GPS Reception Problems with 396
Old August 5th 06, 03:40 AM posted to rec.aviation.piloting
Jon Woellhaf
Default GPS Reception Problems with 396
With regard to com/nav receivers causing a GPS to lose satellites, Dan
asked,
... Is it simply the act of tuning the frequency, or the act
of actually _receiving_ something on the frequency?
Just tuning the frequency.
Old August 5th 06, 03:49 AM posted to rec.aviation.piloting
Dan[_1_]
This isn't my problem then.... Must be something in the unit.
--Dan
asked,
Old August 5th 06, 12:19 AM posted to rec.aviation.piloting
.Blueskies.
"Jack Cunniff" wrote in message ...
: "Dan" writes:
: Is anyone else having major GPS satellite reception problems with their
: 396? I've made two trips since getting the 396 and have noticed the
: following...
: After takeoff or on arrival within 5 miles of airports here in the
: Phoenix Metro area I have _always_ experienced a loss of GPS signal.
: This could happen even on a smooth, straight in approach (it's not that
: I'm turning away from the satellites, etc.)
: According to this page (Jay Honeck had recently shared the URL elsewhere)
: http://www.scn.org/~bk269/gps.html , certain nav/com frequencies can
: prevent your handheld GPS from receiving signal.
: It's likely, since it's in the same area, that you're tuning one of the
: frequencies listed on that page.
: I've always found that changing frequencies solved the problem; put up
: your satellite status page, then get permission from ATC to go off
: frequency. Turn OFF the radios (if you're in VFR and not using the NAV),
: and you'll quickly know whether you've got a nav/com interference problem.
: I first found this problem when I bought my Arrow (Narco panel), and had
: this problem within the first day or two. I have had interference affect
: my GPS Pilot III, 196, and 396.
: -Jack
Did you try any other GPS brands beside Garmin?
Mooney Engine Problems in Flight Paul Smedshammer Piloting 45 December 18th 04 10:40 AM
ILS reception question gatt Piloting 6 June 11th 04 03:19 AM
Chaplains urge couples to attend retreat to solve problems, By Kent Harris, Stars and Stripes Otis Willie Military Aviation 0 May 31st 04 04:46 AM
F22 Problems Paul F Austin Military Aviation 9 February 5th 04 03:27 AM
