether or not to transition a route at a particular point at a particular time. See the post to LD regarding what a flight plan is. Departures are conducted under ATC. Recoveries are conducted under ATC. Training time along an MTR, within a MOA, in restricted airspace, or on a range is usually done without ATC involvement. If your hypothetical civilian pilot wants ATC to provide him safe separation from other IFR aircraft, he/she should file an IFR flight plan, obtain an IFR clearance, and operate in controlled airspace under ATC's control. They should also look out the window as best they can. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
![]() Jose wrote: Every flight, every day, by the military is on a flight plan. Even those flights on VFR MTRs? Yes. Does ATC track those flights in real time, at least with non-radar position reporting? If so, then ATC should be able to provide better information that a civilian pilot could use to determine whether or not to transition a route at a particular point at a particular time. Jose When I was an air traffic controller at the Denver Enroute Center we would get a flight strip for, say, a B-52 entering a MTR. It's been a while but the flight strip would have his entry time for the MTR and a calculated exit time along with the altitude he'd be climbing to at the exit point. We didn't track him at all while he was on the route; he wasn't on radar and, given the nature of an MTR, it would be nearly impossible to give a civilian pilot an accurate position report of the B-52. It's been several years since I've been a controller so things may have changed. --Walt Weaver |
![]() Jose wrote: Every flight, every day, by the military is on a flight plan. Even those flights on VFR MTRs? Yes. Does ATC track those flights in real time, at least with non-radar position reporting? No. |
![]() On Fri, 04 Aug 2006 13:28:28 GMT, Ed Rasimus wrote in : Every flight, every day, by the military is on a flight plan. Not an FAA flight plan. |
On Fri, 04 Aug 2006 12:05:07 -0600, Newps wrote:
On Fri, 04 Aug 2006 13:28:28 GMT, Ed Rasimus wrote in : Every flight, every day, by the military is on a flight plan. Not an FAA flight plan. Within the USA they certainly are. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
UBL wants a truce - he's scared of the CIA UAV | John Doe | Aviation Marketplace | 1 | January 19th 06 08:58 PM |
The kids are scared, was Saddam evacuated | D. Strang | Military Aviation | 0 | April 7th 04 10:36 PM |
Scared and trigger-happy | John Galt | Military Aviation | 5 | January 31st 04 12:11 AM |
